Question about HP Officejet 6310 All-In-One InkJet Printer
When I scan a multiple page document, it saves to file as individual pages. I've tried changing all the settings, but still saves individually. Any ideas?
On my software for HP6310 a menu gives me the choice of "add" which will add pages together.
Posted on Dec 24, 2008
Bothers MCF-490CW 4 in 1 || scanner - when scanning multiple pages, what must I do so when I send as an attachment the attachment is one group instead of each individual sheet?
Create a WORD document then paste each images on a page, save the Word document and then send this Word document as an attachment in your e-mail.
If you do net want to send the Word document then you can create a PDF of the Word document and send the PDF file as an attachment.
Jun 06, 2011 | Office Equipment & Supplies
Can't scan multiple pages into single document - reinstalled drivers but still can't - used to be able to. How do I fix this?
http://files.support.epson.com/htmldocs/…
I think this says you need Professional Mode rather than Full Auto Mode.
Under File Save Settings in the Professional Mode, you should see buttons for Add Page / Edit Page / Safe File.
Basically, you keep adding pages then finish.
If you already have multiple .pdf files that you wish to combine, Acrobat Professional (not READER) can do that.
Good luck,
- CarlD
I copied the text but I think you won't be able to see the images here:
4. Select PDF as the file type setting. The current Paper Size, Orientation, Margin, and Compression setting are displayed below it.
5. If you need to change any of the current PDF settings, click the Options button. You see the EPSON PDF Plug-in Settings window:
Select the settings that match your document and click OK. You return to the File Save Settings window.
6. When you are finished selecting file settings, click OK. Epson Scan scans your page and displays this window:
7. If you are scanning only one document page, or you don’t need to edit your pages, click Save File and go to step 10.
If you are scanning multiple pages, click Add page and replace the first page on the document table with the second page and click Scan. Repeat this step for each page in your document. When you are finished, click Edit page and go to step 8.
8. You see the Editing Page window displaying thumbnail images of each scanned page:
If you want to include all the document pages in your PDF file as they currently look, go to step 9.
If you want to delete some of the pages, click the odd pages or even pages icons, or click the individual pages you want to delete. Then click the delete icon to delete them.
If you want to rotate pages, click the pages or use the odd pages, even pages, or all pages icon to select the pages. Then click the left or right rotate icon to rotate them.
Note:
The delete icon is not available when all document pages are selected.
9. When you have finished editing your document pages, click OK. Your document is saved in a PDF file in the location you selected and you return to the EPSON Scan window.
10. Click Close to exit Epson Scan. Source(s): http://files.support.epson.com/htmldocs/…
Aug 22, 2009 | Epson CX8400 All-In-One InkJet Printer
I am using an HP Officejet Pro L7680 all in one. I am trying to scan multiple pages into one document. The list offered by my HP Solution Center for saving scanned documents is .jpg .tif etc. but each...
Well once you have digitized all the documents can they all be converted to PDF?
THen all you need to do is to make sure the titles are in numeric order as page 1 - whatever
Adobe PDF acrobat professional lets you place them all into one doc.
On the left open page options at the top of this menu you can insert after of befor all the rest of the docs just open the lead doc and then add pages to thea you will build a book
Jul 27, 2009 | Office Equipment & Supplies
Can't scan multiple pages into 1 document
Be kind m'53. Maybe you can scan to a folder, then use print setup to compile all the data on one page, if it's not much data. You'll have to do all this with the computer, don't expect the scanner to do that. There is always lots of software out there to do this kind of stuff.
Apr 02, 2009 | Brother MFC 7420 All-In-One Laser Printer
Scanning multiple pages as a single document
The pages you scan in are each individual "pictures" which are very different than the text in the everyday word processing file. What you can do is to make a new word processing document and insert each of the scanned pictures into this new document in order. This will allow you to print all the pages in one job by printing the word processing document. As far as I know there is no way to scan all of the pages into one single file.
Carl
Dec 05, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Ricoh Aficio 2090 Printing config question
You have to scan each one individually. The machine can scan them into a pdf file. Press user tools button. Press the scanner button and check the file format settings for individual files. Select PDF if needed.
Nov 13, 2008 | Office Equipment & Supplies
Scanning 2 page document
Go into the PDS settings and change tab from single page to multiple page.
Jun 11, 2008 | Konica Minolta bizhub C250 All-In-One...
Canon CanoScan LIDE 25
Use the PDF function of the CanoScan Toolbox. On the options screen for a pdf, click the drop down box next to “Save as Type:”. Select “PDF (Multiple Pages)”. This option causes CanoScan to stop after each page is scanned and ask if there is a next page or if you are finished.
May 04, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Scanning documents
Has the machine got a doc feeder if so select twain scanning select doc feeder and the scan it will scan all pages in the feeder and then you should be able to save as one file.
Thanks J
Jan 24, 2008 | Sharp AL-1551 Laser Printer
HP Officejet 6310 All-In-One InkJet Printer Logo
264 people viewed this question
Seeker5211
Seeker5211
