Question about Maytag Washing Machines
WHEN I TRY TO DO A LOAD OF LAUNDRY AFTER A FEW MINUTES IF FLASHES F 02 SO I STOP AND RESTART IT BUT A FEW MINUTES LATER IT DOES THE SAME THING. WHEN IT FINALLY FINISHES I AM LEFT WITH SOPPING WET CLOTHES THAT I HAVE TO WRING OUT BEFORE I CAN PUT THEM IN THE DRYER.
Went to a different web site
Posted on Dec 13, 2008
The machine constantly displays the oL code when it r
Hi Randall:
If your the error reads OL, it's "overloaded" and you need to remove some items to delete this problem.
Definitivelly, this flashes when the machine or motor control detects a load size that exceeds the washer's capacity. To clear the error open the door lid and restart the cycle by removing excess laundry. If error doesn't clears then unplug the washer for 5 at 10 minutes and check.
Jan 30, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
How do you stop the cycle immediately after starting (found a sock that needs to be added in the washer) and then re-start wash cycle
You can only add items to the wash for a few minutes after that washer starts. If you found something you want to add you have to restart the cycle. This is a safety feature added to the front load. After the washer is full of water it doesnt allow the door to open so the water in the machine doesnt flood you laundry room.
Jul 15, 2011 | Asko W6021 Front Load Washer
Code ol
Hi
Error OL means overload. oL flashes when the machine/motor control detects a load size that exceeds the washer's capacity. To clear the error open the door lid and restart the cycle by removing excess laundry. If error doesn't clears then unplug the washer for 5-10 minutes and check. Hope this helps... Please post back if you need more information.
Daniel
Nov 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer stops and blinks OL even with just a few items
HI. OL flashes when the machine/motor control detects a load size that exceeds the washer’s capacity.Open the door lid to clear your display and remove the excess laundry, then restart the cycle. Be sure to not overfill the unit or this will occur once again. Overloading the unit will damage the motor.
Aug 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Door won't open
If you can drop down drain hose to floor level then drain into bucket this will allow you to open the door . Sounds like coin in the pump /remove the filter and clean check pump blades are free...Good luck
Apr 28, 2010 | Whirlpool GHW9100L Front Load Washer
Stop frequently on spin and rinse cycle F6 code
I have a Kenmore Elite he4t front load washer that was working fine and then we moved and now it stops washing midstream and flashes an F and a H. I have to pause and restart then it will stop washing again after a few minutes and flash the same codes again. I reset again and then it stops with 1 minute left and will not drain.
Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
F02 code flashes and stops rinse cycle
Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be disp NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the displaylayedPress PAUSE/CANCEL twice to clear the displayCheck the drain hose and make sure it is not plugged or kinkedCheck the electrical connections at the pump and make sure the pump is runninCheck the drain pump filter for foreign objects.g. If the above does not correct the problem, replace the pump.
Jul 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
02 jeep laredo will idle for about ten minutes and stop
does it restart on its own? or do you have to restart it?
Feb 08, 2009 | 2002 Jeep Grand Cherokee
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
