Staple location Where do i put staples on my dialta Di 450 photocopier?
  • Anonymous Mar 31, 2014
    What is code c0510?LOW FUSER TEMEPERATURE? how to repair?
  • 1,326 Answers
The staplers are in the sorter, open the front door of the sorter and there is one toward the front and one toward the rear of the copier. They are marked with a Green Handle, you push up and they pull out. You may need a flash lite to see them. The inside of the door should show you how to install the new staples. Once they are installed the copier will run a staple test. Let it and if one of the two jam try to reinstall them again... Good Luck
Posted on Dec 13, 2008
How to put back together
Stanley Model TR45 Light Duty Staple Gun Review - YouTube
? 3:35
https://www.youtube.com/watch?v=hWmvXhkqnYI
Jul 25, 2012 - Uploaded by Vansvideoreviews
Stanley Model TR45 Light Duty Staple Gun Review ... How toPut Staples in a Craftsman Stapler (Model 968447) ... Stanley SharpShooter Manual Staple and Brad Gun review - Duration: 9:35. by Unpack Guy 35,948 views.
How to load staples into a Stanley Stapler - YouTube
? 2:11
https://www.youtube.com/watch?v=j4Q5W0uKS-s
Mar 26, 2013 - Uploaded by David DeStefano
This video shows you how to load staples into a Stanley StaplerModel # TR110. ... Stanley SharpShooter Manual Staple and Brad Gun review ...
put stanley sharpshooter staple gun back together ... - Fixya
www.fixya.com > Forum > Tags
Find solutions to your put stanley sharpshooter staple gun back together question. ... staples for the TRE500 Stanley Sharpshooter Electric Heavy Duty Stapler.
Dec 10, 2015 | Stanley SHARPSHOOTER HEAVY-DUTY STAPLE GUN
Help please! I have a Paper Pro high capacity stapler that will not staple. I can open it up and put staples inside, but no staple will come out when pushed down. Oddly enough, if I put ONE staple inside...
are you using the correct size of staple?? (thickness wise) secondly check the spring is pushing as it should, also a fix to get it working is as you put the staple stack into the stapler, seperate them and see if will staple. other than that it's defective and you should purchase a new one.
Oct 30, 2013 | Staples PaperPro 1200: Heavy Duty Stapler
How do you load staples into stanley tr70 staple gun?
The first thing you can do is to remove the lock of the staple holder which you will find at the bottom part of your staple near at the holder of the staple..after you remove that holder the next thing you will do is to get one of the staple and put it in..after that you can put again your lock of the staple and you can use it..thats the way how to put the staple nail..
i hope it can help you..
Jun 05, 2011 | Stanley TR250 H Heavy Duty Heavy Duty...
How do I load staples into the Minolta Di 2010f copier?
Follow instruction on door. Push in on both sides of staple cart pull the top up install the new staple pack dont pull string on staple pack until its inside. (Staples on the floor:)) Don't throw away the plastic cart itself insure the arrows on the new staple pack match the direction on the old run or the staples will be upside down and not able to get out of the pack
Aug 17, 2009 | Minolta DI-2010F Copier
How to remove jammed staples in staple gun?
Take out the small bolt that is secured with a nut at the back of the gun (at the end where you feed the staples) -- then drop the inset. Now you have access to the jammed area. Clear out jammed staples and put the stapler back together. Easiest way is to hold the nut and turn the bolt from the other side.
Jun 16, 2009 | Arrow T50P ARROW STAPLE GUN
Will not staple
Hello sir; Remove the staple cartridge check there have left over used staplers , just dump it out,also need to check vertical lifting motor moving smoothly.
Jun 01, 2009 | Ricoh Aficio 450 Copier
Need help on how to put staples in Ace staple gun 22084
At the very botton of the stapeler in the back there should be a square mechanism press in and down then just slide the staples in and eplace the mechanism the way you took it out
Dec 03, 2008 | Ace Hardware Ace Staple Gun
Staple gun support
Know the types of staple guns available. They can be manual, electric, battery operated or run by compressed air with an air compressor. Some staple guns have guide wires because they’re used by electricians that can’t pierce wires. Others have long noses to work well in corners and tight spaces. There’s also a reverse built ergonomic staple gun called a "forward action" because the handle and the staple’s exit point are on the same end of the staple gun. Some staple guns can shoot brads instead of staples. Know how each type of staple gun works. This one is so simple because it works just like a stapler. You press and hold the silver latch on the back of the stapler to open the body. Take the tray out and fill it with staples. Then it’s ready to use. Just put the staple ejecting end on your piece to be stapled and squeeze it. There is also the forward action manual gun which is used by pushing the handle down, too. The handle is just located near the staple ejection site. Use an electric staple gun for effortless stapling. There’s no need to squeeze or apply any pressure on these guns. They come with a very short cord so you will always need to have an extension cord with your staple gun. You can also go with a rechargeable battery operated cordless staple gun. They are great but they do run out of steam so for long use one with a cord is better. They’re also pretty easy on the wallet these days, so there’s no reason to go without this in your home tool kit as it’s something that does a lot of jobs. Know the versatility of the staple gun. Whether you have a manual or an electric model, these are some of the most versatile tools out there. You can use them to recover furniture, to build a birdhouse, to staple lattice to a patio, to build lightweight projects like a small knick knack shelf and to do wiring work.
Aug 27, 2008 | Black & Decker 5700 Powershot Forward...
145 people viewed this question
k24674
jasbo
jasbo
