Question about Garmin Nuvi 350 Car GPS Receiver
"No Map Data Available" - Garmin Nuvi 350
My GPS displays direction and speed, and sometimes even a main road, but the cursor representing my car isn't actually on the road. If trying to plug in an address I get an error that reads "No Map Data Available". Someone from Garmin told me to go to Settings, Map, and under the "Get Map Info" tab select "city" but the Garmin doesn't let me select the "Get Map Info" tab, so it's still NOT WORKING. Ideas????
  • 4 more comments
  • Anonymous Dec 18, 2008
  • gsanangelo Dec 23, 2008
    i tried to complete the update and now there are no maps or highlighted route
  • Anonymous Jan 09, 2009
    No map data available
  • jkboatn Jan 28, 2009
    I did too-and called garmin and they sent me a.unl file I moved it over to the drive inside the garmin subdirectory then unplugged the unit like garmin said-and still same problem..nomap dataavailalbe-also the link below doesn'twork..anyone else
  • Anonymous Mar 27, 2014
    My GPS in my Dodge Journey says no maps available when I try to find an address How do I get my maps back
  • Anonymous Mar 29, 2014
    My garmin nuvi (1490) was working fine when it told me it no data and no maps and would'nt do anything
  • Garmin Master
  • 2,130 Answers
This is because your map file has either been deleted or corrupted and needs to be replaced. Please see this link for more info. Too much info to copy & paste here:
http://www.sharc.net/nuvi_lost_map.htm
- Jim
Posted on Dec 13, 2008
  • mapper2 Mar 10, 2011
    I had the same problem when I switched language. Just go to settings/system/maps, change the settings back and forth and click done, it will restore the maps. (Garmin 1490)
    New Friend:
I had replaced the file in the wrong folder inside the Garmin. Make sure the file is EXACTLY where it was before the conversion
Posted on Oct 03, 2013
    New Friend:
NUVI 855 ... rearranging Route ( .gpx ) files with a PC. Then "No Map Data Available" errors. Tried Garmin's site - created an Unlock file - no help. Replaced all system and data files with two different backup copies - no help.
Then ... removed the battery to check S/N. Replaced battery and unit auto restarted. Checked Maps ... OK ! Tried again adding & removing Route files ... same problem. Same Fix !! Seems to work every time.
Posted on Apr 15, 2013
SOURCE:
Hi there im having a tomtom 1505tm and my screan goes black but you can hear in background telling you the road,sometimes i can it opens sometimes no pls some help
Check the power saving features. You may have configured the GPS to turn off the screen display while GPS is reading directions.
Mar 04, 2014 | Tomtom VIA 1505TM GPS Receiver
After engine is warm ( V 6 ) sometimes, but not always, hesitates when trying to speed up and sometimes backfires. Dealer replaced coils and plugs but can't find the problem. 2005 lincoln LS
The spark plugs get replaced around 60,000 miles
& the L/S requires a special spark plug,also
premium fuel or it will knock
If you change plugs every 3 years, then that isn't the issue
Did they remove the upper intake manifold to do the right side
spark plugs?
You never have more then 1 bad coil a year, or sometimes
2 ,but never at one time
A dealer can not work on an L/S for some reason
I own a 2004 V8 & have no issues diagnosing these problems
The front 2 O2 Sensors ,the ones in the front of exhaust converter,
get slow & get replaced at 100,000 miles
You clean the MAF Sensor with CRC MAF Cleaner
A back fire could be a lean condition from a vacuum leak
That could be around the engine or in the EVAP System
Hopefully they checked the TPS Sensor
When I refer to check, I don't mean replace,I mean test &
use an oscilloscope to back probe the sensors,not continually
make love to their scan tools,actually get involved & see what
does work & how well,then you will eventually find something
that doesn't.
The EGR Valves fail on ford products quite offten
Need to check/test fuel pressure at rail on engine,even
road test with gauge taped to the windshield & take scan
tool along to collect data.
You got sometimes & when warm,that is what they should
be working off of
You don't go after a problem ,you find out how things are
doing that do work & the drivability issue will surface.
Dealers sometimes never even road test a car or long enough
So there you go,they won't find anything
Keep in touch,I have all the manuals etc if you give me more
symptoms
Jun 22, 2011 | 2005 Lincoln LS
Was going north and the map said i was going south
Are you sure you were heading north at that particular time?
Gps show your direction at that moment and time. Just because your road is going north does not mean that the road is always going north, sometimes they change directions to go around obstacles that were in the way of the road design, IE mountain, town, river.
The sign for the highway may say your are heading north when in actuality you are heading south to go around something.
The gps will not take into consideration the curve of the road, it just tells you the direction you are heading. Hope this helps.
Apr 02, 2010 | Pioneer AVIC-D3 GPS Receiver
Garmin 1300; Can't get speed limit of street/road but do get speed that I a going. Why? "[email protected]" "817-992-6143" "Robert L Warner"
I had a nuvi 205 for a while and it showed some of the speed limits. had a little sign that would pop up above the current speed. I "upgraded" to the 1300 and was surprised to see that feature missing. Actually, kinda mad, I really liked that function
Nov 24, 2009 | Garmin nuvi 1300 Car GPS Receiver
Northstar 951 GPS shows boat moving & @ high speeds (over 100)
RE: Northstar 951 GPS Receiver
Contact & Support @ http://www.northstarnav.com/en/Support/
jack
0501102.jpgPlease Rate This Now or Later!
Feb 22, 2009 | Northstar 951XD GPS Receiver
Does not show max speed allowed it is 6mths old
I have found that the maximum speed is not known for all roads so only the speed is displayed.
Where the max speed is known for a particular road it should always work for that road. If not then there could a problem with the GPS.
Peter
Jan 21, 2009 | Tomtom GO GPS Receiver
Cursor bouncing
I have had some similar issues, I find I must wait till my mapping program is fully open and running before I plug in my GPS unit, and the problem doesn't resurface.
Oct 25, 2007 | Microsoft Deluo Universal GPS USB...
Garmin Nuvi 350 Car GPS Receiver Logo
24,037 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
