Question about GE (PSS26MSRSS) Side by Side Refrigerator
Wont dispense water
Ice maker works fine and dispenses. Water is running to filter but will not dispense out of door.
  • 7 more comments
  • navarrington Dec 14, 2008
    Have the same problem but won't dispense water or ice, changed the panel but now no light now on panel.
  • sgrell Dec 15, 2008
    GE side-by-side creates ice, but water will not dispense.
  • jmbarry2679 Dec 15, 2008
    I have the same problem. Ice makers works, water dispenser does not. Light in dispenser door works. Any ideas?
  • kimsheldon Dec 17, 2008
    Same problem ice maker works light works no water despenses.
  • Anonymous Dec 19, 2008
    Ice, no water. When I try for water I do hear  a clicking sound. Frozen reservoir? If so, where is it located?
  • Anonymous Dec 20, 2008
    My refrigerator will not disense water
  • Anonymous Dec 24, 2008
    I replaced my water filter yesterday and now the water dispenser doesn't work
    I have the same problem. I found out that the last 2-3 inches of water is freezing in the line. I have to defrost it with a hair drier, that takes 30-45 min. It is a pain in the ****. GE has a poor design!!!
  • Anonymous Dec 27, 2008
    Our side by side produces ice, but will not dispense ice or water?
I spent an hour looking at many of the suggestions posted here and at other sites. I tried the easiest first and it worked so I am sharing it on all the sites that were helpful. Turn down the temperature of both the freezer and the refrigerator. I then tried holding the door switch closed and repeatedly pressing the lever to dispense water. After a few minutes I walked away for 30 minutes leaving door closed. WHen I returned the water flowed perfectly. good luck
Posted on Sep 18, 2010
Did you check the pump at the bottom of the fridge ,and also the solenoid. valve to release the water ,does it click when you depress glass against sensor in dispersal area
Posted on Dec 16, 2008
Filtered water will not dispense
If your ice maker is working your filter is fine. You need to check the solenoid valve that feeds the water dispenser. You should have 2 of them on the water line. One that feeds ice maker and one that feeds the water dispenser. That is most likely your problem
Jan 21, 2018 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker doesn't work. changed filter. light on ice maker door still on.
You need probably to change the dispenser solenoids which swith water on dispenser
Apr 05, 2008 | Jenn-Air JCD2389G Side by Side...
Ice maker wont fill.water dispenser on door is working
Could be the filter. Can you bypass the filter? How about the incoming water line. Is there presure there?
Aug 26, 2009 | Frigidaire FRS26R4A Side by Side...
Water despenser
The water dispensing valve may not be functioning, if the valve buzzes or hums when the water dispenser is pressed the valve may be mechanically deficient, if there is no sound whatsoever the switch for the dispenser,the dispensing valve coil or its electrical connections may have failed.
May 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Intermittantly no water from inside water dispenser
I just started having the problem of no water dispensing from the in-door dispenser. I checked the operating manual and it suggested that the refridge temp may be set too low thus freezing up the water line. I have set the temp higher and we will see if that helps. I do not think that will do it because as you too note, the ice maker works fine. If the filter were an issue the ice maker would not refill either.
illinoisjas
Apr 19, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
Ice dispenser wont work....ice maker works
Need to check and see if the water filter is stop up ,if you don't have a filter it I would start with water value at the bottom .
Mar 14, 2009 | Refrigerators
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
131 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
