Question about HP LaserJet 1300 Printer
Black lines across the LH side of the page in 4 places per sheet
  • beegees Dec 30, 2008
    I have black smudges across the entire sheet in about 6 spots.
  • 107 Answers
Bad fuser if you already checked the toner
Posted on Dec 12, 2008
How to print 2pages on one sheet of paper (side by
press key with windows logo(bottom of keyboard, both sides of spacebar),choice printers and faxes,find printer your using(if you have more than one listed, or the one with check by it),double click, when document box opens,click on printer(upper left at top of box),under page layout choose # of pages per sheet...2 will give you 2 pages side by side,4 will split the sheet into 4 quarters.
Mar 20, 2010 | HP Officejet Pro L7680 All-In-One Printer
How to remove front stabilizer bar in '05 Scion TC
I don't know if you can get the bushings out without changing the bar or not, but changing the bar is a big job for a DIY. I was thinking about it but will probably have a pro do it for me. From the shop manual: 1. PLACE FRONT WHEEL FACING STRAIGHT AHEAD 2. REMOVE COLUMN HOLE COVER SILENCER SHEET (See page SR-9) 3. DISCONNECT NO. 2 STEERING INTERMEDIATE SHAFT ASSEMBLY (See page PS-21) 4. DISCONNECT NO. 1 STEERING COLUMN HOLE COVER SUB-ASSEMBLY 5. REMOVE FRONT WHEEL 6. REMOVE ENGINE UNDER COVER LH 7. REMOVE ENGINE UNDER COVER RH 8. REMOVE FRONT STABILIZER LINK ASSEMBLY LH (a) Remove the 2 nuts and front stabilizer link LH. HINT: Use a 6 mm hexagon wrench to hold the stud if the ball joint turns together with the nut. 9. REMOVE FRONT STABILIZER LINK ASSEMBLY RH HINT: Use the same procedures described for the LH side. 10. DISCONNECT TIE ROD END SUB-ASSEMBLY LH (See page DS-6) 11. DISCONNECT TIE ROD END SUB-ASSEMBLY RH (See page PS-21) 12. DISCONNECT PRESSURE FEED TUBE ASSEMBLY (See page PS-21) 13. DISCONNECT FRONT SUSPENSION NO. 1 LOWER ARM SUB-ASSEMBLY LH (See page SP-22) 14. DISCONNECT FRONT SUSPENSION NO. 1 LOWER ARM SUB-ASSEMBLY RH HINT: Use the same procedures described for the LH side. 15. REMOVE FRONT FLOOR PANEL BRACE (See page EX-2) 16. REMOVE CENTER EXHAUST PIPE ASSEMBLY (See page EX-2) 17. REMOVE HOOD SUB-ASSEMBLY 18. REMOVE NO. 1 ENGINE COVER SUB-ASSEMBLY 19. SUSPEND ENGINE ASSEMBLY (See page MX-19) 20. REMOVE NO. 1 HOOK (See page PS-22) 21. REMOVE FRONT SUSPENSION CROSSMEMBER SUB-ASSEMBLY (See page PS-22) 22. REMOVE FRONT NO. 1 STABILIZER BRACKET LH (a) Remove the 2 bolts and front No. 1 stabilizer bracket LH from the suspension crossmember. 23. REMOVE FRONT NO. 1 STABILIZER BRACKET RH HINT: Use the same procedures described for the LH side. 24. REMOVE FRONT NO. 1 STABILIZER BAR BUSH (a) Remove the 2 No. 1 stabilizer bar bushes from the stabilizer bar. 25. REMOVE FRONT STABILIZER BAR
You can download the manual online for about $15. Well worth it.
Jun 30, 2009 | Scion TC Cars & Trucks
Hp laserjet 4 plus - keep getting a horizontal black line
yes you have to catch printer making the line and then as a page is being printed you need to open door to stop paper after green cylinder(drum) as it is entering fuser, then you need to remove paper from printer without pulling through the fuser, if you see the line then rub your finger across line up and down page, if it smears at all then its the cartridge if not then the fuser
Apr 27, 2009 | HP LaserJet 4 plus Printer
Mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Mar 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
Black lines on printed material
check the optics section the remove the exposure glass anh clean the fisrt,second, and third mirror
Feb 16, 2009 | HP LaserJet 3050 All-In-One Printer
Black Line on Rt side of every printed sheet!
I don't know if this will help but I was getting smears on the right side of the paper where there was no printing. I came acrossed this and it worked for me. Open up the front cover and lift the top cover and remove the drum cartridge. Then with cartridge out remove the left and right screw on the side of the cartridge. This will give the drum belt room without hitting the cartridge case. The cartridges plastic was not formed well.
Skip
Jul 11, 2008 | Dell 3100cn Laser Printer
Problem printing multiple pages on one sheet!
This is not the fault of the printer but the fault of word.
The way I did it successfully was as follow:
File > Page Setup > Layout = Landscape (sounds like you have already done this)
In the print dialoge, instead of OK, click Properties. On the layout tab, select landscape and below that select pages per sheet = 4 and then click ok... Then click OK to print.
May 22, 2008 | HP LaserJet 2200 Printer
Canon Pixma MP 800 printing Issue (heavy black line on opposite side of print page
problem is when the printer does a head clean dumps large amount of black ink on to rollers. Replacement head is almost £100 and not certain to fix fault
Apr 12, 2008 | Canon Pixma MP800 All-In-One InkJet...
HP LaserJet 1300 Printer Logo
53 people viewed this question
Ben Johnson
