Question about Sony Audio Players & Recorders
Sony DE445 receiver/ "protect" on screen and shut off
I ran speakers through wall and speaker wire does not have positive or negative markings,by conecting a positive from receiver to a negative on speaker would this cause receiver to display protect and shut off. And if so is there a way to check which wire is positive or negative.
  • 979 Answers
What type of wire are you using?
Posted on Dec 12, 2008
Protect mode
Check if speaker positive and negative terminals are not connected to each other creating short circuit, PROTECT MODE occurs when speaker wires touch each other.
--SS.
Oct 14, 2013 | Sony Str-Se501 Stereo Receivers
I need help my sony str dec 445 keep flasking the protect on the display
first check for any loose speaker wire in the back as this will cause the unit to go into protect mode if the bare speaker wire is touching, if thats not the case then there is a problem with the unit internaly and would be hard to tell whats wrong with it without looking at it.
Dec 11, 2009 | Sony STR-DE445 Receiver
How do I hook up my Bose 901s to my Sony Receiver Model STR-DE545?
look at your speaker wire there should be some marking the distinguishes each wire. You need to get this right make sure the negative or black color from the speaker is connected to a negative or black of the receiver. ditto for the positive (red). look on the back of the receiver you should see where the speakers get connected left, right.
Oct 24, 2009 | Bose 901 VI Main / Stereo Speaker
I have an Onkyo AV Receiver and every time I push a button(input selector, turn speakers on or off...anything) the whole system shuts off but i can turn it back on immediately and it's fine till I hit...
Onkyo & Harmon Kardon it a very nice unit and it built very professionaly and very sensitve unit. Its very important that you make sure the correct pole is connect correctly when it come to speakers. the unit come with resetable breakers inside the receiver (safety protection) so you wont blow or short the unit if not connected up correctly. when wiring speakers up from an to the receiver you have to make sure the poles are hook up correctly. positve speaker wire go straight to positive plug behind the receiver same as negative. the speaker wires should have some kind of making on it to mark as either positive or negative. try that and see if that help, if nedd more help.
Oct 02, 2009 | Yamaha RX-V596 Receiver
DE 445 flashes "protect" and sound goes off when loud noises play on DVD
Check your speaker connections at the back of the receiver and at the speakers. You have a short. If you don't see anything obvious, disconnect your speakers at the receiver and play a dvd and turn up the volume. If it stays on, you have a wire or a speaker problem. If it cuts out , you have a DSP chip problem. Reconnect speakers one by one and test each speaker until it cuts off or you have fixed the problem. If you still have issues, post a comment and I can help you some more.
Aug 07, 2009 | Sony STR-DE445 Receiver
Trying to use a passive subwoofer with STR-DE445
The output of the Sony is "signal only" not power. Being "passive" like your sub. What you need is a sub amp, and they are not cheap, 400-600 on average "min". Unless you have a Velodyne 15 or 18, just get an amplified sub, they start around 150 new. Hope this helps
Mar 27, 2009 | Sony STR-DE445 Receiver
PROTECT DISPLAYED ON RECEIVER
This generally means you've got a short somewhere, and the received is trying to protect itself.
My suggestion is to disconnect all of your speakers at both ends, and reconnect them.
Most times this happens because a speaker wire is lose, and the positive and negative connections are touching each other, causing it to short out.
Mar 24, 2009 | Sony STR-DE485 Receiver
Speakers pop and rear speakers cut out of surround sound
your problem is a bad solder connection of the relay linked to the lautspeaker sockets. I had the same problem and googled for the solution. Since I resoldered the pins everything is fine. That problem is well known and happens to a lot of Sony receivers.
I can send you a link with a detailed how-to-do solution with pictures, however it's written in german language. But you can use some online translators.
Here is the link: http://www.bmw-syndikat.de/bmwsyndikatforum/topic.asp?TOPIC_ID=28280&FORUM_ID=20&CAT_ID=9&Forum_Title=Geplaudere&Topic_Title=Problem+Sony+STR-DE445
Ralf (from Germany)
Jan 07, 2009 | Sony STR-DE445 Receiver
Sony STR-DE445 protect displayed
It sounds like a bad solder connection. It just needs to be soldered up, if you take it into a shop just tell them it doesn't need any new parts, it just needs to be soldered up.
Or, if you can solder it yourself, or know someone that can, that would be much easier.
Aug 04, 2008 | Sony STR-DE445 Receiver
Amp switches off at about -10db volume level
I suppose that on all speakers connections + (positive) is on +, and - (negative) is on - ?
Oct 08, 2007 | Yamaha HTR-5830 Receiver
120 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
