Question about GE JVM1640 Microwave Oven
Model JVM1640CJ03 Why is my turntable making a thumping sound? There is no sound when turntable is off.
  • GE Master
  • 9,156 Answers
If the turntable tray is positioned and seated properly, it is probably a failing turntable motor. You can find usually helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383 If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Mar 09, 2007
To check if it is the turntable, take all that out of oven. Put a tiny microwave safe dish in and see if it will heat up some water.
Probably IS the turntable if there is no thumping in this experiment.
Posted on Dec 06, 2007
SOURCE:
GE Spacemaker XL1800 Microwave
see for the turn table obstacle of any screw or something else.
Aug 04, 2008 | Samsung MW1030WA Microwave Oven
GE Profile Spacemaker XL1800 microwave turntable
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
On some, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Oct 28, 2013 | GE WB26X10037 Microwave Stirrer Motor
Ge spacemaker microwave jvm1640cj03 stopped heating. interior always clean. light, timer etc working.
If it stops heating and the other parts of the oven still work, the problem is with the magnetron circuit. If it makes a loud buzzing noise when you try to heat the food, then the magnetron has shorted out. The replacement cost for the magnetron is almost as much as a new oven, so it does not make sense to have it fixed. Sorry.
Apr 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
It suddenly won't heat anymore. Turntable still
depends on make and model could be a capacitor issue or a control panel issue
Jan 14, 2010 | Microwave Ovens
Microwave makes a thumping sound then no heat
sounds like the hi voltage diode or capacitor are intermittant, the thump is the transformer drawing current when the magnetron tube calls for hi voltage to operate, you will see the lights dim slightly every time it cycles the mag tube for heat
Oct 07, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Whirlpool otr microwave
Once i opened up the microwave, I found that some kind of capacitor or something (had two wires going to it) had fell down on top of the fan. I had to rig the plastic mounting bracket and re-attach it to a panel inside. That took care of the rubbing noise. It turned out that some one had unplugged the wire that powered the turntable. That took care of that. it seems to work fine now. Steve
Apr 18, 2009 | Microwave Ovens
The glass dish that goes around - makes a strange noise
You may have a bad motor orplastic coupler.
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
Nov 22, 2008 | Kenmore Microwave Ovens
GE SPACEMAKER MICROWAVE OVEN
Is it a rhythmic thumping, or intermittent, or one thump when it first starts?
If it's rhythmic, it may be a failing turntable motor or stirrer.
If it's a thump just when you hit Start or when the magnetron turns on at the beginning of the cook cycle, it may just be a common noise that they sometimes make due to the magnetic field produced by the high voltage transformer.
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 06, 2007 | Microwave Ovens
GE JVM1640 Microwave Oven Logo
440 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
