Question about Belkin Computers & Internet
Bought a wirless router to find that the cd to setup will not run on Windows 98 can you help!
  • zabrina liang May 11, 2010
    Windows 98 is pretty much no longer supported. what model is your wireless router and the manufacturer just may be able to work with your os because some routers are designed to work with any os
  • Belkin Master
  • 4,806 Answers
The router is not supported by Win98, you will have to upgrade the OS to XP, check this by looking at the system requirements on the router packaging
kind regards
Posted on Dec 12, 2008
Lost my belkin setup cd for my wirless router connect n150 dont need the manual i need the download
Sir Lost My Installation cd, Belkin, Wireless Router Model : F5D7231-4, FCC ID : H8NRT2406W. Pl Provide Software
Dec 31, 2010 | Belkin Basic Wireless Router
Tip
Setting up Wireless on router and wireless security
For setting up any router you can follow the below simple steps
  1. Connect the router with a power cable and switch on the poser, reset the router with its reset button normally you can find the reset button on the rear side of the router for 30 seconds and then switch off and on the power
  2. After reset conenct the router to any laptop or desktop with a cable and also connect the router to the modem or the internet service provider cable
  3. after all connection lights will come on go to right hand side corner of the computer and check if the network connection is showing connected
  4. Once you are connected with a wired connection open a page of internet explorer and type in router addess normally it will be http://192.168.1.1 or http://192.168.0.1 and then type the username and password default usernames and passwords can be found in router manual.
  5. Once the router setup page is open you can confugure the router easily without the CD setup.
  6. The advantage is you do not have to run the setup CD and you can also do wirless settings for your wireless laptops or devices
  7. Go to the wirless settings page and you can select the wireless on and off or you can setup a wireless security to avoide your router with unauthorized acess
  8. I would recomend always keep the wireless network secured if you are using the router for a home or small office as there can be people who will be using your bandwidth for free without your permission
  9. one more tip i would like to give whenever any kind of setup is required on the router do it by a wired connection only and not thought a wireless pc or laptop as it can disconnect you from the router in between of your setup
  10. WEP is the kind of wireless security which is easy to setup and remember and most wireless cards of laptops and computers support it
All the best with your wireless router configuration and security setup
Regards
Vikram
on Dec 02, 2009 | Computers & Internet
Wirless router problam
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
OR
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Click Here for step by step instructions on how to connect to the wireless network and troubleshooting steps
Nov 30, 2009 | D-Link DIR-625 (790069292637) Wireless...
I have a Tosiba Laptop that is wireless to my desktop but now I bought a new HP wirless Printer and it want my WEP key. Nothing on the router helps, tried all three numbers. What do I do?
The WEP key is the security key that you setup when you initially setup your router. w/o that key you won't be able to connect. if you can not remember the wep key; enter the setup of your router. u will see it there under the security setting tab.
^_^
Sep 12, 2009 | Computers & Internet
Part # F5D8233-4 belkin wirless router need software cd
You don't need the cd. It has a connection wizard that helps set it up but you don't need to use that. You need to go to the belkin website and download the manual. That was also on the cd that's missing. Used to be a paper one in the box.
http://cache-www.belkin.com/support/dl/f5d8233-4_v1_manual.pdf
That will tell you how to get setup. For the most part routers run as is right out of the box. You will want to setup the wifi so you will need a SSID name to call it and then turn on the security. WEP or WPA are the usual suspects. Pick a 5 or 10 alphanumeric key. Turn on the wifi. Then you may need to enable dhcp so your computers will get ip numbers from the the router. Most of that is enabled by default on most routers. Wifi usually isn't as it requires more information.
Jul 21, 2009 | Belkin (F5D72304F5D7000) Router
Belkin N1 Wireless router wont fully connect to laptop
if you connect your xbox and it works than it is not your isp
go to your network setup and try it with fix ip and DNS to you vista laptop wirless card /fixed card ip setup
goodl luck get back if this does not work with more info on your network setup
Jun 12, 2009 | Belkin (F5D8231-4) Wireless Router...
Huawei wirless modem
Click the below link ,click on download and download the file and run please do let me know.
http://www.bioticaindia.com/huawei-wireless-modem-153-6k.html
Dec 25, 2008 | Computers & Internet
Need help
Since your laptop is working fine with another wireless network , so it only means the problem here is with the router, you can try first to reset the , to reset it Press and hold the reset button for 15 seconds then after that you need to run the setup CD for the router to reconfigure it back.....
Nov 12, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Reconfiguring rouer
If you have the setup CD you can just run it to your computer and let it reconfigure the router for you, but if you don't have the setup CD you need to manually configure the router by accessing its IP address using the computer that is wired directly to the router....
Nov 05, 2008 | NetGear WGR614 Wireless Router
Install Xp From Dos
If XP will not install from the CD or if you have a new drive with no operating system onit yet try these:
Install Windows XP from the hard drive with Windows 98 already installed:
Boot Windows 98
Insert the XP CD into your CD reader
Explore Windows XP through My Computer
Copy i386 folder to C:\
Go into C:\i386 folder and double click on winnt32.exe to launch the setup from the hard drive
Install Windows XP from DOS (ie. no OS on a new hard drive):
Boot with a Windows 98 Start Up disk
Insert the Windows 98 CD into the CD reader
Run smartdrv.exe from the Win98 directory on the windows 98 CD (file caching)
Type cd.. to back up to the root directory
Insert Windows XP CD into the CD reader
Copy the i386 folder to C:\
Go into C:\i386 folder on C: and type winnt.exe to launch the setup from the hard drive.
Oct 20, 2008 | Computers & Internet
Computers & Internet Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
