I have a hp mediasmart home server. When the machine boots the health indicator lights blink 5 red and then a flashing blue. I suspect that the system boot drive is damaged (it is clicking). How do I go about fixing this? Michael Gibson
  • 111 Answers
If it is clicking it is bad, replace it
Posted on Dec 21, 2008
Health lights blinking red
You say the "health lights" blinking red. If this is the power light on the front then it can blink at different rates:-
Flashing red (2 blinks) Thermal event (THERMTRIP#).
Flashing red (3 blinks) No CPU.
Flashing red (4 blinks) Crowbar.
I'm not quite sure what they mean by "Crowbar"
The user manual can be found on this link:-
http://h20565.www2.hp.com/portal/site/hpsc/template.BINARYPORTLET/public/kb/docDisplay/resource.process/?spf_p.tpst=kbDocDisplay_ws_BI&spf_p.rid_kbDocDisplay=docDisplayResURL&javax.portlet.begCacheTok=com.vignette.cachetoken&spf_p.rst_kbDocDisplay=wsrp-resourceState%3DdocId%253Demr_na-c00448584-2%257CdocLocale%253Den_US&javax.portlet.endCacheTok=com.vignette.cachetoken
whilst the link below gives you a list of the available documentation for download:-
http://h20565.www2.hp.com/portal/site/hpsc/public/psi/manualsResults?sp4ts.oid=501887&ac.admitted=1403517641801.876444892.492883150
Jan 18, 2014 | HP ProLiant ML110 G3 Server
External health lights blinking 4 red lights
one of the wires inside is not in the right place or theres a faulty hardware
Hp w2408h monitor flashing red green black blue white
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 10, 2014 | HP W2408H 24-inch Widescreen LCD Monitor
ML350 G3 S/board CPU Error Amber LeD + Internal Health Error
You will continue to get internal error until you add memory. It shouldn't even boot without RAM.
Feb 04, 2013 | HP ProLiant ML370 G4 Server
Proliant ML350 g4 internal health led: red and green alternate
Open the case and turn it on. There should be corresponding red light indicator inside or possibly the back.
Dec 03, 2012 | HP ProLiant ML350 G4 Server
HP mediasmart EX470
Hello it depends on your current operating system.This could have happend after the update from MS yesterday.
It looks like a failed update.
Here is a link if you are running server 2008:
http://serverfault.com/questions/362759/server-2008-stuck-in-reboot-loop-configuring-updates-stage-3-of-3
Good luck
Nov 13, 2012 | HP MediaSmart Server EX470 (GG795AA)
On one of our HP DL360 G5 systems every time after soft reboot the server cannot be booted back. This is 100% reproducible also with Cold boot. Can someone help us find what internal component is...
The simplest way is to check Insight Manager. Type localhost:2301 on a web browser locally. Or, servername:2301 for remote access. You need local Administrator password.
Insight is only available if it was set up with a Smart Start disk. It's that pack that comes with all HP servers, but can be downloaded as well. Best practice is always install.
Don' know what IML is, and ILO has no baring to problems.
There is Insight Manager link on specs.
http://h18004.www1.hp.com/products/quickspecs/12476_na/12476_na.html
Nov 12, 2012 | HP ProLiant DL360 G5 Server
Battery light flashes blue once, orange once. Manual says battery overheated and let it cool. Been cooling for 3 1/2 hrs unplugged from anything and still nothing. No power..and blinking blue to orange...
With battery in, boot to the BIOS, check indications under battery health. I'm pretty sure it will indicate battery decline/failure which will mean, replace the battery.
Feb 10, 2010 | Dell Inspiron 1525 Notebook
Internal led of ML350 server is glowing.......how do i resolve it?
Hi Franceso, plz specify
Is it powering ON ?
Which LED is glowing?
These leds are there on the front panel :
1 Power On/Standby button
2 System power LED
Green = Power on
Amber = System shut down, but power still applied
Off = No power
3 Internal health LED (Wave sign in BOX)
Green = Normal
Amber = System degraded. To identify the component in a degraded state, refer to system board LEDs.
Red = System critical. To identify the component in a critical state, refer to system board LEDs.
Off = Normal (when in standby mode)
4 External health LED (power supply)
Green = Normal
Amber = Power redundancy failure
Red = Critical power supply failure
5 NIC 1 activity LED Green = Network link
Flashing = Network link and activity
Off = No link to network.
6 UID LED Blue = Activated
Flashing = System remotely managed
Off = Deactivated
7 UID button
If it is Internal health led then any internal h/w issue is suspected.
If it is external health led then any power supply or power source related issue is suspected.
Also check the status of the server & its IML (Integrated Management Logs) in ilo (Integrated Lights Out ) if it is configured. (2nd RJ45 port in rear)
Also make sure the cabinet is properly closed.
Nov 18, 2008 | HP Compaq ProLiant ML350 G3 Server
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
