Question about Microsoft Office Xp Professional Full Version With Adobe Acrobat 5.0 (269-04508 BUNDLE) for PC
Win32 Hi When i,m clicking on my hard disk any partition so written is there like if D: so D:/resycled/boot.com is not a valid win32 application
  • 1 more comment
  • Anonymous Dec 13, 2008
    got the same problem
  • Anonymous Jan 08, 2009
    nnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn
  • MoDyYy-89 Jan 14, 2009
    if D:
  • 54 Answers
Well it is a virus
they incorporate with your disk and when you click on them the virus function become open
left click on the drive like d and then search for boot.com
you will see a file will appear
delete that file
or try to scan with your antivirus
do as early as possible because it will spread to your all drives.
Posted on Dec 13, 2008
Am trying to install vista on my windows xp-sp2 but it gives "spinstall is not a valid win32 application......how to install then???
Are you doing a Dual-Boot? With a Separate Partition on the Primary HDD? I'm a bit confused? Are you doing a install on the Primary HDD and installing over the Win XP? Did you format the HDD? Or on a second HDD?
Mar 20, 2013 | Microsoft Windows Vista Ultimate Edition
Partitioning lacie hard disk 2.0 500 gb
Windows XP: Right-click on "My Computer" and select "Manage". From there, select "Disk Management" which lets you view the drives and do things to. More details here...
If you're on Mac OS: Here's how
Mar 20, 2009 | LaCie Hard Disk 500GB with Hi-Speed USB2.0...
Cannot access my hard disk from windows
Your windows system by default really has to be located on The C partition of the drive in order to self load.
Jan 30, 2009 | Toshiba Satellite P105-S6227 Notebook
Local Disk Problem
resycled/boot.com is a worm/trojan.DNSchanger that propagates on local fixed and removable USB drives. resycled/boot.com may infect drives via autorun.inf file it created that runs a command each time the drive is accessed. Malicious files will be copied to a drives attached on infected computer
http://www.tech-archive.net/Archive/WinXP/microsoft.public.windowsxp.general/2008-11/msg00153.html
Follow this link and do what the artical says to remove and fix. Good Luck. Please rate me thanks.
Jan 16, 2009 | Computers & Internet
Hi, recently i had virus in my comp called win32.worm.autorun.MQ i restored my windows through restore after cleaning up when i click on my drive it gives me error saying "resycled\boot.com is not valid...
This is a solution i found at another site that i think could help you with your probem
Hi
If you still need help with this please do following:
Download and install TrendMicro HijackThis
* Once installed open HijackThis by clicking Start > Programs > HijackThis and click the button labeled
Do a system scan only
* Click the scan button in the lower left hand corner of the interface and HijackThis will quickly scan your system.
* Once the scan is complete the scan button will now read save log. Click this button to save the log file to your PC. Once you select where you would like to save the file it will open in your systems default text editor. Typically this application is Notepad. Post the log here.
The link:http://www.techsupportforum.com/security-center/virus-trojan-spyware-help/hijackthis-log-help-inactive/306207-resycled-boot-com-not-valid-win32-application.html
Please let me know if you need more help with this problem
Jan 06, 2009 | Computers & Internet
My disk is showing not proper win32 applicaton
To correct and solve this error, follow this steps:
1. Run Task Manager (Ctrl-Alt-Del or right click on Taskbar)
2. Stop wscript.exe process if available by highlighting the process name and clicking End Process.
3. Then terminate explorer.exe process.
4. In Task Manager, click on File -> New Task (Run…).
5. Type “cmd” (without quotes) into the Open text box and click OK.
6. Type the following command one by one followed by hitting Enter key:
del c:\autorun.* /f /s /q /a
del d:\autorun.* /f /s /q /a
del e:\autorun.* /f /s /q /a
you plz enter the drive name of your hard drive same as above.
c, d, e each represents drive letters on Windows system. If there are more drives or partitions available, continue to command by altering to other drive letter. Note that you must also clean the autorun files from USB flash drive or portable hard disk as the external drive may also be infected.
7. In Task Manager, click on File -> New Task (Run…).
8. Type “regedit” (without quotes) into the Open text box and click OK.
9. Navigate to the following registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
10. Check if the value name and value data for the key is correct (the value data of userint.exe include the path which may be different than C drive, which is also valid, note also the comma which is also needed):
“Userinit”=”C:\WINDOWS\system32\userinit.exe,”
If the value is incorrent, modify it to the valid value data.
May 19, 2008 | PQI Intelligent Stick (267027) Hard Drive
D:\ application can not run in Win32 mode
hi
go to start-run c:
if u can open it your sys is malware infected if u hace winxp sp2 pro and fat32 or ntfs partition.
scan your sys with avast ,qiuck heal and symantec update
Mar 26, 2008 | PC Chips (M925G) Motherboard
Microsoft Office Xp Professional Full Version With Adobe Acrobat 5.0 (269-04508 BUNDLE) for PC Logo
81 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
