Question about Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist
Windward 11 ceiling fan light doesn't work
Tried tube and remote from different unit (same model) they didn't work. Suspect a bad ballast but don't know where to buy one.
5 Suggested Answers
  • 10 Answers
SOURCE: Hampton Bay Ceiling Fan Windward II
There is a 4 position (dip) switch on both the fan housing and the remote. Make sure these switches are set exactly the same and the remote will control the light and fan separately. If not, the remote may be getting interference on the preset frequency - try CHANGING the dip switches to a different setting and the remote should work.
Posted on Oct 24, 2008
  • 75 Answers
SOURCE: lost screws to attach fan blades on ceiling fan
This is not a 'promo' for Home Depot but you will find the screws there that you need.
You will need 15 screws, with an 'unfinished' appearance, for the attachment of the five blades to the arms, and 10 screws that have a smooth rounded finish to attach the arms to the motor housing. If they do not have it in stock they can order ot for you.
If you have an electrical fan store in your area you should be able to find the items there as well.
If you have an old discarded ceiling fan, take the screws out of it and try them on your current fan, they should work.
Good luck. :)
Posted on Apr 26, 2009
macdirk
  • 116 Answers
SOURCE: Do I need to oil
No the bearings are sealed, and not designed to lubricate. They can go bad, and if they do it is possible to remove the seals and re-oil/grease them. Sometimes this helps a little but not always. If you try to lubricate them without disassembling the fan, pulling the bearings, remove the seals, most likely whatever you try and squirt in their will just attract dirts and make things worse. getting to the bearings, usually means taking things apart that were not meant to come apart. So, the short answer is usually if they go bad the fan is shot. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave good thumb rating if you found this helpful. Thanks, and good Luck!
Posted on Oct 02, 2010
jharvey572
  • 447 Answers
SOURCE: I have a Hampton Bay Windward II ceiling fan. Fan
sounds like there is a lose or broken conection from were the feed to the balast slits from the main fan conection try rewireing from the live imput to the balast see if that solves it.
Posted on Jul 30, 2011
Instalation diagran for windward II speed control unit
I thought this fan comes with a remote. You can't use both.
Aug 03, 2014 | Hampton Bay 54 in. Windward II Brushed...
Www gpwarranty com
for the Problem with Hampton Bay 54 in. Windward II Brushed Steel Ceiling Fan check the manual
http://lightingworldbay.com/windward-iv-52-indoor-brushed-ceiling-fan-manual/
Apr 25, 2013 | Hampton Bay 54 in. Windward II Brushed...
CEILING FAN WORKS,BUT REMOTE ONLY WORKS THE FAN SECTION, WILL NOT DIM LIGHTS NOR TURN OFF LIGHTS ONLY SO WE CAN USE FAN ONLY. WHAT DO WE HAVE TO DO?
Fist, make sure the bulbs are good. Check in another fixture to verify that they indeed work. Since the remote works the fan, dead batteries can be ruled out. The problem will be confined to either a bad receiver in the fixture, or a bad remote.
Since Hampton Bay is a line carried by Home Depot, you may have some luck bringing your remote to HD and trying it out on the display units. You may need to try different address settings on the remote to find one that works if you don't get results the first time. This is usually several two position switches often called "DIP Switches". Change the positions of them one at a time until you find one that works. Try to control a fan first. Once you find a fan the reacts to the commands from the remote, try to control the light. If the light doesn't work - the remote has a bad transmitter or light switch control. You could attempt to disassemble the switch, but most don't have parts that look different when they're bad. You'll probably have to replace the remote.
If the lights work, then the problem is with your fixture. You can remove or simply bypass the radio controller in the fixture and install an after market receiver and remote to control it again. These are sold at Home Depot and work with any paddle fan.
I hope this helps & good luck!
Oct 26, 2011 | Hampton Bay 48670 Flemish Pewter Finish...
I have a Hampton Bay Windward II ceiling fan. Fan works fine but fluorescent light doesn't. Have done some troubleshooting. Obviously 120V input is OK otherwise fan wouldn't work. Wires to the...
Jul 30, 2011 | Hampton Bay 46056 Callaway II Ceiling Fan
Can't figure out how to reverse the Hampton fan with the remote
I have the Hampton Bay Windward II Ceiling Fan SKU 523-127. I have replaced various parts over the years including the ballast, light shade, 9" 30 Watt Circline bulb and the remote.
Hampton Bay Windward II Ceiling Fan SKU 523-127 was sold by Home Depot, and manufactured by King of Fans.
King of Fans website is: http://www.kingoffans.com
This fan can be seen by clicking on Products --> Ceiling Fans --> Click on page 9 (at the bottom of the webpage) then click on the Windward II fan picture, then you will be able to click on Download Owner's Guide.
Mar 11, 2009 | Dryers
Windworld III has mind of its own -- light comes on any time it likes fan changes speed
This sounds like one of the most common problems with Hampton Bay's remote-contolled fans...either the transmitter (remote control) or the receiver (mounted in the fan, typically inside the ceiling canopy) has gone haywire. A circuit has blown or something is short-circuited, and it has a mind of it's own. The only fix is to replace the receiver and transmitter, which are relatively cheap and sold as a pair at your local Home Depot and Lowes.
Hope that helps! If you ave any other questions, feel free to ask!
Jun 14, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Jun 11, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton Bay Fan 55295 remote control
I have the Hampton Bay Windward II Ceiling Fan SKU 523-127. I have replaced various parts over the years including the ballast, light shade, 9" 30-Watt Circline bulb and the remote.
This fan can be seen by clicking on Products --> Ceiling Fans --> Click on page 9 (at the bottom of the webpage) then click on the Windward II fan you will be able to get to the needed additional information.
After downloading and reviewing my fan's Owner's Guide, and reviewing the online FAQs, I called 1-800-330-3267, concisely described the problem, and ordered the parts needed with only the fan name and SKU.
I and am about to order more parts after suffering a power surge (The needed info was in the FAQs). My experience is great customer service and speedy delivery of the needed parts.
One of their FAQ's answers the question:
Where can I get parts for my ceiling fan?
You may call customer service at 1-800-330-3267 on Monday through Friday EST. When you call please have your UPC code available. If you do not have your owners manual, you may look on the top of the fan where you will see a silver or gold sticker. There you will find a UL number beginning with the letter E and located under the UL number is the UPC code. The UPC code consists of 12 numerical digits. From that information, the customer service representative will be able to determine if you are calling the correct company and determine the make and model of your product. If it is determined you are calling the wrong company, you will be given the correct number to call.
Jan 25, 2008 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist Logo
153 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
