Question about Garmin GPS
This appears to be the solution How do I see the rest of the solution? Garmin Nuvi 660 GPS Receiver Problem: Garmin Nuvi GPS won't acquire satellites Solution by: wingflinger (1 solutions) There is a known hardware bug in the Garmin 600 series relating to the detection of the connection of an external antenna. The GPS is supposed to do this automatically and when it detects an external...
    Master:
  • 623 Answers
In order to get a "fix" on it's current location your GPS needs to download data from three or four GPS satellites. Typically, this should happen in about two minutes or less from the time you first power on the unit. This can take a little bit longer if its been a while since you used the GPS or if you have travelled a long way since you last turned the unit on. Your Garmin 600 should be acquiring satellites and providing a location report pretty quickly after power up.
Once thing that can affect the performance is whether not not the GPS has a clear view of the sky. If you are operating indoors, in a car, or anywhere that has a lot of obstructions (in a city with tall buildings or a forested area with a lot of trees) these things can block your GPS's view of the sky and prevent it from receiving data from one or more satellites. This can cause the GPS to be unable to provide a lock on its current location or to take a very long time in locking on.
Posted on Dec 12, 2008
  • 275 Answers
Just connect your Garmin GPS to your computer, run WebUpdater, and follow the screen prompts. After confirming that you want to perform an update, WebUpdater will download that update for you and install it on your GPS. WebUpdater always checks for its own update first before performing a unit update. Unlike previous versions, you no longer need to download Web Updater everytime you upgrade your unit software. Once installed, simply run it from your computer —no need to download anything else yourself!
download the latest version of WebUpdater software
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
  • 734 Answers
Please discribe your problem in detail....
  • Garmin Master
  • 13,433 Answers
Update the unit software, it might fix the problem.
http://www8.garmin.com/products/webupdater/
My nuvi is fully charged, the touch screen is fine, it has the correct time etc, but it won't acquire satelite signals - why?? help!!
There is a component that is well known for failing in the flip-up antenna/GPS receiver. Please see this link for more info on this problem. We can repair your unit for you.
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Sep 18, 2011 | Garmin Nuvi 660 GPS Receiver
Receiver Garmin nuvi not acquire satellites i lost satellites signal
Common problem. Please see this link:
- Jim
Aug 21, 2011 | Garmin Nuvi 660 GPS Receiver
Not able to acquire satellite. Garmin stays on
The flip-up internal antenna/GPS receiver is defective and needs repaired/replaced. Please see this link fo rmore info:
- Jim
Sep 15, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 cannot acquire satellites
Hi I had this problem and its an antenna fault, give garmin a call and see if yours is still under warranty, if it is they will tell you to take it back to the retailor who will call garmin for a RA Number and they will replace it there and then. If your warranty has run out then call garmin to ask about repairs
Best Of Luck
Jul 19, 2009 | Garmin Nuvi 660 GPS Receiver
My nuvi 660 all it says is acquiring satellites
Try reuptdating your GPS or reset it it might be a bad patch.
Jun 23, 2009 | Garmin Nuvi 660 GPS Receiver
Acquiring satellites
my friend has the same unit his will only acquire satellites when unit is plugged in the cigarrette lighter
Jan 24, 2009 | Garmin nuvi 200W GPS Receiver
Garmin 660
If you start it up and are located in the place where the pin code was set, then the unit should unlock once it acquires sufficient satellite signals.
Sep 05, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi takes a long time to Acquire satellite
No. 98% of the time it took 45-56 seonds for your NUVI 660. Thats the compagny set up time acquisition and it did very well.
Be sur you had your flip antenna parallel to earth surface.
660 has THE BEST SIRF Chipset for acquiring satellite.
I had 2 NUVI 660 since 2 years. It work much better than those new 7xx series who it really took 2-3 minutes to acquire satellite.
Be sure you update your version to the last one.
----> https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00540-00&cID=134&pID=400
Best regards
Jan 12, 2008 | Garmin Nuvi 660 GPS Receiver
GPS Logo
52 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
