Question about Zanussi WJD1667W Front Load Washer / Dryer
Reset i can not reset my wash/dryer all i keep getting is an err message
    Problem Solver:
  • 5 Answers
If this Err message is displayed constantly and the machine refuses to heed your attempts to select any programmes I'm afraid this means contacting the Service Force company who deal in Zanussi appliance spares, user manuals and machine dealings
Here is the contact phone number should you need it.
08705 929 929 www.serviceforce.co.uk
Hope this solves your headaches
Posted on Dec 20, 2008
Err message whatever I press!
Try unplugging the washer, wait about 10 minutes and plug it back in. Maybe this will reboot your washer. Since most new washers are digital and maybe this will help. Good luck
May 13, 2014 | Zanussi ZWD1470W Front Load Washer / Dryer
Shows ERR when it is turned on
Hello, If you can't get it to work, try to do a factory reset.
Turn the unit off, then Hold the PRINT and ESC key down and then Press the power button. KEEP HOLDING THE Print and Esc key down for 2 seconds and then release both of them. You should see a message in the display INT?, Press SET to Reset your printer, or Esc to cancel.
Hope this helps.
Best wishes
Mac =)
Dec 28, 2013 | Casio KL-60 label maker
Washing machine comes up with ERR message
Oct 19, 2017 | Washing Machines
I cannot get the ERR flashing off my screen. I keep pressing the reset button as per my instruction manual but does nothing. Any ideas?
Un-plug the washer and hit the reset and power buttons while it is un-plugged. This should reset the computer.
Mar 01, 2011 | Electrolux Washing Machines
My d80 keeps reading error, i have tried adjusting lense and changing memory cards, don't know what else to try
What is the error message? If it is ERR then ERR message is not a good thing. Read page 132 of the D80 Manual. Also, try a factory reset found on page 129 of the manual. On the left side of the camera is the terminal cover, inside below the USB connector is the reset switch. If that does not work then it will need to go call Nikon digital 1-800-645-6689.
May 02, 2010 | Nikon D80 Digital Camera with 18-135mm...
Err
The ERR message is not a good thing. Read page 132 of the D80 Manual. Also, try a factory reset found on page 129 of the manual. On the left side of the camera is the terminal cover, inside below the USB connector is the reset switch. If that does not work call Nikon digital 1-800-645-6689.
Apr 05, 2010 | Nikon D80 Digital Camera with 18-135mm...
I shot a wedding and got the ERR message 3
Take your manual reset a little further...remove the card and battery...press all the buttons...leave the camera alone for at least 20 minutes...insert the card and then the battery...turn it on. See if that works.
Oct 08, 2009 | Nikon DSLR D90 Digital Camera
1994 lexus ls 400, cd player
Hello I just purchased a 1991 Lexus LS400
I have one of those 6 cd changers and got "err" when I started up the CD.
Here is what I tried and the result
1. I took out the CD,s replaced with new ones and it played but only for a bit, then even the new CD's got the err message
2. I then though maybe dust and/ or dirt so I took out the 6 pack of CD's and blasted compressed air into the unit from a can of computer cleaner compressed air. Lost the err message but then came back
3. Read a few other ideas on the problem and then tried the old hair dryer trick. (I am a long term live a board boater and have brought back may mis-behaving electronic devices that have moisture issues with the hair drier) However the hair drier did not do away with the err message.
4. two more boating tricks I thought of... I wiped down each leaf of the CD pack with rubbing alcohol
and actually got a good deal of dirt off the plastic, finally and probably the solution I sprayed some "wire dryer" a light spray then a mist.( Wire dryer made by Gunk is a spray can of a liguid we used all the time to get cars started in the cold weather, even got a better connection by spraying on battery wires to get the sailboat diesel started with an almost dead battery.)
I Waited a few minutes put back the cd holder and it worked.
It has been about 6 hours and it is still running like a champ.
could have been the combination or just the wire dryer...not very scientific maybe it will help
Jan 12, 2009 | 1993 Lexus Ls 400
Zanussi WJD1667W Front Load Washer / Dryer Logo
386 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
