There was a loud pop and flash from behind and now does not work
  • 395 Answers
What model and brand tv ?
sounds like the projection bulb blew out on it
Posted on Dec 12, 2008
Tc-p50g10, loud pop and then tv went out with a 3 flash signal and then pausethe 3 flash repeated
loud pop can be a bad fault on the power board. would think it would be the upscale side of the power board. big 3 pin voltage controller. it will also blow in front of it. you will be able to test it with a meter.
Nov 11, 2013 | Panasonic TC-P50G10 Plasma TV
Loud pop and light behind stove. Stove top works, oven does not.
Good Morning Stephanie - Typically you may locate the model and serial number in the storage drawer, on the right side. Based on the symptoms you are describing, you may either have a communication error from the main control board or a faulty bake and/or broiler element. If resetting the unit did not solved the issue, at this point I would personally contact a professional to accurately diagnose the range to determine the root cause to reduce the risk of unnecessary parts.
May 26, 2013 | Frigidaire FEF316 Electric Kitchen Range
Loud pop coming from roof area possible around sun roof
remove the headlining then squirt some foam filler behind the support bars ,i think they may be flexing causing the noise as this sort of fault is common the rover 75
Nov 12, 2012 | 2006 Cadillac DTS
Toshiba TP50G90, makes a loud popping sound then shuts off. red light flashes
it sounds like its over heating.clean all the fans ,put new artic paste on the cpu
Jan 25, 2018 | Toshiba TP50G90 50" Rear Projection...
My flash is not working on my Pentax 100D. It will not focus because of that. When I set it to no flash, it takes the pic. What am I doing? I have been using this camera since 2007 with no problems at...
Your circuit board is likely fried. If it is under an extended warranty, send it in and try to get it repaired. I had the same issue following a loud pop when using the flash on my K100D. You can try using a friend's flash but there is no guarantee that it will work, won't damage the flash, or do anything. If the friend's flash works, then you are better off buying an external flash than repairing the pop-up one because it will be roughly the same cost, and an external flash will yield better results than the pop-up ever could.
If the other flash doesn't work, then you need to send it in for repair because the circuits are definitely fried.
Thanks for choosing FixYa!
Jan 30, 2011 | Pentax K100D Digital Camera
Suddenly pic went out. Loud crackling and popping heard. Now, Blue indicator and red power light continually flashing. I think lamp. Unit 3 years old
the lamp has blown replace if got instruction book that came with tv shows you how if not got the lamp is behind cover on side or frount cover that comes off by undoing two black screws on back corners (each lower corner) anda sharp pull will remove cover
Dec 13, 2009 | JVC HD-56G786 56" Rear Projection HDTV
I have a Vizio P50 HDM and while watching it last evening I heard a loud pop and the picture went into a very noisy/distorted condition. Sound is OK. Any ideas?
That loud pop is your Y and Z sustainer. Normally it goes out completly but yours is still half working. Not usally fixable yourself, because you may need to flash the control board f/w , which is proprietary and can't be aquired unless you work for them,
Jul 08, 2009 | V, Inc. Vizio P50HD Plasma Television
Stove cutoff after loud popping sound
The element burnt in to and arced which is the loud noice you heard red flash of light. It probably tripped the breaker at the electrical panel. Don't turn it back on until someone checks the element and replaces it.
May 28, 2009 | Kitchen Ranges
Can't get the camera to Flash
EXACT same problem. Tonight I tried to take a picture and heard a loud pop sound but I didn't think it was my camera... anyway it took the picture but didn't use the flash. Later, my sister went to take a picture with the flash and it made the same loud pop noise and now the camera wont work if the flash is on.
Jan 19, 2008 | Samsung Digimax S630 Digital Camera
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
