Tv automatically starts scrolling through channels.
It seems like the channel up button is stuck. We removed the batteries from the remote and it still scrolls. We also deleted all but one channel on the tv and it still blanks out like it is scrolling.
  • 27 Answers
Go through your tv menu and do a auto set channels once this is completed everything should be fine it takes about 10 min
Posted on Dec 12, 2008
46xbr kdl hi for some reason my tv as froze on channel 44...it is set in the programs list and i cant remove it...
you could try returning in all of your channels from the main menu the tv can do this automatically but you need to select the procedure
1. click on the home button
2. scroll sideways till you reach settings
3. in settings scroll down or up and click on digital set-up (centre button of your scroll control)
4.then scroll down to, and click on digital auto tuning (centre button of your scroll control) this will activate automatic channel tuning the tv will do the rest and will wipe out old settings and retune in all channels
Jun 03, 2013 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
I have a Samsung LN32B360 LCD TV. It is less than 2 years old. Today when I switched on the TV, the channels started scrolling automatically in reverse order. It is not accepting the remote signal it seems...
Hello; Samsung thought it was cute to use "touch control" Circuit boards at the set for basic functions like power on/off channel up/ down etc , but they **** at the design of doing this. One function can be stuck on like vol up/dn or anything else. The set has a microcomputer in it that can only accept one command at a time. first take the batteries out of the remote to eliminate it as the cause. Most states have "fitness of merchantability law to protect you against this junk! call the state you are in for protection laws FIRST. If no help, open the TV and find the cable to the buttons at the set and unplug it to see if problem goes away.
Aug 12, 2011 | Televison & Video
Channel changes automatically. None of the buttons seem to be stuck. Please help.
To troubleshoot this first ake the batteries out of the remote. If the changing of channels stops then the fault is with the remote not the television. Replace new batteries into the remote and see if the issue is resolved. If it continues go around each button pressing and releasing it - if the problem persists you will need to purchase a new remote.
If the problem continues even with the batteries out of the remote then you have a faulty tuner on the TV and this will need to be replaced.
Thanks for using FixYa.
Jan 19, 2011 | Televison & Video
TV keeps scrolling through the channels and won't stop. I cannot use the remote. I have unplugged everything, and I took out the batteries in the remote--nothing worked. To turn off the TV, I have to...
I think one or two buttons on the TV is stuck in and that should be the channel button. Its pressed in that's hy it keeps scrolling.
Disassemble the TV, remove the TV board carefully to get to the channel button, free the stuck button and TV should be okay again.
Note that TV stores a lot of current, so wait a bit before opening the back cover to avoid electric shock.
Good luck.
Jan 01, 2011 | Televison & Video
TV stuck on one channel
Remove batteries from remote, and test again the touch buttons on TV with remote batteries out. This to exclude the possibility that remote has a stuck button.
If the problem persists , then it is probably a faulty IR board on TV (the one that gets IR signal from remote), or a faulty touch button switch.
May 16, 2009 | iLO 3200 32 in. LCD Television
There are a few things that can cause this. #1 most often cause is either something spilled on the channel button or something wrong with the bezel where the buttons are located causing the button to be pressed all the time. Check the buttons on the tv and make sure none of them are stuck. #2 is a bad button (switch). Replace the switch or the control board. #3 is a short on the wiring harness going from the switch to the mian board. Maybe it's squished against the frame somewhere. #4 would be a bad main board. You will likely have to take this unit to a service centre to have it looked at.
Apr 14, 2008 | ViewSonic NextVision N2010 20 in. LCD...
I am stuck on channel 2
some tv's default to channel 2 after being unplugged.since it is a older tv ,the buttons on the remote and the tv maybe worn down.on the tv itself try pushing the buttons down a liitle harder. if you have aux or line in/video inputs,scroll down on the channel button to log into a aux channel for the dvd player.as for the remote try buying a cheap universal remote to see if that works.
good luck
wg
Feb 02, 2008 | Zenith A25A23W 25" TV
TV changing channels
check channel up & down buttom if stuck up. if not, replace eeprom as possible. good luck!
Nov 27, 2007 | Insignia NS- 27" TV27 TV
Turn tv on, and it scrolls through the channels
Had the same problem, channels would not stop scrolling.
It was as though someone had there finger on the channel up button.
Disconnected the sixth wire, starting with the black wire on the wiring harness for the front buttons, on/off, ch. up/down, vol. up/down, etc.
It works fine, no more unwanted channel surfing!!
Aug 29, 2007 | GE 32GT740 32" TV
Televison & Video Logo
143 people viewed this question
Top Televison & Video Experts
