2002 Cadillac Deville Logo
A
Anonymous Posted on Aug 30, 2017
2002 cadillac deville service engine light flashing at 20 mph
Service engine light was on, battery went dead due to dome lights left on for @ 36 hrs, battery would not take charge, replace battery, now service engine light flashes at 20 mph, with car coasting and trans in nuetral light flashes till car gets down to 20 mph then it stays lite. Have replaced coil paks, plugs, and boots, remove battery cables an drain 12v system, no change...
Rick M
Level 3:
  • Cadillac Master 4,148 Answers
  • Posted on Aug 30, 2017
Rick M
Cadillac Master
Level 3:
Answers
4148
Questions
0
Helped
1252342
Points
13941
Did you replace those parts based on the trouble code? Or are you just throwing parts at it? What are the codes?
http://ricksfreeautorepairadvice.com/flashing-check-engine-light-is-serious/
5 Related Answers
Anonymous
  • 607 Answers
  • Posted on Apr 23, 2009
SOURCE: 1999 cadillac deville brake light switch
Replace the brake light switch - sticking . Hope this helps
honeymokey
honeymokey
  • 3113 Answers
  • Posted on May 09, 2009
SOURCE: replaced battery now car will not start, service security system message on dashboard info. please help
The car is not reading the key and thinks someone is trying to steal it. Try another key or see a dealer.
Anonymous
  • 3533 Answers
  • Posted on May 25, 2009
SOURCE: the service engine soon light stays on i just change oil
you can try taking the positive cable off for about 3-secs and check in you owner manual to see if it tell you how and if you do have one try this website www.edmunds.com to see if you can download one for you car.
Anonymous
  • Posted on May 07, 2010
SOURCE: the service stability system light came on in my
My Service Stability System Message along with the (ABS) Brake Light lit up on my dash, what can i do to fix it...Or what does this mean ?
Anonymous
  • Posted on Dec 29, 2010
SOURCE: service stability system light flashes
i hav the same problem wit my 98 deville wat did u do to fix it and wat was the cheapest way. Also did u have anyother problems wit ur car during the time u were driving it wit these lights on
1helpful
2answers
Dead battery while just setting for few hrs
bad batt..alternator..or wornwire that charges. Chec all connections for dirt and titeness. Cud b a fuse tu. Charginwire is at back of alt to the batt
2002 Cadillac deville DHS. Before take the smork
Whatever is causing the timing adjust itself at the wrong time. It could be anything from a vacuum leak, to a coolant sensor to electrical problem. By reading all the LIVE READINGS from the sensors & getting an emissions reading will help u narrow down the problem. It doesn't sound like a DIY fix. Equipment needed
My 2002 cadiliac sts keep flashing diffrent warning lights as i drive
If you can duplicate the problem if the car is parked, I would want to know if the alternator is charging the battery when the battery light comes on and if there are any codes stored in the computer.
Battery voltage dropping below 12 can cause all sorts of electrical problems, and some of the warning lights are connected to each other.
Have a 91 cadillac sedan deville left the inside
Security system is active, look in your owners manual to deactivate
6helpful
Cadillac 1999 DeVille Battery goes dead after sitting for a few days. Had battery checked and it's good. What should I check?
You should check for voltage draws when the vehicle is off... Disconnect the negative battery termal, Pull dome light fuse,and connect a light or volt meter between the two.
common offenders are alternator diodes. These fail and cause drain.
Then you have to check, circuit by circuit, until you find the offending system.
Also, before doing anything, disconnect negative terminal and see if the battery is still fully charged after a few days...
1helpful
Have a 99 cadillac sedan deville. lots of
you need to verify the dome lights are turning off before you walk away,something is draining the battery.check you car out after driving it and make sure radio and any other things all shut off.
2helpful
I have a 2002 Cadillac DTS. It randomly dies when
Had same problem,called my Cadillac buddy and he said pick up both crankshaft position sensors.Charged me $100 cash and has not stalled again,drove me nuts for two years.
Change engine il and tire pressure message how do i rest
Must have codes for check engine light cleared with scan tool. Check all tire pressures and road test up to 35 mph. Tire message should clear if low tire was problem. If light for tires remains then possible radio frequency sensor problem. Sensor replacement may be necessary. Sensors have alkaline non-serviceable batteries. If battery is dead sensor will have to be replaced.
1helpful
Clicking starter=car not starting
the battery is located under the rear seat, check battery connections. if connections are tight replace starter.
Car won't start
did it crank over or not at all? please clarify
Top Cadillac Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Cadillac Expert? Answer questions, earn points and help others
