Question about Sony PlayStation 2 (PS2) Console
My PS2 fell on the floor!
My PS2 fell on the floor, and now the tray that reads the disc is jammed. its open but it won't close all the way! and it won't open all the way i don't know what to do!!!!!
  • michelle lacy
    michelle lacy Dec 12, 2008
    my playstation fell on the floor, now i can only play it for a lilttle while before a red blinking light comes on. i dont know what to do is this fixable!!!?
  • jbond81237 Dec 13, 2008
    playstation wont close blue light comes on but it wobt close all the way
  • 116 Answers
Use to have this problem alot, there is a track on the under side of the tray a little plastic pin follows, it has jumped the track, do not force it closed or you could break the track, hopefully it isnt broken already. Have you ever opened a ps2 before?
Posted on Dec 12, 2008
The disk tray wont stay closed the open/close button flashes and opens again.
It seems there might be something jamming your disc drive from completely going in, or your disc drive has fallen off the track and might need to be realigned.
Jan 20, 2011 | Sony PlayStation 2 (PS2) Console
The console works (comes on , tray opens and closes,) after putting disc in tray and closing it makes a sound like disc reading then stops ,nothing on screen ,,Is this a replace the laser job??
its not dealing with the laser. your cord inside connecting your ps2 top cover to your tray might be lose or not connecting like it should. take apart the ps2 and see if it is connected. if not place it back inside the tray slot inside of the ps2.
Dec 15, 2009 | Sony PlayStation 2 (PS2) Console
PS2 HELP WANTED!!!!!!!
my friend had the same problem what he had to do was keep opening and closing the disc tray untill the 'reading disc' shows up and stays up but he got really anoyed with doing this so he got a new one shortly after this the ps3 came out...
Jun 17, 2009 | Sony PlayStation 2 Slimline Console
PS2 was dropped, now disc won't spin and can't be read.
I just looked at a friend's PS2. Same story, tripped over cord, unit fell to floor. Unit powers up and sys. config. screen comes on but the drive didn't seem to be spinning up. Opened the case and found that the shaft of the drive motor for the laser tray had popped out of it's centering retainer ( little black bushing/holder). With the top off the unit, looking at the unit from the front, on the right side in the rear corner you'll see the motor. The worm shaft (bronze colored rod) runs towards the front of the unit. Where it ends it should sit centered in a black plastic holder, if it's off to the side a little pressure will pop it back in. Put the cover back on, and power it up, you should hear the drive spinning up. If it does you should be set. Hope this helps.
Mar 28, 2009 | Sony PlayStation 2 (PS2) Console
PS2
There may be many problem that have occurred to make this happen, here is a list of the three most common:
  1. You MAY have a disc jammed into the PS2, making it impossible to open (and/or) close. This could have happened by someone accidentally putting one disc right on top of a disc that is in the PS2, and not taking the other game, movie, etc., out. How to fix? Best Buy, Circuit City. Another way this could have happened is: an earthquake, flood, SOMETHING, may have happened that made a disc fall out of the tray (while INSIDE of the PS2) and jam it up, to fix this, you have to do the same as the first option.
  2. The motor is broken, this is pretty self explanatory, the motor that makes the disc drive open and close is broken, solution? Same as before.
  3. Your PS2 has reached it's prime, and gone over the hill, sorry buddy. :(
I hope you found this helpful, sincerely- animation508 (youtube username)
Sep 23, 2008 | Sony PlayStation 2 (PS2) Console
Jammed PS2 DISC TRAY
If your ps2 is in the upright position this could be the problem as the disc will not sit propeely and rattle around and cause scratches, the best way to have it is in the downright position as the disc tray will be flat and wont slouch down, try turning it on and pressing the close switch.
Jul 03, 2008 | Sony PlayStation 2 (PS2) Console
System dropped
there will be a problem with the circuitry see if you can find a gaming repair shop, they will have it up and running in no time
Apr 13, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 won't read disc
how to clean my ps2 disc i used alchol
Mar 16, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 will not read disc
Check your disk for scratches fingerprints ect,,
if thats all good step two
try useing a lens cleaner
****(( tip and trick for scratched disks ))****
a crayon rubbed on the disk then wiped off with a lint free cloth
no t-shirts dish towels that will just add more scratches
remember start at the center wipeing out to the edge.
if none of that works you may have a lens problem
Jan 04, 2008 | Sony PlayStation 2 (PS2) Console
Disc error
the best to do is the basics open your ps2 and inside open the disc box ( you can simply identify it it is the place where the disc is played) get a cotton buds and wipe gently and smoothly the lens. If
still it won't work go to your nearest repair man for further advice.
Oct 20, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
127 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
