Question about E-Machines T6216 (827103077834) PC Desktop
Blueish green lcd monitor - I have a E machine model T6216
And after it runs for a short time the monitor turns a blueish green.I tried another monitor and new cables with the same results.I hope you can help with this problem.Thanks
  • 4 Answers
Sounds to me like you need a video card to me, You may try reinstalling the drivers for your present video( I am assuming you are using the integrated video ),all drivers for your PC can be found here http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T6216
But I bet you are going to either have to replace the motherboard or buy a video card. According to the specs you will need a PCI Express X16 card. Here is one possibility for 31.00 plus shipping after rebate http://www.newegg.com/Product/Product.aspx?Item=N82E16814130419
or you can pick one from this list http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010380048%201069609641&name=PCI%20Express%20x16
Posted on Dec 12, 2008
    Sergeant:
  • 236 Answers
Emachine T6216 onboard video is shot (nothing on known good monitor) Have installed new PCI-Ex16 graphics care. Need to disable onboard video. Is there a jumper on motherboard?
Have you tried entering BIOS? I beliveve that you have to press and hold F1 during boot to enter BIOS. Once in there you should be able to disable onboard video card.
Apr 20, 2010 | E-Machines T6216 (827103077834) PC Desktop
My whole screen has a blueish green tint
  • Make sure the plugs are hard into the sockets, one loose pin can cause strange colour problems.
  • A faulty signal cable between PC and monitor can also cause colour problems, try a different cable if possible
  • Try it on a different computer to find out whether the computer or the monitor is the problem. If it's the monitor and none of the above works, it will need service or replacement. If it's the computer, your video card is likely to be the problem.
Apr 09, 2010 | Samsung Syncmaster 940BW LCD Monitor
I don't know what happened but my monitor is blueish and not shar
pepsi_2_cola, If after reseating the vga plug to vga connector 3-5 times and the problem still persists, you will need to see about having the unit refurbished with new "switch-mode-power-supply"/ "inverter board" and possibly new "cold-cathode-fluorescent-lamps" installed. visit YOUTUBE before doing the refurb thing! Search and view vids on "lcd monitor disassembly" , "lcd monitor repair" the longer ones are more imformative. then get back here with what you have learned about how lcd monitors fail with age and amount of total "ON" hours of use. please state the age of monitor next time! a gateway 1975 could be 4-6 years old! It could also be time for a new one! You DO KNOW that those "cold-cathode-fluorescent-lamps" don't last forever!!!!! 12fixlouie If this was of any help please rat this response on fixya.
Nov 07, 2009 | Gateway FPD1975W 19" LCD Monitor
My 5 yr old daughter's monitor now has a blueish green cast to it. It is a PL2010M. Did she change a setting (very likely) or is there a problem?
To find out, I would browse through the on-screen menu using buttons on the monitor to find an option "Reset to default" or "Factory Settings" or something to that effect.
Oct 26, 2009 | Planar PL2010M 20" Flat Panel LCD Monitor
Monitor screen changes from regular color to a green tinted screen?
Looks like you need to purchase a new monitor. If it's too worn out then it's the outcome. I also had the same problem before and I ended up buying a new one. You should not experience that thing if it's new.
May 27, 2009 | Dell 1503FP 15" LCD Monitor
NO VIDEO
try changing the memory cards if any one slot got the problem, clean the slot area from the ram., reset bios conf., it works
Mar 26, 2009 | E-Machines T6216 (827103077834) PC Desktop
Power button is flashing green
These models are prone to shorting of the inverter drive transistors, 2sc5707. An in-circuit ohm meter test will reveal which are shorted if any. They should be replaced in pairs even if only one is shorted. Bad solder joints on the transformer can cause them to short so look for bad solder.
Monitor Mike
Jul 14, 2008 | Dell E173FPb 17" TFT LCD Monitor
AL2216W LCD monitor "Power status Green blinking" & No display.
LOOKS LIKE A BURN SOLDER !! , open the monitor , check the PC BOARD around the transformer area , look for burn spot or cold solder , RE solder it , try again , hope this helps please rate solution and thanks AJ
May 06, 2008 | Acer AL2216W LCD Monitor
Blueish screen
From your monitor menu, check your monitor color temperature. Is it 9500k or 6500k?
Try setting it to 6500K
Dec 31, 2007 | BenQ FP731 17" LCD Monitor
Monitor Black, Green Power Light Flashes Monitor is 4 yrs. old
Assuming you've already checked your driver and system settings, tried a different monitor, and checked the cable and connector pins, this would almost certainly be a problem with the power or signal circuit board inside the monitor.
Jan 19, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
E-Machines T6216 (827103077834) PC Desktop Logo
173 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
