Question about Nokia 1100
Insert SIM The problem is that...even after inserting various SIM cards the mobile shows ......Insert SIM. How to proceed with this problem.
  • Anonymous Mar 17, 2014
    insert sim card saying even when its on
  • 74 Answers
Change sim card ic. or make it short.
Posted on Mar 16, 2007
The contacts for the sim card may be dirty have a short ( was the phone dropped). Use a cotton swab and some contact cleaner (rubbing alcohol will work fine) and gently rub the contacts with the alcohol soaked swab. try inserting the sim card after the alcohol has had a chance to evaporate (about thirty minutes or so). [NOTE: the following may sound complicated and you may not be comfortable doing it - if this is the case then take it to a repair shop or get a friend who is inclined to to this sort of stuff] (I have done this several times and have had no ill results) If this does not help, use a (I think # t-5 or 6) star bit to remove the cover and casing. clean all the contacts with the alcohol (make sure you leave no strands of cotton behind), allow to dry and put it back together. After all this, and it still does not work I can only assume the controller board is damaged somehow.
Posted on Mar 09, 2007
  • 65 Answers
First check your sim if theres any corrosion, if so try to clean with cloth or swipe it with your fingers.. hehe. if still not working replace it with other sim card. also, insert your sim to other phone. if still not ok, visit the service center nearest you..
Posted on Mar 31, 2007
  • 3 Answers
Insert sim
Posted on Aug 14, 2009
For engineers, make sure the batt contacts very well with the terminals,also raise sim cntact points for a better contact,if not check the ic close to the sim port.pull it up with the help of rework station and run jumpers from 1 to 3,4 to 6 and 7 to 8.cheers...
Posted on Jun 28, 2007
Try diffrent battery.
Posted on Apr 30, 2007
I solved this with a few pieces of paper between the sim and sim holder. In other words let the sim holder put more stress on the sim, and thus on the reader contacts. This worked on three different Phones.
Posted on Jul 28, 2007
SOURCE:
Insert sim card 5320
What is your problem with your Sim card? Is your phone shows the "No Sim" or "Insert Sim" or "Sim Rejected" or "Invalid Sim" error? If it is so i am here to help you. If your Nokia shows the "No Sim" or "Insert Sim" error then remove your Sim from your mobile and place it again correctly. If your mobile shows the error message "Invalid Sim" or "Sim Rejected" the your phone is locked to a particular network. To fix this problem you need to unlock it. Use unlock code to unlock your Nokia 5320. To get the code you have to submit network provider, country and IMEI number of the mobile. Make sure yourself whether you have knew the network provider to which your mobile is locked, country to which the locked network belongs to and IMEI number of your mobile. If not you can find the IMEI number in two ways:
1)Go to Options>status
2)Find IMEI on the back of your mobile, behind the battery.
3)Type *#06# and press call button. It will display your IMEI number.
You can find the network provider to which your mobile is currently locked by switch off your mobile and switch on it again. A logo of the locked network will get displayed on your mobile screen. After knew all these get the code from the site Theunlockarena.com ,by submitting these to them. Unlock it yourself using unlocking instructions which is given in the site itself.
Jul 24, 2013 | RIM Cell Phones
Invalid sim card
It shows Sim Error or else Invalid Sim...Or even though Sim Inserted it asks "Insert Sim"
If it says anyone of the error like that means Your Mobile is Locked To Network ..You need T Unlock it to insert other Network Sim GSM Sim Card....
It may locked to some Network....You can get the code here
http://www.superunlockcodes.com/supported-phones/rs12wp7/ and Unlock the Mobile from the Network Lock....
I hope..You got solution...
Jan 21, 2011 | Cell Phones
My proble is i insert sim in mobile massage show please insert sim. my mobile model is m200 samsung
Hi, when a phone displays an insert sim message, it means that either the Sim card or the Sim tray where the sim card is inserted in the phone.
First, You can use the sim card on another phone to be sure that the sim card is still working properly. If the sim works with another phone, that means the sim tray where the sim card is being insert into the phone is bad and will need to be replaced.
You `can contact a skill personnel for help.
Have a nice day.
Sep 23, 2010 | Samsung M200 Black OEM GSM Unlocked Cell...
When i switch on the mobile it shows insert sim card
if you sim card is already in there try putting it back in there may be you inserted in the wrong way.
May 14, 2010 | Cell Phones
While i am insert new sim card my mobile profile
you need to have the phone check by a repairer for him or her to flash the Phone, I am sorry you may have to do that
Mar 10, 2010 | Nokia Lands Phones
When i insert the sim card , and then sitch on the
i think u should check ur sim jack
Dec 09, 2009 | Cars & Trucks
Insert sim card showing
Try your sim card to another phone, or try another sim to that phone just to eliminte the problem. Sim card are easily ruin by static discharge
Jan 03, 2009 | Motorola Mobility RAZR V3
INSERT SIM CARD
take the phone to a mobile service center and have them check the sim holder in the phone
Dec 18, 2008 | Nokia 6600
SE k750i is displaying insert sim even though sim is inside.
well... seem like you phone has got locked from the network may be accidently in case of stolen better check you service provider and if they say every thing is fine try to flash your mobile .it has some perticular number to flash it try these number *#7780# (password 12345)
Sep 01, 2007 | Nokia 3200
Nokia 1100 Logo
342 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
ASHRAF CA
ASHRAF CA
