Question about XO Vision GX1042 10.4 in. Car Monitor
I have XO Vision GX1042 10.4 in. Car Monitor and I lost the remote control. I have the input going to AV1 on the monitor. Once in a while it automatically switchs to AV2 on my monitor when I turns the monitor on. I could not figure it out how to change it back to AV1 without the remote. I take my chance once a week to turn the monitor on and hopefully It gets back to AV1. Right now I can not watch DVD. Please help.
SOURCE: Lost the remote
that one is easy just press menu the channel button up till you get to av1 or av2 then press the volume to change it.
Posted on Jan 10, 2009
Xo vision gx2022..need the plug that turns video wire into rca's
radio shack online or crutchfield.com may have what you need
Dec 27, 2009 | XO Vision GX2022 Car Monitor
Is there any way to just order the audio/video inputs for xo vision xo27702 monitor
is there any way to just order the audio/video inputs for xo vision xo27702 monitor
Sep 10, 2009 | XO Vision XO270 7 in. Car Monitor
How to get power to xo vision roof mount unit
old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball
Feb 04, 2009 | XO Vision GX828 8" Roof Mount TFT LCD...
Is there a video input on the back of a XO Vision xod1730?
Feb 02, 2009 | XO Vision MD068 6.8 in. Car Monitor
Lost the remote
Dec 12, 2008 | XO Vision GX1042 10.4 in. Car Monitor
XO Vision GX-1581 No Signal
It looks like you've narrowed it down to a settings issue. If it is saying "No Signal" while on AV2, then you need to switch to AV1 where your video signal is. A remote might be available online from XO Vision (www.xovision.com) directly or on E-bay. You might also be able to find a local dealer of XO Vision from their website. One quick fix you can try....since the monitor has 2 video inputs and is stuck on AV2, you can simply get video by unplugging the video input on AV1 and plugging it into AV2. Hope this was helpful.
Sep 27, 2008 | XO Vision GX828 8" Roof Mount TFT LCD...
XO Vision XO-141FM 14.1 in. Car Monitor
Check that you have good ground connections.
Use DVM to check if you have 12VDC to player.
If you have no DVM, you can use small car light bulb with leads.
If bulb lits from ground and hot wires, then player is bad. Or most likely a loose connections.
atdlee@netzero.com
Feb 02, 2008 | Car Audio & Video
Check voltage going into player.
It should be 12VDC.
atdlee@netzero.com
Feb 02, 2008 | XO Vision XO-141FM 14.1 in. Car Monitor
Xovision monitor
To what car?
Black wire to ground.
Red wire to +12VDC.
Yellow cable to input of Yellow Input's radio.
atdlee@netzero.com
Dec 21, 2007 | XO Vision 12.1 Flip-Down Monitor w IR"
XO Vision GX1042 10.4 in. Car Monitor Logo
Top XO Vision Car Audio & Video Experts
Pablo Gonzalez
Jose Velazquez
Jose Velazquez
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
