Question about AOC A17W221 17 in. HD-Ready LCD Television
No sound on channel 4.1, but on all other channels
I recently bought an AOC 22" LCD HDTV which works fine except for one little problem. I cannot get the sound to work on channel 4.1 which is CBS. When we select info on the remote, it brings up a box with 3 lines. On the right end of the center line, it says scrambled. How can we fix this problem?
  • txflyingchef Jan 03, 2009
    I am getting the signal from an antenna in the attic. After I scanned the channels channel 4-1 did not come on. I went to show/hide channels and I got the picture, but no sound. Channel 4 analog did work. I called AOC and they told me the signal was too weak and the tuner was not guaranteed to get all channels. If this is true and there is no way to adjust the TV so 4-1 works will a signal amplifier at the antenna work. fthe is the 2nd AOC L22W898 TV. I returned the first one with the same problem. However if you know of a way to fix it with an adjustment I will be very happy. I have the DISH network but I have the bedroom tv on the antenna because we watch the news and the Letterman show on local stations.
    You have got it all wrong. The tv Is an AOC 22" L22W898, not a 17" tv. There is nothing wrong with my Dish network. the problem is with the tv connected to the antenna in the attic as I clearly stated. You must be in India or some country where you have trouble understanding english. Either give me some advice that deals with the information I gave you ot tell me you can't help me.
  • 679 Answers
There is 5.1 and 7.1 no 4.1, the 5.1 is front center,front right, and front left, then rear left and rear right, the .1 is the sub-woofer, thus we have 3 front 2 rear and 1 sub-woofer, the 7.1 has a left and right center channel 7 speakers and and 1 or sometimes 2 sub woofers.if cbs isn't working it is not an audio problem, more likely an antenna or cable problem, some local channels are a pain in the **** to pull in with a standard antenna. Scrambled is the video, it may be encrypted if you are using an FTA box to pull in dish or a cable box that is not mpeg 4 compliant, I can help you more if you need it but first I need to know what you are trying to watch and what type of equipment, as this stuff is pretty standardized, but I need to know what you are trying to watch and with which equipment.
Posted on Jan 03, 2009
  • 2 more comments
  • George Bill
    George Bill Jan 03, 2009
    that's kind of what I envisioned, allow me to get back with you tomorrow, we should be able to figure it out.
  • George Bill
    If the technicians answer was that he didn't know how to fix it, I would tell them to remove it, I had the same thing happen with dish about six months ago, and they rewired the entire house. Then Comcast also who I use for my modem , did the same, thing . If you let them get away with it they will. Obviouslly you need a better connection than you are getting, check with neighboors next door and see if they are experiencing the same problem, this kind of stuff is why you pay them every month. You need a supervisor to generate a work order and get a tech out to your home, there is really not much we would be able to do, being that you already are aware of the problem, and you shouldn't need a signal amp if you are paying good money for your service, that is just a shotcut to avoid the real problem.
  • George Bill
    George Bill Jan 04, 2009
    It's not up to me to give you to anyone, Your question was so *** backwards that I was the only one who answered it, this is what you wrote,"the sound to work on channel 4.1 which is CBS" Isn't that 4.1 pal
  • George Bill
    You are watching local channels with a standard roof antenna, and you want to pull channel 4 in clearer, try a different antenna, you already tried the amp, there isn't any other solution, greetings from Boca Raton India
Display says please run auto channel scan
It sounds like it is not seeing any signal. Do you have the input set for the proper type? Air or Cable
Check your RF connection to ensure you have a signal coming into your television.
Nov 16, 2013 | AOC L22W898 22 in. LCD TV
Forgot my parent control password and i cant watch tv
This sounds like a common problem on these TVs. Try a factory reset:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
Mar 04, 2012 | AOC L22W861 22 in. LCD HDTV
I need to rescan and can't remember how to do it
Press Menu on remote.
Press the left arrow to get to Channel menu.
Press down arrow to get to Auto Scan.
Press right arrow.
Select Digital channels and scan.
Sep 23, 2011 | AOC L22W861 22 in. LCD HDTV
AOC L24H898 LCD TV
Do you have power surge or failure issues with your electricity? Try plugging your TV into an uninterruptable power supply (UPS) to get line conditioning and the continuous power.
Otherwise, I'd guess there is something else causing memory failures (bad chip or something).
I hope this helps.
Apr 21, 2010 | AOC L24H898 24 in. LCD TV
Can change the sound with my remotes
I recently bought a GE universal remote control, SKU: 24950, that has a control code for the AOC A17W221 TV. I bought mine at Target. You can check online to see if your local store has one before you go there. It's also listed on the GE site under consumer electronics accessories with a price. Don't know if they sell it online, though.
Mar 15, 2008 | AOC A17W221 17 in. HD-Ready LCD Television
Sharp LC-52D62U HDTV won't tune-in channel 21.
Sounds like the signal is probably too strong. The TV is not the problem.
Jan 16, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No sound on random channels
it sounds like you have SAP enabled. Refer to your manual or on screen menu to verify that it is disabled.
Dec 07, 2007 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
37" aquos
It sounds like it may be n demo mode. Check the inbuilt menus and check this is turned off.
Nov 24, 2007 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
AOC A17W221 17 in. HD-Ready LCD Television Logo
52 people viewed this question
Top AOC Televison & Video Experts
Raj Patel
Are you an AOC Televison and Video Expert? Answer questions, earn points and help others
