Question about IBM ThinkPad T30 2366 Notebook
IBM T30, turns on now and then
My T30 will not turn on all the time. When the button is pushed all the lights turn on except for the hard drive. Then the laptop turns off. After trying several times the the hard drive light turns on with all the other lights and the laptop works fine. Any help will be appreciated.
Also, there is a rubber button on the bottom of the laptop, I forgot what that is for.
Thank you
  • 4 more comments
  • bigfish1 Dec 15, 2008
    I have almost the same problem, but my computer freezes sometimes too. It freezes in BIOS setup too.
    I think it might be the CMOS battery. It's under the main battery.
  • fib_football Dec 17, 2008
    I had the same problem that went on for months and then one day the machine won't even power up anymore. All the lights light up and then go off just the "z" indicator stays on but the hard drive never starts and nothing boots up.
  • Anonymous Dec 29, 2008
    It asking me password to get in IBM Bios Setup utility
  • Fumetsu Jan 16, 2009
    I, too, have this problem. Upon turning on my laptop, the screen lightly flashes, all the key lights come on, then the screen lies dim and eventually fades into vertical color bars. I'm pretty pissed.
  • rhmaida Jan 17, 2009
    My IBM T30 won't turn on, and I can't access my bios. The fan is working, hard drive is spinning, but nothing displays.
  • barold Feb 18, 2009
    T30 used to run fine - but would freeze during operation (completely, no keyboard or os access, have to do the hard power down). Now it won't even get to the bios screen on power up; lights for batt go on, hd spinning and cooling fan running, but nothing else happens
    Champion:
  • 203 Answers
Look for bios update, and for that buton in your back laptop is for reseting the laptop at factory seting (default seting) . for that with hard disk problem , put the hard disck on a external hard drive reader and see if is still ok, or maybe the hard is full with data, For bios password  try to find aplication KILLCMOS  and reset the password.AND for Fumestsu Try to start your laptop without baterry in just with cable power.
Posted on Jan 16, 2009
I have a IBM thinkpad t30 the on/off button every time I try to turn the laptop on it takes a long time for the computer to come on. Whats wrong ?
This is in laptop terms an older laptop. i recall it was fitted with a 20 or 40GB hard drive and with 256mb of ram and unless you have since upgraded it, it is possible the hard drive is filling up or it is beginning to fail through age.
Things you can try:
  • See how much space is availible on the hard drive, to work effectively there should be at least 2 gb of space that windows can use as a swap file
  • In My computer / C drive/ properties/ tools, defragment the hard drive and then run a disc cleanup, see how much space is fred and if it runs faster after the hard drive has been decluttered and defragmented.
  • If you still have problems / the hard drive is filling up, move some files to a seperate location such as an external drive to free up space.
  • If after this, you still get a slow start up, download a copy of HDD Tune (the free version) and do a health check on your hard drive, any bad secorrs or RSC errors means you should consider replacing the drive asap.
  • Finally, consider upgrading the RAM
Jan 22, 2011 | IBM ThinkPad T30 2366 Notebook
IBM thinkpad T30.The power button turned on then nothing boot up power LED light is on.
Remove battery and power for a minit, install it again, power up mains and try again. This helpe me here in Paraguay several times.
Saludos Wolfgang
Dec 11, 2009 | IBM ThinkPad T30 2366 Notebook
IBM Thinkpad T30 wont boot up
You have faulty RAM modules. Reseat your RAM modules, to make sure they make proper connection. If this doesn't work take them to your friendly computer shop and ask them to test them for you.
Apr 29, 2009 | Lenovo ThinkPad R51
T30 Wireless switch off
use Fn and the F5 buttons together
Dec 08, 2008 | IBM ThinkPad T30 2366 Notebook
How to get rid of numberlock in ibm thinkpad t30
Hi Ritadeng,
On the Thinkpad T30, the number lock key can be turned on or off by pressing the shift-key and the scroll-lock key. The scroll lock button is found at the top of the keyboard between the PrtSc button and the Pause button.
You should see the light with the arrow and the number 1 inside (just above the F7 key) turn on and off when you press this.
Hope this helps!
David
Nov 18, 2008 | IBM ThinkPad T30 2366 Notebook
T30 does not turn on..video is blank
This could be a couple of different things. First, remove the battery and start with AC power only. Sometime batteries will malfunction and cause this. Second, remove the memory and try starting with one chip in, then change out the chips and try. And third, this could be that the hard drive is begging to fail. If the hard drive doesn't initialize and the machine can't read it, then it will appear to be on without running. Usually it's with the small electric motor in the drive. Next time it doesn't start, listen to see if you can hear the drive spinning, if you can't, then it's the hard drive. Run through these one at a time, if you find that one helps then you don't need to follow on down the list.
Jul 18, 2008 | IBM ThinkPad T30 2366 Notebook
T30 won't turn on
It might have some statical lockup
Here is the steps that you may try
Disconnect the AC adaptor, take the battery out, press the power button and hold about 7 second. Connect the AC adaptor and turn the unit on. If issue persists please post for further diagnostic.
Good Luck
Jan 27, 2008 | IBM ThinkPad T30 2366 Notebook
IBM T30 Start Up Problem
see website laptoprepair101.com, sev eral ways to test this problem
Mar 28, 2007 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T30 2366 Notebook Logo
654 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
