Question about Formac Gallery 1740 Oxygen 17.4 in. Flat Panel LCD Monitor
How do I open up my Formac monitor?
My monitor is out of warranty and has just ceased to work. It will cost me too much (more than the cost of the monitor) to send it back to Europe to be looked at. I have found a local guy specialising in fixing monitors, but he says the unit is sealed. Anyone know how to open one up? Thanks
5 Suggested Answers
  • 4 Answers
SOURCE: Formac Gallery Monitor
Looks like the water is getting in to the LCD contacts. Or corroding them. If the monitor can be opened safely open it and place in a warm dry environment for a few days. Silica dehumidifiers may help.
If the issue is not permanent this may fix it.
Posted on Feb 27, 2008
SOURCE: backenlight inverter panel failure formac gallery 1900 oxyg
mine had the same problem, replaced the fuse with a T2.5 amp.
Ammeter gave a reading of 1.6A across the fuse pads so we shall see if its pops...
Posted on Oct 18, 2008
benwabnick
  • 2404 Answers
SOURCE: my formac dvi monitor wont work as a 2nd monitor for my laptop
Try a monitor that has a vga output only, sometimes these laptops can't recognize the difference when there is a converter involved. It doesn't see the signal properly.
Try that and if a regular monitor works with vga then you know that monitor may not be compatible with that laptop because of the converter. You could also try another converter as well to see if that fixes the problem.
Posted on May 07, 2010
SOURCE: i need a new power supply for a formac 1900
I've got two and you are welcome to one if you pay pp plus a sensible offerI live in South London UK
Posted on Oct 13, 2011
I need a new power supply for a formac 1900 monitor
May 19, 2011 | Formac Gallery 1900 Oxygen 19" LCD Monitor
This Formac monitor had some screen brightness issues for some time and then one day just went dark. The video card is ok, because it drives other monitors just fine. I checked the formac power supply...
was you check your monitor cable??maybe it because your monitor cable didn't connect properly
i hope this helpfull
please rate my answer
thanks
Dec 24, 2010 | Computers & Internet
Suddenly, after no previous problems, when computer (Mac- G5, older, not intel) started up in the morning, the monitor, although power light on, displays only black screen. Monitor is lcd Formac- not...
Try hooking it up to another PC first, but more likely to have failure in the power supply caps or failed inverter cicuits.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 01, 2010 | Formac Gallery 1900 Oxygen 19" LCD Monitor
The monitor has power, but there is no picture. can this be repaired?
May 24, 2010 | Formac Gallery 1900 Oxygen 19" LCD Monitor
My formac dvi monitor wont work as a 2nd monitor for my laptop
May 07, 2010 | Formac Gallery 2010 20.1" LCD Monitor
Burning smell from vent at top of monitor, accompanied by rapid and intermittent flashing of indicator light beneath power on button... Is this fatal..????
means that there are capacitors going bad inside of the unit. It could be fixed by taking it to a repair shop but you need to see if the cost of the repairs are going to be more then the cost of getting a new monitor.
Jun 28, 2009 | Formac Gallery 1740 Oxygen 17.4" LCD...
Backenlight inverter panel failure formac gallery 1900 oxyg
Aug 01, 2008 | Formac Gallery 1900 Oxygen 19" LCD Monitor
Gallery 1740 Trips out my G5
Right I got my formac monitor open by removing the Bezel, it's tricky but not too hard. The casing is suprisingly flexible and forgiving. The clips are backed by a double sided tape on all four edges. Start from the top and give the tape time under tension to come unstuck, it will, a bit like a plaster.
Oh yes, unplug before continuing.
Inside there are four HEX #4 (5/64 inch) screws holding the display inside the chassis. These can be removed, on the back side of the panel is the power/controller board. And remaining in the chassis is the Cold Cathode power board (long thin one on one side). This can be unplugged to get more range on the cables. (remember which way it goes in, I use a marker pen over the plug and socket to show me where to put it back) The Controller board has a number of power components. Firstly there are 5 power diodes, they all seem to respond properly under a meter in my screen. There remains one linear voltage regulator LT1117 and two 500Khz Step down switch mode regulators, LT1374. These devices are most suspect for causing the over current draw. Replace them if you can do this with ease. However most regulators have inbuilt protection. So it is also possible that a support component such as a resistor or capacitor has failed causing the other components to operate outside of their intended parameters. I will post some pics of the board later.
Dr Matt
Feb 24, 2008 | Formac Gallery 1740 Oxygen 17.4" LCD...
Jan 27, 2007 | Formac Gallery 1740 Oxygen 17.4" LCD...
Formac Gallery 1740 Oxygen 17.4 in. Flat Panel LCD Monitor Logo
79 people viewed this question
Top Formac Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Formac Computer and Internet Expert? Answer questions, earn points and help others
