Question about HP Computers & Internet
I don't know how to remove attachments - HP Computers & Internet
  • 1 more comment
  • marpdq Dec 13, 2008
    I have 101 attachments on my computer/ I want to remove them but don't know how.
  • marpdq Dec 16, 2008
    Thank you for the good help. It worked great and I got rid of the stored attachments. I really appreciate your response to my call for help. marpdq
  • Justin Washburn May 11, 2010
    Not sure i am following the problem, you want to remove atachments you are recieving or sending?
  • 116 Answers
You cannot delete just the attachment from emails recieved, however you dont have to open them, also you can change this setting in outlook express goto tools->options->click security tab->remove the check next to "do not allow attachments to be saved or opened that could potentially be a virus". also if you right click on the paperclip next to the message on the left side and go to delete it will remove the email.
Posted on Dec 13, 2008
Re~attaching spring on Maytag Dryer PYE2300AYW While replacing the belt the spring slipped off and I don't know where to attach it to, one end is on the idler, where does the other end go?
If I am not mistaken, your spring called a Idler spring should mount to the motor mount and the other end to the idler arm. But if you do not remove the drum from the dryer it will be hard to see how to re-install the spring. Remove the drum to make your task easier for your self.
Good Luck
Oct 11, 2011 | Maytag PYE2300AY Electric Dryer
Don't know how to remove and swap lenses on my olympus sp-590uz
The lens isn't supposed to be removable. With the CLA-11 Adapter Tube you can add an additional lens to the camera, such as close-up, wide-angle, or telephoto. However, these attachments go in front of the lens that is already on the camera.
Jul 29, 2011 | Olympus Cameras
Viking oven gets warm but not real hot. The coil does not get red and appears to be not working
Typically the problem is with the oven controller. IF your RTD (resistive temperature device) is ok then your oven controller board is faulty. When the oven is turned on (bake mode) the oven controller closes the relay that controls the bottom element and the oven begins to heat. The RTD or thermostat provides a feedback loop to the oven controller. RTDs don't partially fail, they either work or they don't. Since your oven is getting warm I would imagine the RTD is okay. You can verify the RTD by measuring its resistance at room temperature. Remove power from the oven and either remove the RTD completely and measure with an OHM meter or remove leads and measure while still attached to the oven chassis. You may have to remove it if your ohm meter leads won't reach. I don't know your model oven but most RTDs at room temp are about 1.1 kohms or 1100 ohms. If this is the case your RTD is fine and your controller board is bad. Please let me know if you need anything else. Good luck!
Jul 02, 2011 | Viking Kitchen Ranges
Dont know how to loosen or tighten the belt im trying to put on my car. the belt is connecting the alternator to the waterpump
You need to loosen the bolts that attach the alternator to the engine. Just loosen then a turn or so, don't remove them. Then there should be a long 10 or 12mm bolt attached to a bracket being held by one of those bolts attaching the alternator. One direction loosens while the other tightens the belt. When it is where you want it, retighten the alternator bolts and test.
Jun 06, 2011 | 2003 Mitsubishi Galant
I accidently removed a toolbar, don,t know wich one, now I can,t open attached links
go to start /accessories/system tools/ system restore follow the on screen prompts.
Oct 06, 2010 | Computers & Internet
Have an older tractor and snow blower attachment.
Go to sears.com and lookup in the parts listings for the tractors model number and the snowblowers model number and they will show all the attachments and brackets needed to run it. Hope This Helps Don
Nov 09, 2009 | Craftsman Garden
I don not know which direction to attach ruuber band that turns the turntable.
My husband had a flash of insight and remembered what he did when he accidently removed it when we bought the turntable. Thanks for checking back!!
Sep 17, 2009 | Sony Audio Players & Recorders
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
