Question about Samsung ML 1710 Laser Printer
Printer samsung ML 1710 do not power on
Dear Sir, While I am printing some envelops on my the ML-1710 printer, one of it jamed and the red light on, I removed the jamed envelop from the paper pass and the red light still on. I had checked if there is any bit of paper still inside, but there is nothing (and nothgin is missing from the envelop as well). I tried to switch it off and start it again, but it did not start again no light or movement happend in the printer, it looks like dead body. I check the fuse and the exist of electricity is it looks ok. If anyone could help in solve this problem, please let me know. thanks
  • 161 Answers
If you pulled the envelope backwards, most probably you moved one of the paper path sensors out of position. Unfortunately, this is something you should not try to fix yourself, but any experienced printer or electronics technician can help.
Posted on Sep 21, 2007
Samsung ML-1710p - when attempt to print, leds start slowly blinking simultaneously, "on line / error" - red, "toner save" - green
May be rejected this toner unite or paper could not feed properly.Service thoroughly your printer and Fuser unite.
Nov 27, 2009 | Samsung ML 1710 Laser Printer
Error light is red, and nothing prints
i think your paper sensor is damaged, replace it
red light show : when paper is not present or toner is not accepted, or door open
We have Zero cost solution for samsung -scx-4300, scx-4824/4828
ml-2240,ML 2245, ml 1640. clp 310/ 315, It is working permenently.
Refill cartridge is working for ever. which is running successfully.
also provide other new model reset solutions.
www.nakshatraworld.com
mob: 9713862555, 9893282285
vivekryp@yahoo.co.in
Nov 22, 2009 | Samsung ML 1710 Laser Printer
Samsung ml-1710 printer does not always print
you need to reinstall printer with samsung printer driver specific for this model that can be downloaded from samsung website
Oct 04, 2009 | Samsung ML 1710 Laser Printer
I have a samsung ml-1710 laser printer. Was wrking
Power off the printer, disconnect/reconnect the printer cable, power on the printer, reboot your workstation.
If that doesn't work, in Control Panel - Printers, delete the icon for your printer. Disconnect the printer cable. Reboot your workstation and log in. Reconnect the printer cable and see if the printer is recognized. Install the printer driver.
Jun 12, 2009 | Samsung ML 1710 Laser Printer
Samsung ML 1710 won't print second page
i'm thinking it's a config-related problem. i've seen a comparable problem already. could you check the settings in the printer software? there is setting that says "print first page from different tray" if its box is checked, the printer wants to print the rest of the print job from another tray, and will block when there is no other tray available.
if you find this setting is not marked, then i propose to delete the printer driver and all settings and then downloading the most recent driver from the manufacturer's website and installing that one.
May 25, 2009 | Samsung ML 1710 Laser Printer
Print is faint on envelopes.
this is because the envelopes are thicker. Check to see if there is a setting in the driver that specifies envelopes...
May 01, 2009 | Office Equipment & Supplies
ML-1710 Printer won't print
Our printer at work does this and I found that a piece of paper was stuck under the rollers. As soon as I removed it the paper went through. Another problem could be that you may need to FAN the paper and make sure the other side is feeding in first. Hope this help
Mar 20, 2009 | Samsung ML 1710 Laser Printer
Samsung ML-1710 Printer: Online/Error (red) lite ON: won't print
It is not a computer problem, when your printer won't come to ready. The lights flashing are due to a failure of some sort - electronic, or perhaps a fuser warm up problem. The fact is, whatever the fault, it is cheaper to replace this printer than have it repaired.
Mar 16, 2009 | Samsung ML 1710 Laser Printer
Printer prints too light
dust in the LSU (laser unit), you have to clean LSU.
Nov 25, 2008 | Samsung ML 1710 Laser Printer
Samsung ML-1710 Laser Printer
Hi, On another posting of a similar problem, I proposed this solution: In some instances, the PC switches off a USB port. You may have to un-check "Allow the computer to turn off this device to save power." This is in your Device Manager/Universal Serial Bus Controllers/USB Root Hub. Hope this be of some help/idea. Pls post back how things turn up or should you need further information. Good luck and kind regards.
Apr 24, 2007 | Samsung ML 1710 Laser Printer
Samsung ML 1710 Laser Printer Logo
65 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
