Question about Cameras
My camera (PS SD30 elph) lens will not retract and the diplay code of E18 appears. I have already checked the battery cover and such.
    Novelist:
  • 121 Answers
There are a variety of things that may be causing this problem. Here is a website that takes you thru a list of possible solutions.
Do it yourself camera repair
The first few solutions are easy to try and won't damage your camera. If they don't work, do NOT proceed into the remaining solutions if your camera is still under warranty - send it in for warranty repair. If your camera is out of warranty, then the cost to repair the camera usually exceeds the camera's value so you can try the remaining items on the list.
Posted on Dec 12, 2008
What does E18 mean
Lens error. Try http://www.e18error.com/ for help on fixing it.
Jun 29, 2014 | Canon PowerShot SD30 / IXUS i Zoom Digital...
Hi i had an e18 error appear and the lens was stuck. the lens is now going in and out but the focus is compleatley shot every thing is blured any ideas?? thanks
"E18" indicates an error that involves the lens unit or lens cover in your camera .This error appears where the lens is prevented from properly extending or retracting .The error may also be displayed if the lens camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.Hold the camera so that your fingers do not touch the lens unit when you are shooting. Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service from canon. Or else try pressing the power button on and held it down while extending the zoom lens. The lens will extend out and the camera will be freed from the error.
Thank you !!
Jun 22, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
Canon Elph shutter won't retract and camera won't shut off.
Very common.
Broken Shutter Flex cable in the lens.
Needs replacement.
Apr 05, 2009 | Photography
Canon sd630 dead
Lens is defective, change the lens
Nov 01, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon powershot sd30 digital elph
I have same problem. I turn on the camera you hear it trying to come on, shows display pic for like 3 seconds and then shuts down. If I could get the lens to retract I am sure the camera would work.
Jun 23, 2008 | Canon PowerShot SD30 Digital Camera
Everything is blurry and out of focus
error code e18 means that the focus motor gears a jammed, dirt or grain of sand in them. you can try to fix it by gently banging the camera on somthing soft, their are also instructions on web on how to disasemble and fix this fault. BUT unless you have some skills, the right tools and conditions i would not attempt it. leave it to the experts
Sep 22, 2007 | Canon PowerShot SD30 / IXUS i Zoom Digital...
E18 error message
I have the same problem that was posted by chewie .
E18 error message!
Hope somebody can help.
Jun 22, 2007 | Canon PowerShot S2 IS Digital Camera
Camera was dropped, lens will not retract, when on/off button is pressed the initial screen and sound appear but then the camera makes a kind of warning sound and E18 appears in the lower left hand co
Perhaps the lens got bumped (if the camera was one when it was dropped) and is out of place. Mine did the same and I sent it in (it was within warranty) and Canon fixed it.
Mar 18, 2007 | Canon PowerShot SD100 / IXUS II Digital...
Error 18
The "E18" error code indicates an error that involves the lens unit or lens cover. This error may appear where the lens is prevented from properly extending or retracting such as, for example, when pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed if the lens unit/camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera. Solution Check the following when you operate the camera to avoid applying pressure to the lens and surrounding area: - Hold the camera so that your fingers do not touch the lens unit when you are shooting. - Make sure the camera is off before you put it back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.
Aug 31, 2005 | Canon PowerShot SD500 / IXUS 700 Digital...
Error 18
Aug 31, 2005 | Canon PowerShot SD200 / IXUS 30 Digital...
Cameras Logo
44 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
