Microwave Ovens Logo
Posted on Dec 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't pop popcorn well
Our Welbilt microwave oven, Model MR95TW, manufactured in 1995, will not pop corn adequately. What is its rated cooking power, and has it lost power over time?
William Miller
Level 3:
  • Welbilt Master 9,179 Answers
  • Posted on Dec 13, 2008
William Miller
Welbilt Master
Level 3:
Answers
9179
Questions
Helped
4478235
Points
21747
It's 850 Watts, 0.9 cu ft.
That's enough for popcorn, but a magnetron does lose power once it starts to age.
The figure I've heard is an average life expectancy of 2000 hours for a magnetron.
Two "Band-Aid" suggestions for better exposure and more even heating:
1. Place the popcorn bag on top of an upside-down paper plate.
2. Place the bag off-center instead of dead center. Placing food in the center of the turntable is not as efficient as placing it off-center.
Popcorn doesn't cook in my new combi oven. I'm on 1000W but the bag only half inflates after 3+ mins. Is it faulty or do I need to put the bag of popcorn on a plate? Has anyone else had this problem?
Definitely a Combi MICROWAVE oven?
Popcorn needs a certain amount of moisture in it to 'pop'. 1000 watts of microwave should work fine. Make your popcorn, put it in a bowl and eat the popped corn. Put the un-popped kernels in a pan with a little oil and see if they will pop. My theory is that the bag or the corn is old.
Make and model are always useful in such questions, then we can check specs.
1helpful
2answers
I just bought a 1.1 size microwave. I tried popping a full size bag of popcorn using 2 pushes of the popcorn setting. The bottom popcorn came out black. Any idea why?
The microwave burnt it. It will be a bit of trial and error with using your new microwave and will also depend (in this case) the brand of pop corn you've cooking. Check the recommendations on the pop corn packaging for time and heat range. Happy popping!
2answers
Shut's off after cooking popcorn, only popcorn, won't restart for 15 too30min.
Sounds like the magnetron is over heating. Try putting a 4 0z cup of water in the oven along side the popcorn bag. See if this helps. Usually, the oven only runs 2 to 2.5 minutes for a bag of popcorn. You may have to experiment with the slightly different cooking time...
Is there a fuse in this microwave? It will run but not heat. welbilt model mr95tw
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
What should my powerlevel be on on my microwave because it keeps burning my popcorn
Your power level should be on high, but you shouldn't rely on the oven to time the cooking. I have yet to find an oven that won't burn popcorn if it has a preset POPCORN button. Press it and walk away and next thing you know, you've got charcoal. You should always stick around while making popcorn. Stop the oven and take the bag out when the time between pops drops to 1 or 2 seconds. The corn will continue to pop on its own for a bit because of stored heat, but you won't burn it. You'll never get 100% of the corn to pop, so don't worry about unpopped kernels.
1helpful
2answers
Does the Welbilt MR95TW exceed 800 watts?
2answers
Bad to cook popcorn in the microwave?
I have run a lot of popcorn thru the microwave with no effect on the oven.
I've never seen any cautions to not do that or to even be careful doing it.
A lot of microwaveable popcorn is sold, so that's a good indication.
Charlie
1helpful
Turn table shattered while making pop corn. Cuisinart ModelCmw100
You can order a replacement dish here. The dish shattered because the heat from the bag of popcorn was too much for it. If you look at the owner's manual for almost every microwave, they tell you not to put popcorn directly on the glass dish, but to put it on another plate.
The oven should be safe to use. Just look for any burned spots on the paint in the bottom of the cooking cavity.
Need manual
The part numbers were MW-9999-04 OR IB-MR95TW but they are shown to be no longer available.
However, one dealer lists it as being available here.
Good luck.
Microwaveoven Welbilt MR95Tw
I have one if you want to pay shipping. Mine just broke.
Top Welbilt Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Welbilt Microwave Oven Expert? Answer questions, earn points and help others
