Question about Sony PS-LX250 Turntable
Sony ps-lx250h belt-driven turntable runs too fast.
I have the 33rpm setting on for long playing records, and the turntable runs consistently a little too fast. I replaced the belt and it still happens.Any ideas?
  • Anonymous Feb 06, 2009
    Same deal here... did you figure it out?
    Genius:
  • 1,199 Answers
Is there an adjustment knob? if so use that! if not it will have to be adjusted from under the turntable!
this should fix ya!
Posted on Dec 12, 2008
Panasonic SL-HM42 turntable runs a bit too slow on 33rpm. Hasn't been played in a while. How do I the plate off to check the belt?
Most turntables need you to lift of the matt and then round the spindle is a horseshoe clip which you need to take off.
Aug 29, 2013 | Sony PS-LX250H Turntable
My turn table is going to fast when i play an record , what can i do to fix this? thanks
Hello the turn table has two speeds. 45rpm and 33rpm (rotations per minute) If you are playing a record that takes up the entire turntable you need to set it on 33rpm. For the records that only take up half of the turntable you want to set it on 45rpm. Setting the turntable on the wrong setting for a certain size record can make the record play to fast of to slow.
Mar 24, 2011 | Panasonic Technics SL-BD22D Turntable
My Sony PS-LX250H Turntable suddenly started playing records too fast for both 33 and 45 speeds. Any ideas on how to fix???
If this is a belt drive then most of these speed increases are caused by the belt being in the wrong position. The belt could be faulty and my need to be replaced. Otherwise it could be due to a power supply problem, such as a faulty regulator to the supply of the motor. A check on the voltage to the motor will determine this. Assuming you know what the correct voltage should be! Of course with luck it will be higher than the motor is supposed to run at.
Feb 02, 2011 | Sony PS-LX250H Turntable
My audio technica turntable is playing records too fast. how do i fix this?
there are two small holes under the unit labeled 33 and 45 that control speed. im guessing youre mainly playing lps so use a flathead jewlers screw to adjust the 33 setting until you get the right speed
Jan 08, 2011 | Sony PS-LX250H Turntable
The turntable motor runs but the turntable doesn't spin i'm not sure if the belt is on incorrectly or what help please. Sony ps-lx250h turntable
most platters are secured with a c clip in the middle --gently prying it off should allow the platter to be removed--than a little dexterity is required to reattach the belt to the pulley and around the bottom of the platter--if the belt is broken or stretched you can pursue a replacement at mcm electronics .com
Sep 04, 2010 | Sony PS-LX250H Turntable
PS-LX250H
Have you measured the stylus downforce. It usually is between 1 & 1.5 grams.
Apr 21, 2010 | Sony PS-LX250H Turntable
Adjusting calibration
try adjusting the anti skating device near the main tonearm pivot? set it another notch and try it again? if not repeat by setting another notch till your happy with the playback?
Apr 27, 2009 | Sony PS-LX250H Turntable
Sony PS-LX250H speed problem
I have a different Sony model (PS-LX-150H) that had a similar problem. I hadn't used it in awhile, and then when I did, I noticed the speed problem.
IF your PS-LX250 is like my PS-LX150, there are small speed adjustment screws accessible from the bottom of the unit. On mine, the two adjustment screws were labeled - one for 33rpm, the other for 45 rpm. Basically I just fiddled a bit with them using a very small precision screw driver until I could verify that I had reached 33 rpm (I used a stopwatch and literally counted the number of rotations/minute after making adjustments.)
Now it sounds right!
Mar 09, 2008 | Sony PS-LX250 Turntable
Sony PS-LX250 Turntable Logo
823 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
