The message states "doc. cover open and scrolling below it says please remove original from glass close cover. Well there is nothing on copier/printe glass and cover is closed. Please help
Mike [email protected]
thanks you your time and help
SOURCE: doc cover open
Yes there is and I know your problem have a look at the left hinge on lid that you lift to put down an original for copying, it will be breaking apart, the switch is black in that same corner on doc feeder base, as the hinge breaks apart the doc feed lifts in that corner causing "doc cover open" cause that switch no longer gets pushed in when lid is shut
Dodgy repair - tape switch closed, but doc feeder will not work properly/can use glass.
Repair - Easy removal of three screws and replacing 20buck hinge bought from brother dealer...part no.LE8731001 Hinge assy left.
Now that's FIXYA!
SOURCE: Document Cover Open
I had the same problem with mine. Lift the top scanner, and check the hinges on the left. That error message means that the little black sensor on the left next to the hinges is not meeting flat with the unit when closed. Hold the sensor in for a few seconds, and your printer will start working properly.
SOURCE: Back cover open message
I had the same error message. I also tried every compartment... Here's ultimately what my problem/solution was...
I turned the printer around and fully opened the back cover. I found that one of my kids had somehow fed a small piece of paper/cardboard into the printer. When I opened the back cover all the way I could see that obstruction (which I hadn't seen before). Pulled it out, and the error message went away. Works fine now.
SOURCE: copier will not copy
Look for a switch where the door shuts. Either the tab on the door that hits the switch is broken or the switch is loose or broken.
SOURCE: paper jam while printing on BROTHER MFC-420CN all-in-one
You need to reset the printer software.
If you need more help come back.Post /
thumbs / testimonial are
welcome!
