Question about Jenn-Air JES9800A Electric Kitchen Range
My jenn-air range/stove states f1-1 - Jenn-Air JES9800A Electric Kitchen Range
  • omarie2008 Dec 31, 2008
    mine is an amana downdraft electric with the same F 1 message
  • 15,935 Answers
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
F7 code on Jenn air stove
Here is a link that has fault codes for Jenn Air stoves. Hope tis helps!
Jennair Fault Codes AppliancePartsPros com
Mar 09, 2015 | Jenn-Air Kitchen Ranges
What des error cde F1 mean on a Jenn-Air D156 drp-in range
'Newer Style' Range/Stove/Oven Fault Codes Failure
Condition Check/Repair F1 Power to element relay energized during time of day display Wiring harness shorted or change power relay board (PRB)
Note: for double ovens, change second oven board
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad)
Mar 22, 2010 | Food Processors
Does anyone know where i can get an instruction on how to replace the touchpad on a Jenn Air JGS8850BDS gas range/stove?
I just replaced the panel overlay on my stove and that did fix the problem (of the 3,6,9 buttons not working). I found the part for under $110 on line and replaced it myself.
Nov 05, 2009 | Jenn-Air JGS8850BDS Stainless steel Gas...
How can a Jenn-Air down draft stove be vented out the roof ?
Yes , its much more labor intense but it can be done by venting it up through the wall then through the attic over to the side vents. Make sure to get flexable duct to pull up through the wall.
Apr 10, 2009 | Jenn-Air JDS9860A Dual Fuel (Electric and...
Older jenn-air stove
on the front panel does it have a button that says CLOCK if so press that then with + button see if setting changes if so when it gets to the correct time stop and press clock again .
Oct 25, 2017 | Jenn-Air SVE47100 Slide-In Electric...
How do you convert the oven to lp gas on ge xl44 range
if this is a new stove need to change the pin in the regulator ,
then need to replace the stove top orifices from gas to l.p.
check under the stove for pieces they tape them under there by the regulator -- that how i found mine under my new jenn air
check the stove companies web site for a users manual also
Feb 19, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Tried to clean top of jenn air stove
If this is a gas stove, you've shorted out the ignitor circuit.  If it is may have gotten some of your cleaner into one of the controls.  See what doesn't work and trace from there.
Dec 14, 2008 | Jenn-Air JGR8775QD Gas Kitchen Range
Jenn-Air JES9800A Electric Kitchen Range Logo
188 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
