Question about GE Spacemaker JVM1640SJ Microwave Oven
We have the F3 code
We have turned off the main breaker to see if it would re-set----No it did not. What is the F3 code mean? Can we fix this problem??
  • GE Master
  • 8,929 Answers
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Dec 13, 2008
KitchenAid KHMS155LSS when press "bake potato" button,start flashing error F3
Question: Error Code - Oven - F3 Error Code - F3 E0 Answer Product Symptom:
Error Code/Message - Oven - F3 Error Code - F3 E0
Control displaying F3 E0:
There may be a problem with the Oven Temperature Sensor, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
Jul 31, 2014 | KitchenAid KHMS155LSS 1000 Watts Microwave...
F3 code
An F3 error code indicates that the keypad for the control panel is bad or has a short. This will cause the microwave to beep continuously after the set clock message appears.
On many models of microwave oven means a problem with the touch panel, (tact switches).
Replace the switch panel to fix the fault.
Hope this helps.
Aug 10, 2011 | General Electric Microwave Oven
Get F3 warning on panel. where are the codes located so i can see what the problem is, thank you JOHN BOMSA
Error code F3 on many models of microwave oven means a problem with the touch panel, (tact switches).
Hope this helps.
Feb 01, 2011 | General Electric PEB1590SMSS Stainless...
Hi, The microwavw heats up and F3 shows on the LCD and wont work until after a while. Thanks
Make and odel please.
Hope this helps.
Jan 18, 2011 | Microwave Ovens
My kitchenaide convection oven is displaying the E1 F4 error.
KitchenAid ovens are popular for their classic design and simple user interface. When a problem occurs in the function of a KitchenAid oven, an error code will display on the clock as soon as the malfunction registers in the oven's memory. Each code corresponds to a particular type of malfunction. Most can be corrected by disconnecting the power supply for one minute and then restarting. If the code persists, either replace the indicated part or contact a service center. F0/F1
  • The F0 and F1 codes refer to electrical issues. If the code appears as only two digits, the problem is a transistor failure, so you must replace the electronic range control (ERC). If the code displays four digits, it will read F0-E0, which indicates a failure switching from analog to digital, or F1-E1, which refers to a safety flip-flop. Both problems require the replacement of the ERC.
  • F2/F3/F4
  • The F2, F3 and F4 codes refer to problems with the oven temperature sensor or the keypad. If you see the two-digit F2 code, it means your keypad has shorted and the ERC must be replaced. The four-digit F2-E0 code means that the oven temperature is too high. Test the door lock and the relay operation, and correct as necessary. A two-digit F3 code means an open temperature sensor or thermal fuse, so those parts must be replaced. A four-digit F3-E0, F3-E1, F3-E2 or F3-E3 code or a two-digit F4 code means that either the oven is registering as too hot or the temperature sensor has shorted. Either way, the oven temperature sensor must be replaced.
  • Nov 22, 2010 | Microwave Ovens
    It has an f3 code on it what ledoes it mean
    F3 means fault code number 3, I think this is Power Supply, or Magnetron.
    Feb 09, 2010 | Samsung MW1030WA Microwave Oven
    F3 error code ge microwave
    No, unfortunately the membrane keypad is not available as a separate part on this model.
    You would have to order the control panel frame, which comes with a new keypad already installed.
    The part number is WB07X10883 and you can get it for $86.82 here.
    In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
    At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
    Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
    Some connectors on the relays may have a lock:
    Nov 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    What does f3 mean in the window of a GE microwave
    Code F3 is for 'shorted touch pad panel'.
    However, this is not always the case.
    Try the following;
    Press (and hold) the Clear/Power button to reset the microwave and turned it off. Press it again to turn the microwave back on. set the clock. If the touch pach panel is okey, your microwave should work with no problem.
    Oct 10, 2009 | GE Microwave Ovens
    I have a GE spacemaker microwave I got the F3 code we have turned off the elec. breaker to try to see if it would re-set. It does not------What is the F3 code and can we fix it?
    William E. Miller
    prototech@usa.net
    Dec 12, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    F3 Error Message
    It needs a new key pad it is shorted the ge website has a list of error codes f3 is the keypad
    Jan 31, 2008 | GE Advantium 120 Convection/Microwave Oven
    GE Spacemaker JVM1640SJ Microwave Oven Logo
    117 people viewed this question
    Top GE Microwave Ovens Experts
    William Miller
    William Miller
    D. E. Hev
     Larry
    Larry
    Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
