When standing pilot is lit with a call for heat gas is released for a couple seconds before it ignights and it backfires hitting the limit swith and pilot goes out. I have cleaned burners and pilot . Ive checked gas presure. what could be causeing that.
  • Ken Bledsoe May 11, 2010
    Is the unit more then 10 years old? And what brand is it.
  • 334 Answers
Improper airflow.
Check to see that there are no obstructions in the exhaust flue.
Make sure the inducer fan is operating and the blades are intact. (if your unit is equipped with a draft inducer motor.)
Flame rollout can also be cause by cracked heat exchangers when the blower kicks on, or from wind blowing into the flu in reverse.
(Bad/missing wind deflector outside on top of flue, or unusually gusty wind in unusual angles.)
Posted on Dec 13, 2008
Sw6p suburban won't stay lit. My 6 gallon hot water heat on my 2007 camper won't stay lit, I go and light the pilot light and it lights but I turn the gas up and it blows out please help
the thermal couple is likely bad .
when you release does pilot stay lit or only as long as you hold the button .
if it stays lit then the thermal couple is good
if it only blows out as you turn on the heat then its draft issue.
May 09, 2015 | Water Water Heaters
Raypak gemini 53 pool and spa heater pilot iights but burnner wont ignight
The thermocouple allows the pilot to stay lit. If your burner will not light but the pilot is lit, there is a problem with either the control or the control valve. Either the signal is not being sent to the control valve to open or the signal is being sent and the valve is faulty.
Jan 08, 2015 | Raypak Pool & Spa
Rheem rp4036m
Under the gas valve is a removable panel. On models of that era there should also be a second panel behind the first. remove both.
the pilot light should be clearly visible.
If no pilot, turn the gas valve to OFF. wait 60 seconds. locate the tubes from the gas valve to the pilot location. turn the valve to pilot, and with a long match or grill lighter lit, place flame at the pilot location and press down on the pilot button beside the main valve.
pilot should light. If not shut off the gas and call a technician. If yes, hold the pilot button for 60 seconds, then slowly release. Pilot should stay lit. If not, shut off gas and replace thermocouple, start relight sequence over. If pilot stays lit, replace inner cover and adjust temp to 120 deg. If heater fires up, replace outer cover. Done.
If heater does not light, replace gas valve or entire unit. Water heaters have a limited life expectancy, and if my recollection is correct your unit is 10yrs past warranty.
Dec 04, 2013 | Water Water Heaters
Pilot light keeps going out
pilot light keeps going out! more then likely its the thermal coupling doing this. if bad it shut all gas to heater for a safety measure. just shut power off, then turn gas off and replace it. then you should be ready to go. to relight heater hold down on gas vavle knob in the pilot position, hold down and light it at the coupling where gas comes out. when it is lit, continue to hold down for 60 seconds. release knob very slow. then if its lit, turn to the run position. if flme goes out, wait at least 5 minutes to expel the gas fumes and turn to pilot and try again. good-day !
Mar 31, 2012 | Water Heaters
CGA Mclain .Natural Gas boiler issue 70k btu with a effikal ventx damper, model RVGP. There is no blower for ventilation, no control board with lights. Pilot light will not stay lit. have already replaced...
hey Carli suspect you mean the pilot goes out as soon as u turn your gas control valve back to the on position!? If this is so, you will have to probable reset the flue spill switch located right at the exaust outlet. OR, SOMETIMES THEY HAVE ANOTHER LIMIT switch in the same circuit in series. If the pilot goes out when u release the pilot press down knob, then it is your thermo couple is loose or fininshed,or the pilot flame is not aimed properly at the sensor (thermo couple)
Sep 21, 2011 | Heating & Cooling
How to light the pilot light on a natural gas wall heater
SEt to pilot, Push knob, push pezio ignighter until pilot lights, hold for 30 seconds. if it stays lit turn to on, if it doesn't stay lit, you have a bad thermocouple
Mar 24, 2011 | Vulcan Heating & Cooling
Pilot light keeps going out! Will not stay Lit.
Check if the the gas pressure is sufficient (as stated on unit's nameplate). Check if the hi limit device is good. Check also if the thermopile (cylindrical metal with two wires standing behind the pilot hood) is receiving enough heat from the pilot flame. The voltage generated by thermopile should be 500millivolts in order to open pilot and main valve. If there is 500millivolt on gas valve thermopile and the pilot flame does not stay lit, you have to replace the gas valve. If the thermopile is glowing red and the voltage generated does not reach 500 millivots, you have to replace the thermopile.
Jan 18, 2011 | Pitco Frialator SG18S Deep Fryer
Im calling for heat from the thermastat and control panel, the boiler light and and the fan is running, but no matter how many times i keep re trying the pilot and burner will not commence, is there...
I would check to make sure control on gas valve is in on position and pilot is lit if you have a standing pilot. If you have a spark or hot surface ignitor make sure they are trying to lit pilot. If you have standing pilot model and pilot lit is not on. Turn control on gas valve to off,wait five mins. then turn to pilot. Depress botton and try to light pilot. If it lights hold down for a couple of mins. then release.. If pilot stays lit turn control to on. If thermostat is calling for heat this should bring main burner on. If pilot does not stay lit then replace thermocouple. Hope this helps. Thanks
Nov 16, 2010 | Heating & Cooling
My hot water heater will not stay lit. What could be the problem and would I be able to fix it?
The thermal couple that senses the heat from the pilot and holds the gas valve in the ready condition must be bad. It is not difficult to replace. Note: When you first lite the pilot flame you must hold the button down for at least 30 seconds before releasing it. Also check the size of the pilot flame that contacts the thermocouple.
Jun 28, 2008 | Heating & Cooling
Heating & Cooling Logo
78 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
