Question about Refrigerators
I am replacing the relay switch and overload switch for this kenmore frig/freezer. model 25358682890. the capacitor has two wires. one fits the overload component. do they both attach to this or does one attach to the relay on the opposite side from the power wire(red) and the blue wire?
    Sergeant:
    Champion:
  • 291 Answers
Your start device has 2 wires connect to it and the cap slides into it unless you have a relay and over load and in that case one wire goes to each
Posted on Dec 12, 2008
We have a bottom freezer refrigerator-kenmore elite 795.7877-not cooling frig or freezer-makes a clicking sound every once in a while can't get no one to come for 3 days b/c of holiday weekend. Any...
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
It does a lot of clicking (trying to start over and over again)
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one. (110 v)
If you still have trouble Go Here:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Sep 03, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Compressor does not want to start.
If the compressor will not kick on what you have is either a bad compressor or a bad starting device. Generally the unit will try and start and after 8 seconds or so you will hear a loud tick. That indicates the relay is bad. If the compressor is bad it will usually make a loud humming noise.
The start device is plugged into the side of the compressor. Unplug the frig. You can simply take off the wires to the start device (remember where they go!!!!!) and pull it off. You have two piece, the overload and the relay. The relay is the piece that is most likely the problem. Some machines will have these put together in a white plastic block. You can shake this entire piece and if you hear loud rattling it is broken. Sometimes the relay is visibly burned and blacked where it plugs into the compressor. Anyway, if you do not have this white plastic relay/overload combo, the relay is a brown square shaped plastic piece. Shake it and see if you hear rattling. If not, chances are very good the relay is ok, and the compressor is locked up.
Compressor changes are expensive and unless the frig is extremely nice and cost a pretty penny, they aren't worth fixing. Relays and overloads should not break $100 for the parts, and any tech should be able to change one in under 10 minutes. So if it's a relay fix that puppy! good luck :D
P.S. In a RARE occasion the frig may use a capacitor, and the capacitor may be bad. The only way to check is with a multimeter or replace the capacitor and see if it fixed it. This is highly unlikely and therefore not checking from the beginning.
May 29, 2010 | Kenmore 72232 / 72234 / 72239 Bottom...
We have a Kenmore side by side model 52584201. Yesterday the freezer side stopped working. The refrigerator still cools. I have checked all the vents and cleaned around the vent at the bottom. Any ideas,...
FREEZER IS WHERE THE FRIG GET'S COLD AIR. IF BY NOW YOU HAVE FOUND THAT THE FRIG IS INOPERATIVE. CHECK THE OVERLOAD RELAY ON COMPRESSOR. HAD TO REPLACE ONE ON MINE PART WAS ABOUT $60
Feb 26, 2010 | Kenmore 52582 / 52584
Kenmore frig freezer will go to 20 degrees and stay there
sounds like either the compressor is out or the relay that starts the compressor is out. I would try replacing the relay/overload on the compressor and hope for the best. if you have a continuity tester then check from each of the 3 posts sticking out of the side of the compressor that the relay/overload push on to fo one of the copper pipes coming off the compressor..no continuity is good if you get continuity then the compressor is shorted and ruined
Jun 13, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore Model #253-64802400
IT SOUND AS THOUGH THE COMPRESSOR IS NOT RUNNING. IF IT IS AND YOU HAVE NO COOLING, THEN YOU HAVE A SEALED SYSTEM PROBLEM AND WILL NEED A SERVICE TECH. IF IT IS NOT RUNNING, UNPLUG IT AND REMOVE THE RELAY AND OVERLOAD FROM THE SIDE OF THE COMPRESSOR. MAKE NOTE OF WHERE THE WIRES CONNECT AND REMOVE THEM. NEXT, SHAKE THE RELAY AND LISTEN FOR WHAT SOUNDS LIKE A BUNCH OF SMALL ROCKS IN IT. IF YOU HEAR THIS, THE CERAMIC DISC IN THE RELAY IS BLOWN AND YOU NEED A NEW ONE. IT IS POSSIBLE FOR THE POWER SURGES TO BLOW THESE DISCS.
Jan 29, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Frig and freezer not cooling
it is possible that a start relay has gone bad but more likely is that the compressor has seized up. if the unit is under 5 years old most likely the comp will be under warranty from sears. peyton
Jan 19, 2009 | Kenmore 73503 Stainless Steel Bottom...
Freezer and frig is not working
I would start by pulling it out, removing the lower back panel, and see if the compressor is running. It is the black ball on the left side. If it is not running, check voltage at the two wires at the compressor. If there is voltage, try a new overload/relay kit. If there is no voltage, try a thermostat. If the compressor is running, check the evaporator behind the rear freezer panel to see if it is frozen solid, if it is, replace the defrost timer.
Oct 26, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
Relay in kenmore frig
Yes it can. a short in the windings will cause a relay to fail. let me know if you want to make sure it is a compressor
May 26, 2008 | Kenmore Refrigerators
Kenmore 596.755 23400 problem with freezer
You can try to replace the relay and overload but on this model usually the compressors go bad. Call sears to check the warranty. The compressor should have a five year warranty.
May 07, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore frig will not cool
if compressor is hot that means comp- is trying to start but the relay /overload is bad allow comp to cool down unplug from wall and replace with exact type 1/2hp 1/4hp 1/3hp etc make sure all wireing is correct and unplug before starting that model may or may not have a run or start capacitor replace it also..
Dec 31, 2007 | Refrigerators
Refrigerators Logo
163 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
