Question about IBM Wheelwriter 30 Typewriter
The 9, o, l, & . keys don't print. I notice they're all in a row
These are the only 4 keys that don't print. Must be more than coincidence that they are all in a line.
  • IBM Master
  • 3,594 Answers
Check the two ribbon connectors on the keypoard, if they are OK you probably need a new keyboard
Posted on Dec 14, 2008
Top row keys don't work on iPhone
your digitizer is not working, you need to chane it and itll work fine after that
Dec 13, 2012 | Apple iPhone 3G Black Smartphone
Scroll lock on mousepad get locked
Try: To toggle your scroll lock key:
  1. Click on the Windows Start button.
  2. Select Run.
  3. Type 'OSK' in the dialog box.
  4. Click on OK.
  5. The Microsoft on-screen keyboard will open. Notice that the slk, or scroll lock, key (located in the top row of the on-screen keyboard as shown below) is turned on.
  6. Click on slk (in the top row of the on-screen keyboard). This will toggle the state of the scroll lock key. Notice that the scroll lock key is no longer outlined in red. Scroll lock is now off.
Aug 29, 2012 | Lenovo INC 102495U Z570 Ip Ci321 156...
Keypad's 7&* not working
This picture repair guide may help to diagnose and repair on nokia X2 mobile phone handset.
Just follow the instructions stated on the picture itself.
Keypads key configuration by Rows and Columns
Row 0 = soft left, left, soft right, right
Row 1 = send, up, , down, camera
Row 2 = 1, 2, 3, select,
Row 3 = 4, 5, 6, volume up
Row 4 = 7, 8, 9, voume down
Row 5 = * , 0, #
Row 6 = music play, music forward, music rewind
Column 0 = soft left, send, 1, 4, 7, *, music play
Column 1 = left, up, 2, 5, 8, 0, music forward
Column 2 = soft right, 3, 6, 9, #, music rewind, camera
Column 3 = right, down, select, volume up, volume down,
Jan 05, 2012 | Nokia 5700 Cellular Phone
How do I load JT21 staples into a Arrow JT27 Stapler gun?
I was having the problems everyone listed... with the staples loading & firing... I guess the instructions are lousy .. should be ON THE PACKAGE to make it clear.. but.. on the stapler itself on the bottom.. it explains how to correctly load.. you don't put the staples on the piece that slides out.. you slide it out, load the staples in the open tunnel ..then slide the piece back.. that piece is the spring loader... since i finally figured it out ( by coincidence that I turned it over & noticed some faint words printed) - it works PERFECT every time! great little stapler... please fix your directions... seems to be a common misunderstanding!!!
Nov 07, 2010 | Arrow T50P ARROW STAPLE GUN
ok here from left to right top row esc f1 f2 f3 f4 f5 f6 f7 f8 f9 f10 f11 f12 prtscrn scrolllock pause second row ~ 1 2 3 4 5 6 7 8 9 0 - = bkspc insert home page up num lock / * - third row tab q w e r t y u i o p [ ] \ del end pgdn 789+ fourth row caps lock a s d f g h j k l ; ' enter 4 5 6 fifth row shift z x c v b n m , . / shift up 1 2 3 enter bottom row ctrl windows key alt spacebar alt windows right click ctrl 0. hope that helped
Oct 11, 2009 | Compaq Keyboard
you have not set up the proper size .change settings accordingly.
Jan 24, 2009 | Brother MFC-465CN InkJet Printer
Print Screen Function
On the top row, on the right hand side, second from the left, there should be a Print Screen key (Print Screen / SysRq). Just press that key once - it should give you a PrintScreen.
Jul 20, 2008 | Dell Latitude D630 Notebook
If you look at the Convergence ICs you will notice a row of resistors under the fins of the heat sink. Those are the 4.7 ohm resistors. Also in that same row of resistors you will notice the 6 yellow picos they are all lined up the picos have 4 grouped together then 1 more on each end of that row or resistors.
Jun 21, 2008 | Sony KP-57WS500 57" Rear Projection...
Epson CX6600 Skips every other 5th line when printing
Run the print head cleaning routine from the printers driver or control panel. you may have to run it 3 or 4 times to regain all the lines.
May 14, 2008 | Epson Stylus CX6600 All-In-One InkJet...
IBM Wheelwriter 30 Typewriter Logo
27 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
