Question about HP Officejet 7130 All-In-One InkJet Printer
WONT PRINT AFTER REPLACING INK CARTRIDGE
WE REPLACED THE BLACK INK CARTRIDGE AND NOW IT SAYS NEED TO ORDER SUPPLIES PRESS ENTER TO PRINT, BUT NOTHING PRINTS. PLEASE HELP. WE CAN'T RECEIVE OR RETRIEVE ANY OF THE FAXES FROM THE PRINT QUEUE
  • fiathome Jan 08, 2009
    I have the same problem. Supply Expired is the message. AAAAAAAAAAArrrrrrrrrrrrrrrrrrrrrrrrghhhhhhhhhhhhhhhhhh!
  • jmeredith79 Feb 03, 2009
    I get an error message, supply expired, replace black ink cartridge. I've done that and still get the same error message
  • 3 Answers
There is a step missing from the book and HP's site. This how to has the answer, once and for all...
How to fix the repeat alignment issue with Hp All-in-One printer
Posted on Feb 01, 2009
Replaced black ink cartridge, ink wont come out
If any of the ink cartridges need to be replaced the printer will not work. Also, if you are printing only black you will need to go into print properties and select black.
Nov 07, 2017 | Brother MFC-465CN InkJet Printer
I have only black toner, colors are out. How can I keep printing? It sends a message: "replace supplies".
You need a supply of ink in both cartridges in order to print. Even if you are only printing black ink and there is a black ink cartridge with ink in it, your printer will not print without the color catridge installed and it has to have a supply of ink in it. I wish I had better news for you, but unfortunately I don't.
Aug 17, 2011 | HP LaserJet 2840 Printer
Mfc 5860 red printing green - already checked print levels. all are fine.
1. Confirm that the colors are incorrect by printing a Print Quality Check Sheet
a. Press INK.
b. Press the UP OR DOWN ARROW key to select Test Print.
c. Press OK.
d. Use the UP OR DOWN ARROW key to select Print Quality.
e. Press OK.
f. Press COLOR START
The machine will generate the Print Quality Check Sheet.
2. The LCD will ask "IS QUALITY OK? 1. YES 2. NO"
a. Press STOP/EXIT to return to the "Date and Time" display.
3. Evaluate the Print Quality Check Sheet.
On the Print Quality Check Sheet each of the four colors is represented by a slanted square pattern made up of 96 individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
NOTE: Cyan is the light blue color and magenta is the pinkish color.
a. If the colors on the Print Quality Check Sheet do not match the sequence listed above then the ink cartridges are most likely installed in the wrong order. Continue to STEP 4 to resolve this.
4. Open the Ink Refill cover.
5. Open the cartridge covers of the colors that do not appear in the correct order.
6. Remove the cartridges and reinstall them in the correct slots. On Brother Genuine Cartridges the color of the label will match the color of the cartridge cover.
7. Run a "Setup Purge". A Setup Purge is necessary to replace the ink in the ink supply tubes with the correct color. One or more of the ink cartridges may run empty during this process. If they do, replace the empty cartridge with a Brother Genuine Ink Cartridge before continuing the process.
a. Press MENU - BLACK START - MENU. The LCD will display Maintenance.
b. Press 7-6, The LCD will display CLEANING ALL
c. Press 6, the LCD will display eINIT__P ALL
d. Press the RIGHT ARROW key until one of the colors that was installed incorrectly is displayed. i.e. eINIT__P CYAN.
e. Press the BLACK START Key.
  • After the machine completes the Setup Purge it will return to the Standby Display.
8. Print another Print Quality Check Sheet
a. Press INK.
c. Press OK.
e. Press OK.
9. The machine will generate another Print Quality Check Sheet.
a. If all four colors printed correctly the issue is resolved.
b. If one or more of the colors are still not printing in the correct order repeat STEPS 4 - 8.
Feb 17, 2011 | Brother MFC-5860CN InkJet Printer
WHILE TEST PRINT CYAN INK NOT SHOWING WHAT SHOULD I DO SIR
This issue will only occur if an ink cartridge(s) is or was installed inthe wrong position (slot) in the machine. When a cartridge is installed, the ink tube system is filled with the ink from the cartridges, to prepare the machine for printing. If the cartridge is inthe wrong position the tube will fill with the wrong color.
NOTE: If you just installed or replaced the ink cartridges and your printed documents are missing colors please refer to the solution - I just installed or replaced my ink cartridge and my printed documents aremissing colors. What can I do? Blank
To resolve this issue you will need to clean the print head.
NOTE: It may require 10 to 15 cleanings to clean the ink tubes and print head. During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to completethe cleaning process.
1. First verify the position of the ink cartridges:
a. Open the ink cartridge cover and check to make sure the ink cartridges are in the correct order.
b. Starting from the left side, the correct order is Black, Yellow, Cyan(blue), and Magenta (red).
