Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
No picture and a sequence of 5 orange flashes on the power button
My TV wont power up. I tried replacing the lamp and resetting the lamp timer. All I get is a brief green on the power button and then it goes into a sequence of 5 flashing yellow lights. The owners manual doesn't covre this light sequence. Anyone got an answer?
  • Waynarr Mar 28, 2009
    I tried the deep cleaning....still got the problem...
Either the door to the lamp is open or your ballist went out thats wat happened to me
Posted on Dec 20, 2010
  • 37 Answers
Gotta unplug it let it reset, let it sit for at least 3 minutes, then plug it back in...but you may need to clean it out remove the bulb grab a rag and a shop vac and clean out the bulb housing. then take off the back along with the left speaker and clean it out (the same way) basically the dust is keeping the heat in and it is causing an overload,.,,
Posted on Mar 12, 2009
I recently replaced the TY-LA1000 lamp but I'm getting a yellow flashing light that goes on every 5 secs.I made sure that it was installed correctly and tried resetting the timer by pressing + and - o
Yellow flashing light? Did you get any picture? Bet, not!
It means: your lamp door interlock is not engaged: did you forget to turn the locking knob? Did you install lamp compartment door? That might be the only issue. Lamp timer blinks 'red", while TV works normally. Reset the timer, it's gone, along with annoying message. Yellow means: interlock or thermal protection is off. Try to repeat lamp installation procedure. then, you'll find out your mistake. don't need to remove the lamp. It would be "red", if lamp won't fire up.
good luck,
Alex.
Dec 06, 2011 | Panasonic Televison & Video
I have a sony kds-r50xbr1 when turn-ed on the stand by light flashes for about a min the goes solid and picture comes on but very dark. replaced lamp . there is no sound from any input and the controls...
Sir try to reset the lamp timer. you should press the "display" button on the remote then "5" then the "volume up key" and power "on" you should do this while the tv is in standby mode. Then press "Jump" 3 times to enter the DE service menu. Your tv will display the total lamp hours. Reset the lamp time by pressing channel 3, then mute, then enter. this will make your lamp hour timer to zero. Good day and best regards.
Aug 21, 2011 | Mitsubishi VS-50609 50" Rear Projection...
I have an lg projection tv model #RU-48SZ40. I needed to change the lamp, when I was done and turned the tv back on...the orange warning light was still lit. I then tried unplugging the tv, pulled the lamp...
What you need is to have the lamp timer reset. To do so, perform the following;
You will need two hands.
With the remote, press and hold down the "mute" button.
Simultaneously press and hold down the "enter" button on the front of the TV.
After about 5 seconds, a box will appear that shows the total number of hours on the lamp. To reset these hours, press the right arrow button on the remote. After doing so, another box will appear with a confirmation question and an icon for which button on the remote to press to reset the lamp hours.
Dec 15, 2010 | LG Televison & Video
I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Jan 23, 2010 | Mitsubishi WD-52628 52" Projection HDTV
I have a Panasonic pt-52lcx65-k. I thought the lamp was gone so i replaced it. Now the tv wont come on at all. Just a orange light flashing. I tried to reset it by holding the volume button and the pip...
Howdy,
Doble check your Lamp Installation, making sure that the Lamp Cover is properly secured. Reset TV by unplugging TV from the wall for 3-4 minutes then plug back in, then turn TV on.
To reset your Panasonic Lamp Time:
ø Press and hold these buttons for (at least) 5 seconds:
ø Volume Down button (on TV Panel).
ø AND ACTION Button (on remote).
As the remote gets older the ACTION button may not respond unless you press the button dead center and not at an angle.
Thanks for using FIXYA, BIG IRISH.
Dec 19, 2009 | Panasonic PT-52LCX65 44" HDTV
Replaced lamp now yellowish orange status light is flashing
Hi,did you close everything up,make sure door cover is closed.Do you hear clicking noises? If you do it could be an issue with the the ballast that the board that powers the lamp.Make sure fans are running ok,dust them out if they are dirty.Also reset lamp timer by unplugging tv wait 5 min and plug it back again.Good luck and God bless you!
Oct 07, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Replaced lamp-orange lights still flash.....lame!
Yes, Turn On TV, press and hold Volume Down button on TV front and Split button on remote at same time for 6 seconds to reset lamp timer in TV.
Sep 19, 2009 | Panasonic PT-43LC14 43" Rear Projection...
HOW do you reset the timer>? the lights on front of the tv flash 3 gree then 2 orange. Says to replace lamp,which I did then reset timer...HOW?
press "menu" button, scroll down to "special features" and press "ok" button, scroll down to "reset lamp timer" and press "ok" button, you will notice the "no" change to "yes" and press "ok" button, you will notice "yes" change to "no", this will reset the lamp timer
Mar 20, 2009 | Vivitek V37655 56" DLP TV
How do I reset the replace lamp message
Do you have a picture? If so the only way to reset this unit is to get a Zenith programmer remote. With this remote you can get into the service menu and reset the lamp timer and that will reset the unit.
Dec 31, 2006 | Zenith D52WLCD 52" Rear Projection...
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
252 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
