Question about RCA HD52W58 52" TV
RCA 52" TV No longer turns on!
I am having an issue with the TV turns on sound becomes audible then it turns off! After checking the manual I thought perhaps it was getting over voltage per the troubleshooting steps. I checked the voltage and it is at 118.3 volts which is abnormaly high but I live in a very unique place. The TV is only 6 months old and where I live no RCA tech will be able to visit! I am capable of electronic repair I just do not want to void my warranty although I may have no choice. I have also contacted RCA customer support and am awaiting a response.
  • 1 more comment
  • Christopher Provolt Mar 18, 2007
    I took my TV apart and solved the problem on my own. For those of you that have basic electrical skills and can solder it is an easy fix that only takes about one hour. I removed the rear cover and pulled the left side board which houses the flyback transformer, easily identifiable by the big orande wire coming off of the top. If one looks carfully the soulder connection will probably be broken or loose which can be caused by movement or heat. I resoldered all of the connections for the transformer about 12 and the grounding wire to the left, a single black wire that plugs into the board. Once this was done I put ti all back together again and no problems since!
  • eggbox Apr 02, 2008
    tv turned off and will not turn back on
  • Johnathan Hamrick Dec 23, 2008
    My 52" T.V; Clicks three times and quicks. I think the starter is out. Can you tell me what you think might be able to fix or how to fix it.
    Respectfully yours,
    Johnathan Hamrick
5 Suggested Answers
techman
  • 3130 Answers
SOURCE: F36550 RCA 36 in TV
Hehehe Its all in a matter of taste I like sony and Mitsubishi. You like RCA you get what you pay for. These sets are good for the L401 in the horizontal drive circuit to cause your problem as well as a blown fuse and a shorted horizontal output trasistor and the flyback transformer. if its anything Im thinking off the repair cannot be done by a handi person and should be taken to a pro and will cost in the range of150 to 225.00 for this repair. good Luck
Posted on Jul 27, 2006
techman
  • 3130 Answers
SOURCE: RCA F32650 32'' TV Just stopped working and 3 months after warranty 3-yr warranty expired
This is a very common problem with RCA tV sets. But unfortanatly, RCA is no longer made in this country or even owned by RCA anymore. They are a Canadian company called Thompson Corp and could not give two hoots about any problems with TV sets sold here in america. I say this from experience and try to contact them and file a complaint. ther customer service is rude and basicly calls us idiots! Alot of class action suits are pending or have been dropped as for the amount of sets they company have sold,They have attorneys working for them and delaying the cases. It is really the fault of the US Judges that are total morons about these things and try to go by un written laws. They dont have a clue as most of the US goverment does not. Your problem is not a power supply problem, But a high voltage transformer and a horizontal output transistor, and the reason why the estimate was so high, is because the tranformer is no longer available. Thats why the estimate is so high. Because who in there right mind would spend so much on a set as this. You can buy a 32" RCA(BUT I WOULD NOT BUY TRASH)At Wally World for less the $250.00 bucks! I no longer accept RCA TVs in for repair as replacement parts are so much money and im not proud to say I work on RCA TV sets. Total garbage sets!!
Posted on Oct 08, 2006
SOURCE: RCA HD56W58 Troubleshooting
Yes, i had the same issue. High voltage trans. and the HV distributor (splitter) goes bad on there tv, they are known for that. I have the part numbers for the HVT p/n 258655 and HV distributor(splitter) p/n 258512. The two p/n are for HD56W58 proj. tv.
Posted on Sep 03, 2008
  • 92 Answers
SOURCE: rca 62" PROJECTION FLATSCREEN - COLOR PROBLEM/FLICKERING SCREEN
Sounds like the red picture tube could be shorting internally which would cause the "all red" condition. In which case you'd have to replace the red tube. Are there horizontal (slightly slanted) lines through the picture as well when this is happening and a very very bright screen? If so it's most likely the tube.
Posted on Oct 06, 2008
Our TV started taking longer to turn on and then sound will come
may be bad cap take to tv shop good luck
have to have esr meter to check
Apr 28, 2009 | RCA Televison & Video
My rca 52 inch hdtv turns itself off after a few minutes
Sounds like the green tube shorting intermittantly. Have a qualified tech use a tube restorer to check for shorts, or the loss of the 300v line to the green tube.
Aug 30, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52" D52w20 problem
My goes off a few seconds after turning it on. It does make a funny sound, like static on the tv.
Aug 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv wont turn on p52960
Still sounds like the flyback. Rca has had issues throught the years with flybacks failing especially that model.
May 12, 2008 | RCA P52926 52" Rear Projection Television
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
check to see if the autformat has been turn on and that the aspect raito is 16:9 because it sounds like your zoom has been turned on
Jan 29, 2008 | RCA HD52W58 52" TV
Rca 52 inch rear projection
This is a problem common with some RCA/GE TV's. The fix in the past was to install a capacitor between ground and pin 15 of the microprocessor which keeps a data signal riding on the video stream from muting the sound on most stations. By installing this capacitor, you would be disabling the closed caption feature so that feature would no longer work. An authorized RCA TV repair shop may be able to give you more information.
Apr 12, 2007 | RCA P52940 52" Rear Projection Television
RCA D52W20 cold start issue?
i am looking for an owners manual for the d52w20, can anyone help me out here.
kimmipoo_2000@yahoo.com
Apr 04, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W58 52" TV Logo
63 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