- If the ink cartridges are installed in the correct order, close the ink cartridge cover and continue to STEP 2.
- If the ink cartridges are not in the correct order, remove the ink cartridges that are installed in the wrong position by pressing down on the release lever(s), located above the ink cartridge and remove the cartridge(s) from the machine.
Next, reinstall the ink cartridge(s) in the correct position in the machine by gently pushing the cartridge in until it clicks.
When all the cartridges are installed, close the ink cartridge cover.
2. After closing the ink cartridge cover, the LCD will prompt - Did youchange XXXX (XXXX = the color) This message will be displayed for ink cartridge that was removed. Press the - (Minus Key for No). This willkeep accurate data of how much ink is left in the cartridge.
1. Press the INK key.
2. Press OK to select Test Print.
3. Press OK to select Print Quality.
4. Press the COLOR START key.
5. Review the Check Sheet. The colors on the Check Sheet should be in a specific order: Black, yellow, Cyan (Blue) and Magenta (red).
a If the colors on the Check Sheet are in the correct order and are notmissing any dashes, press + (Plus Key for Yes) on the key pad and continue to STEP 7.
b If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - (Minus Key for No) on the key panel and continueto STEP 6.
6. The machine will need to perform cleanings to flush out the incorrectcolor or dried ink from the ink tubes and print head.
a. The LCD will ask you BLACK OK. If black is fully printed and is the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
b. The LCD will ask you COLOR OK. If any of the 3 colors (yellow, cyan (blue), and magenta (red) are fully printed and are the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
c. The LCD will say START CLEANING + for YES and - for NO. Press + for YES to start cleaning. The machine will go through a cleaning cycle that will take approximately one to two minutes.
d. After the cleaning is completed, the LCD will say PRESS START. Pressthe BLACK START key. This will print out the print quality check sheet again for you to check and see if your print quality issue has been resolved or not
NOTE: If you wait 1 minute after the cleaning cycle is completed, the display will return to date and time. You will need to go back to STEP 3 to print the Print Quality Check Sheet again.
e. If the ink color order is correct and all of the dashes are present, press + on the key pad to select YES and continue to STEP 7.
If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - key to select NO. Repeat the cleaning process byfollowing STEPS 6a through 6d. You may have to perform this procedure up to 15 times in order to clean the ink tubes and print head
NOTE: During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to complete the cleaning process.
7. Test by printing the document that had the reported problem (wrong color printing).
Dec 08, 2010 | Brother DCP 165C Compact Color Inkjet...
After cartridge change, the printer will not work
you might not like it, but here it is, it is the truth
Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head. Therefore, once one of the cartridges are expended, the printer signals you to replace the cartridge in order for printing to continue.
Aug 20, 2008 | Epson Stylus Photo R300 InkJet Printer
Officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Aug 07, 2008 | HP OfficeJet D135 All-In-One InkJet...
Ink
May 19, 2008 | Epson R245 InkJet Photo Printer
Printing without color?
Im sorry to inform but yes, Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head. Therefore, once one of the cartridges are expended, the printer signals you to replace the cartridge in order for printing to continue.
May 12, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Dell 922 All In One Printer wont print
did you remove the seal of new catridge. bye
Sep 24, 2007 | Dell 922 All-In-One InkJet Printer
After replacing the black ink nothing prints
Before taking out a new ink cartridge from its package, shake it four to five times. Are you sure you have the proper ink replacement cartridge.The following Epson ink cartridges should be used in your device: * Black: T0431 (high capacity cartridge) or T0441 (standard capacity cartridge) * Cyan: T0442 * Magenta: T0443 * Yellow: T0444 How did you discover the ink was low? Did the machine prompt you or was the printer not printing properly? The other colors should blend together to give you atleast some form of black. If the printer alerted you to change the cartridge...Go back through the procedure to install a new cartrige. Follow the steps below to replace ink cartridges. Make sure the CX6600 is on. When the ink is empty: Refer to the LCD panel message to see which ink cartridge is empty, then press the Color button. When the ink is low: Press the Setup Mode button to enter the Setup Mode and press the A button repeatedly until 5.Ink cartridge appears on the LCD panel, then press the Color button. The ink cartridges move to the replacement position. Make sure that the document cover is closed, then open the scanner unit. Open the cartridge cover. Pinch the sides of the ink cartridge that you want to replace. Lift the cartridge out of the CX6600. reinstall the same cartridge. (Try shaking it a few times again) If none of the above works uninstall the printer. Download the newest drivers from epson and the should straighten it out. Good Luck. Tim
Feb 20, 2007 | Epson Stylus CX6600 All-In-One InkJet...
HP Officejet 7130 All-In-One InkJet Printer Logo
398 people viewed this question
Ben Johnson
