Question about HP Pavilion ZD7360 (PM019UA) PC Notebook
No Display at Boot-up
My hp pavilion zd7360 starts up but there is no display. It makes all the right sounds so it is definitely booted up by just a black display
Here are some suggestions to try. Your display settings may have somehow been changed, or your video card may not be working properly. If it is a display setting problem you can try to attach another known good monitor to the analog video out port of your laptop, turn it on and see what happens. If there is no output to the attached monitor do a hard shut-down by holding down the laptop's power button until it powers off. then turn it on again. With any luck your attached monitor will have a display. You can then go into the "display" settings of the control panel and reset your "settings" tab of the "display" screen. If you are running vista it will be under the "video" screen of the control panel. If this does not work you may need to have the problem assessed by a technician to diagnose your video and screen hardware. Good luck to you.
Posted on Dec 12, 2008
My laptop does not display
switch on press f8, go to safe mode. when its loaded go start - control panel - device manager - disable all yellow flagged drivers by right clicking on them, leaving just display, then boot up again into normal windows and go back into drivers and enable each 1, 1 at a time..
Sep 04, 2013 | HP Pavilion dv6000z Notebook
HP Pavilion G60-120US NoteBook - External Display Problem
hmmm, f4 + function key should do the trick, you might have to press several times to scroll through modes. If that does do the trick, see if you can view bios with external connected on boot.
May 12, 2010 | HP Pavilion G60-120US NoteBook
Hp pavilion dv2000 lights switch on but boot or
Hi
Thank you for your query
Please try the folowing
1) Remove ALL wires and then press and hold the power button in for approx 20 seconds
2) Plug everything back in and then rerty
This may sort the issue out however from what you are descrbing, if there is no boot or display it is highly likely the motherboard and/or the CPU is faulty
I would recommend that you book the PC into a reputable PC repair shop if the above does not work
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 15, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
Pavillion dv9000 screen is gray, with external monitor connected,laptop will only start in safe mode using vista ultimate
Your display drivers could be corrupt.
Boot the machine into safe mode. Right click on Computer and select manage from the sub menu.
When the window pops up select Device Manager.
A device list will populate. When it has look down the list for Display Adapters. Click on the + icon next to Display Adapters to it expands. Right click on the display adapter and select uninstall.
Restart the computer and let it boot in normal mode.
If it boots in normal mode let it detect the Display and install the drivers for it.
I would be a good idea to update the display drivers via the HP support website.
Regards.
Oct 02, 2009 | HP Pavilion dv9000z Notebook
Pavilion dv2125nr won't boot
it could be dead mobo, it's actually the most probable cause of your problem, but there is this thing i've encountered with HP several times already. i know it's a long shot, but i'd like you to try and boot the laptop up after you've removed the DVD-drive. if this works, it's the DVD-drive that's broken, if not, it'll be the mobo...
Jul 01, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
Hp pavilion dv2000 notebook will not boot up
Go to this Hp website for you could have a grapgics chip fault. One way to test is to plug a VGA monitor into the VGA outlet port on the upper left side of you laptop and start it up. If you get a clear display you have a screen problem - next step remove the external monitor and again boot up but in a darkened room to see if your backlight is off - if you can just see the HP logo in the back ground then your backlight has failed or more rightly - the backlight micro switch under your R/H hinge has failed. A cheap fix. If there is no display external or TFT your Nvidia graphics chip has failed. m/board replacement required BUT you may qualify for free m/board replacement under Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} HP Pavilion dv2000/dv6000/dv9000 and Compaq Presario v3000/v6000 Series Notebook PCs - HP Limited Warranty Service Enhancement go to this site below to see if you qualify
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Mar 07, 2009 | HP Pavilion dv2000t Notebook
Laptop is not able to open windows. mine is HP pavilion dv4000 p/n is EP360 UA#ABA- dv4320us
If the laptop boots up press F10 when F10 is displayed on the lower left of display and ensure that the hard drive is selected for first boot. If Windows still doesn,t boot then put the system restore cd/Windows cd in and boot from that.  If the display has nothing make sure that the brightness is not turned down or connect an external monitor. At this point repost to get more info.
Oct 25, 2008 | HP Computers & Internet
DV9205eu display problem
HP has identified a hardware issue with certain HP Pavilion dv2000/dv6000/dv9000 and Compaq Presario V3000/V6000 series notebook PCs, and has also released a new BIOS for these notebook PCs, version F.39 for dv2000/V3000, and version F.3D for dv6000/dv9000/V6000.
Click HERE to update your BIOS
May 03, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion ZD7360 (PM019UA) PC Notebook Logo
65 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
