Question about Dell 3000cn Color Laser Printer
Print quality problem
Hi all, I am having a annoying print quality problem and any help or clue would be great. please have a look at that print scan. http://www.flickr.com/photos/99527156@N00/415574467/ I have tried to basic clean what written in the manual but didnt work. Thanks in advance Mehmet.
This is probably long overdue, but I had the same problem. You need a new drum, unfortunately.
Posted on Nov 09, 2007
Printer will scan but doesn't print all colors when printing
Hi Donald,
  • First,make sure you're printing on original Epson cartridges.
  • If the ink cartridges are old,replace them.
  • Select BEST as the quality setting.
  • For the best print qualities,use the Epson special papers which are highly designed for the best prints.
  • Make sure you load one paper at a time.
  • You may also need to do a print head cleaning on the printer to unclog the nozzles and enable smooth ink delivery.
  • Check whether the printhead needs cleaning by,
  • Turn on the printer.
  • Load a letter size paper that is plain.
  • Press setup.
  • Then press the< or > to select maintainance.
  • Press OK.
  • On the highlighted NOZZLE CHECK option,press OK.
Hope this helps.Thanks!
Please rate this answer.
Nov 10, 2011 | Epson Stylus RX580 InkJet Photo Printer
Hi. I cant get my printer to allign. I've just replaced the black ink cartridge and when i put the allignment page inside the scanner it wont scan
Did you try to align the unit manually or with the computer?
Alignment page does not print
1 Make sure you remove the sticker and transparent tape from both print
cartridges.
2 Make sure the color print cartridge is secure in the left carrier and the black
print cartridge is secure in the right carrier.
3 Make sure you loaded the paper correctly and did not force the paper into
the printer.
Aligning your print cartridges without a computer
Make sure you follow the steps on the Setup sheet to complete hardware
installation. Continue with the following steps to optimize print quality.
1 Make sure you have loaded paper into the paper support, and then press
and hold Scan for three seconds. For help, see "Using the control panel"
on page 4.
An alignment page prints.
2 Place the printed alignment page onto the scanner glass.
3 Press Scan. For help, see "Using the control panel" on page 4.
Once scanning is complete, your print cartridges are aligned for optimal
print quality.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 15, 2010 | Lexmark X2550 All-In-One Printer
How can I scan a document then print it with larger print?
You can scan a document or photo or negative film etc.. using a scanner, there a many types of scanners which you can choose as per your requirement. There are dedicated scanners, all in one integrated scanners, or two in one like that.. but if you need it for your professional use or daily use, it's better to get a dedicated scanner not "all in one" since with all in one if the copier fails or fax fails, the scanner will also fail because they are related and built-in integrated.
The process of scanning a document is as follows;
  • > Place the document on the scanner's flatbed.
  • > Press scan button or scan using the integrated software from the computer.
  • > Customize the scan settings/quality.
  • > Save the scanned documents.
Printing a document to a larger size is different, you can use photo editors like photoshop, paint.net etc..where you can changed the resolution as well as the size of the image. It's best to change the size or resolution before you give the print command. Or you can also change the print size with the paper size or print size.
If you still need more help, please let me know with more details. I am ready to assist you.
Good luck.
Thanks for using FixYa.
Jul 04, 2010 | Computers & Internet
Can't scan but can print through print server
Returned the printer to the store and bought an HP... It works great
Dec 28, 2009 | Canon Pixma MP500 All-In-One InkJet...
The printer prints very slowly all of a sudden. It took over an hour to print out 4 pages. I've unplugged everything. I've cleared the print ques. Same thing is happening when I copy. Help!
If the output quality has improved greatly, you may have selected the "High" quality instead of "Normal". The front panel should give you a clue as to how to adjust.
Jun 11, 2009 | HP PSC 2410 All-In-One InkJet Printer
Help please
When printing you should go to the properties dialog box and check the quality setting that your printer defaults to. You'll probably find options to print either custom, fast, standard or high - you'll probably also be give a choice of paper type to print to - photo, etc. You may or may not be able to make these settings your defaults from now on but most likely you will have to set these at the beginning of your print sessions.
Feb 22, 2009 | HP PSC 1350 All-In-One Thermal Printer
HP LJ P2015DN making noise/squeaking
As you mentioned that the printer makes loud grinding noise or squeaking when page comes out than i feel this is the noise coming out due to faulty fuser.
I want to be sure so please open the rear bin and try to print if still noise comes than i m sure it is fuser.
If there are smudges on the printed page or if some film coating is coming out with printed page than fuser roller are physically damage.
However in this case i assume fuser is faulty.
If there opening the rear bin noise goes off than top output rollers are faulty.
Thanks and Regards
Neeraj Sharma
Feb 18, 2009 | HP LaserJet P2015dn Printer
HP Photosmart C6280 All-In-One won't Scan
Hi how to solve problem to photocopier machine canon ir 2520.problem is machine show massage network download available.how to solve it?please help me
Jan 25, 2018 | Office Equipment & Supplies
Low print quality
Please click on the web link given below and perform the steps as given in the web page to fix the issue.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00381780&cc=us&lc=en&dlc=en&product=439320
This should fix the issue.
Have a great day!
Feb 22, 2008 | HP LaserJet 1020 Printer
Can't get barcodes to scan?
have you tried different darkness settings? it sounds like you only need to turn the darkness up a little.
Apr 02, 2007 | Zebra 110XiIIIPlus Label Printer
Dell 3000cn Color Laser Printer Logo
71 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
