Question about Fuji E6-120 MEP Hi-8 Tape
Drop-out glitch with Fuji mini-DV tapes
I shot some footage on Fuji mini-DV tapes in 2003. When I viewed these tapes on a DSR 11 Deck, there were drop-out glitches ("hiccups") with dropped audio several times every second or so. In 2008 I had clones made of the tapes, but the clones had the same glitch. How can I fix these tapes, or at least capture/digitize them glitch-free for a Final Cut Pro project?
  • 78 Answers
Unfortunately, the outlook is grim. If you duped the tape and the dropouts still appear, the anomalies are regrettably on the master itself, or the DSR11 is malfunctioning.
To be sure, try the following: View the master tape on a different deck, if possible. If glitches vanish, problem solved. Connect the AV/RCA out to the input on whatever digital deck you're using, and capture as usual with FCP. (If you need assistance with this step, I'll be happy to walk you through or send you in the right direction) Optimally, for a Hi8 tape, you would capture using DV 60i settings.
If glitches still appear, try capturing audio and video in two separate occurrences, I.E. One capture for video only, and a second capture for audio only. Sync in final cut.
If that doesn't work, your other option is to send the tape out to a post production house/lab, and see if they can do it -  but if you've tried everything else and resorted to this option, the chances are slim that much can be done - Hi8 tapes are notoriously difficult to recover. Best of luck, and do let me know I can be of further assistance :)
Posted on Jan 07, 2009
Hi. put in a mini-dv tape recorded on a sony z1 camera, the sony dsr-45p tape deck doesn't show any footage from the tape despite the camera had playback to show that footage was recorded. Using a windows...
Try to playback with other tape recorded earlier from other camera or VTR .If other tapes are palying properly without any glitches then it might be the problem with this recording.
anand
Oct 22, 2010 | Sony DSR-45 Mini DV VCR
Mini DV Tapes Won't Play
Please give the model and the make
Apr 16, 2008 | Sony DSR-11 DV / Mini DV VCR
the issue is probably related to the format the tape was recorded in. a z1u records in hi def (hdv) the dsr 45 is standard def ntsc. not compatable, play the tape in a z1 to recover
Tdk sony dvm60 miniDV tape not playing in final
HI please check your easy setup in tyhe fcp and set it as pal or ntse dv and should get the video in
Mar 02, 2010 | TDK DVM60 Mini DV Tape
DSR-11 will not record in DV SP mode.
dear, u need to change the memory cell of ur dsr-11 ,
Jul 29, 2009 | Sony DSR-11 DV / Mini DV VCR
DSR 11 won't record DV tape to its end
You need to use longer tapes. The DER-11 is a DVCAM deck which when recording, uses a faster tape speed then mini DV. Think of your older VCR's. They had SP, two hours, and EP or SLP, which would be six hours. The SP speed would give a better picture. DVCAM is more like an SP recording except digital and a lot better. More information is laid down on the tape.
You'll have to jump up to the full size DVCAM tapes in order to record the full hour.
Apr 10, 2009 | Sony DSR-11 DV / Mini DV VCR
DSR 11 playback problem
Pete, we are having the same problem with 2 dsr-11s.
The fix for us was the "auto repeat" switch on the back of the unit. It was "on" please turn it off.
The other idea was that the tape tension is very sensitive in the units, try exercising the tape (though exorcise might be good too) by fast-forwarding then rewind the tape start to finish. Tape that were tightly wound at the factory can cause this proble as well. Good Luck. Greg VA
Apr 29, 2008 | Sony DSR-11 DV / Mini DV VCR
Purple and green digital lines across film
One of the units is not making good interchange in recording (CAMCORDER) or (PLAYBACK) DSR11 deck either buy or get a known good recording to isolate the bad unit. Camcorders are notorious for loss of interchange as the cassette compartment wears out the scissors jack elevator gets sloppy and changes the angle of attack on the drum and wellah a tape that only plays back in the camcorder.
Jan 18, 2008 | Sony DSR-11 DV / Mini DV VCR
Sony DSR-11 Will Not Recognize Timecode
I think you may have misconfigured something because the problem is not in your DSR-11 try connecting it to a monitor and you will see the time stamp and picture as proof of what I am saying. The problem I think is that your Mac is not processing the time stamp correctly. Try this link first it helped me: Remember follow the instructions ezactly: http://forums.creativecow.net/readpost/35/856108
Sep 11, 2007 | Sony DSR-11 DV / Mini DV VCR
Fuji E6-120 MEP Hi-8 Tape Logo
465 people viewed this question
Top Fuji Electronics - Others Experts
Are you a Fuji Electronics - Other Expert? Answer questions, earn points and help others
