Question about RCA P52939 52" Rear Projection Television
RCA P52939 projection TV
The picture rolls and I can not stop it. Is there an adjustment that can be made to fix this? On old TVs you had a vertical hold and a horizontal hold. This one does not. What is my solution?
    President:
  • 3,130 Answers
Yes you are correct, no days these TV sets have an automatic vertical hoild, and no I am sorry to say, there is no adjustment for you to make. there is a problem in the PIcture in picture circuit if there is one or the sync sepaqrator circuit has a problem. most likely a bad capacitor or a bad diode. This is a solid state set and there are no user replaceable parts inside them unless you know how the circuits work and can trouble shoot printed circuit boards. You are best to call in a pro to assist you in this repair. Good Luck
Posted on Mar 23, 2007
RCA serial 137651043, model P52939, 55 inch tv.
Half black? top/bottom or left right?
The set is rather old--a old trick to use is to connect a fan to the rear of set with the back off--it may extend the life of the set and give you some more use out of it.
I have seen a lot of these sets and never one with the problem you describe. If only a picture top or bottom is missing it may be vertical or if you are seeing what looks like a full picture with top or bottom black it is a Blanking problem--may not be easy to find...........
Apr 25, 2012 | RCA P55000 55" Rear Projection Television
The picture on my TS-4573 rear projection tv has started to roll vertically at a fast rate. How can I make this stop. On old tv's there was a vertical hold adjustment on the back that you could play with...
this fault is caused by defective electrolytic capacitors in the vertical deflection circuits, they need to be changed out, do this before it causes more problems, there are no adjustments for this anymore.
Jan 30, 2010 | Televison & Video
Screen rolls maybe vertical sync
II NEED TO RESOLVE A PROBLEM OF VERTICAL SINCRONICE I SALLBE GRETFULL TO HAVE ADJUSTMENT INFORMATION I SHALL BE GRATEFULL IF YOU COULD HELP ME
May 26, 2009 | Mitsubishi VS-45605 50" Rear Projection...
NO PICTURE BEEPING NOISE
I have an RCA projection TV P52939 it has no picture, and makes a beeping or ticking sound can you tell me what it is.Thank you
Apr 20, 2009 | Televison & Video
Mitsubishi WS-48311horizontal scroll
Its not a problem you can easily fix. Many Mits TVs of the mid-90's had a PIP board in them that had dried up surface mount capacitors on them. The board would have to be either re-built or replaced at a considerable cost.
michtech
Feb 12, 2009 | RCA P56923BL 56" Rear Projection...
Rca picture concave 52 in rear projection
sounds like your color guns are out of alignment and need adjusting. its a cheap fix with a tv tech but i wouldnt recommend doing it yourself. plus, a visit from a tech can tell you if there is anything else wrong/about to b wrong
Oct 21, 2008 | RCA P52939 52" Rear Projection Television
Lines
are the lines multiple colors? ie; reg, green, blue? If so you need convergence repair, not really something a lay person can do.
Nov 29, 2007 | RCA P52939 52" Rear Projection Television
Rca p52939
Does the Tv pick up a signal ? ( picture/sound ) If not, you may have a tuner problem as the screen will default to blue with no signal apparent. Could also be a cable problem. Hope this helps
Ed
NC Electronic
Mills, Wyoming
Nov 18, 2007 | RCA P52939 52" Rear Projection Television
Rolling screen
This may be a vertical hold control problem I'm not sure where the Vert. Hold potentiometer is on the mainboard. I would see if you can find someone who can locate it and adjust it.
Sep 15, 2007 | RCA HD52W56 52" Rear Projection HDTV
RCA P52939 rear projection TV
Vertical sync is an IC function = shop repair = remove light box
and take it to a quality repair facility for an estimate = beware
of "Free Estimates" = pay for diagnosis, get it in writing.Mainly,
I'm finding bad solder connects in this style chassis,sometimes
I work on two or three at a time in my small repair shop........T.
Please rate this solution........................
Mar 19, 2007 | RCA P52939 52" Rear Projection Television
RCA P52939 52" Rear Projection Television Logo
104 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
