Remote control code for daenyx dvd/vcr combo?
I have a Daenyx dvd/vcr combo Model DCR -110 for which i would like a code to program onto my universal remote
  • billr740 Jan 08, 2009
    My remote is an Atlas DVR/PVR 1055.
    Hope this helps
    The solutions I've received so far are copies of what I already have in the remote control instruction manual. I am looking for the four-digit codes that go with my particular dvd/vcr unit. Thanks
  • 4,806 Answers
Hi there
I'm sorry to tell you that there are no codes for the Daenyx dvd/vcr combo for use with the Universal remote, you will have to get a remote which supports Daenyx.
Have a look at the remote controls site to varify this:
http://www.urcsupport.com/html.php?page_id=361
Sorry i couldn't be of any more help and kind regards
Posted on Jan 08, 2009
    Sergeant:
    Novelist:
  • 326 Answers
Http://www.xdiv.com/remotes/ just click the link above.
    Master:
  • 416 Answers
  1. If your home entertainment device does not respond to the Atlas 1055 Universal Remote Control after trying all of the codes listed for your brand, or if your brand is not listed at all, try searching for your code.
    1. Turn on your TV.
    2. On the remote control, press TV once; it blinks once. Then press and hold SET UP until the TV key blinks twice.
    3. ENTER 9-9-1. The TV key blinks twice.
    4. Aim the remote control at the TV and press PWR once.
    5. Press CH+ one or more times and stop when the TV turns off.
      NOTE: In the search mode, the remote control will send IR codes from its library to the selected device, starting with the most popular code first.
    6. Press SETUP once to lock in the code. The TV key will blink twice.
    7. To search for codes of your other devices, repeat steps 1 through 5, but substitute the appropriate key (e.g., AUX, DVD, CBL, or STB) for the device you are searching for.
Good Luck
  • 505 Answers
Dvd/vcr combos usually have different codes and you will only be able to get one or the other (ie only dvd or only vcr) to work. with an off brand like you have, try the codes for other manufacturers like sansui, magnavox, philips, etc and hopefully one will work. unfortunately i have very little luck with dvd/vcr combos. a learning remote will learn any code and can be "taught" to program this device
  • 3,037 Answers
Hi Bill
Here are the set up instructions as this remote doesn't have a code for this device
The Atlas 5-Device Remote Control with Learning is preprogrammed to operate the cable box (converter)provided by your cable system, an RCA TV, a Toshiba DVD player, an RCA VCR, and a Pioneer audio receiver.To control devices other than the default brands,perform the following steps; otherwise skip this section.NOTES: For control of a Combo device (for example, a TV/VCR combo), skip this section and perform the instructions on “Setting Up a Combo Unit” in the manual. If you have another brand of cable converter or a satellite receiver you would like to control,you’ll need to unlock the cable ID Lock before changing the converter code (see “Programming Cable ID Lock” in the manual).
  1. Turn on a device and, if applicable, insert video media, (e.g., cassette or disc).
  1. On the remote control, press a device key once(i.e., VCR, DVD, AUD, TV, or CBL); it will blink once. Then press and hold SETUP until the selected mode key blinks twice.
  2. Use the lookup tool below to locate the type of device and brand name and then enter the first four-digitcode for your device. If performed correctly,the selected mode key will blink twice.
    NOTE: If the selected mode key emits a long blink,the entry is invalid. Repeat steps 2 through 3and try entering the same code again.
  3. Aim the remote control at the device and press PWR once. The device should turn off. Ifit does not, repeat steps 2 through 3, tryingeach code for your brand until you find onethat works. If it still does not respond, trysearching for the code (see “Searching forYour Code”).
  4. NOTE: If the device does not have a PWR key, pressthe PLAY key.
  5. Repeat steps 1 through 4 for each device youwant the remote control to operate. For futurereference, write down each working devicecode in the boxes on the following page.
please see this link for more info
bestdarngood
    President:
  • 2,110 Answers
1. Turn on a device and, if applicable, insert video media (e.g., cassette or disc).
2. On the remote control, press a device key once (i.e. AUX, DVD, AUD, TV, or CBL); it will blink once. Then press and hold SETUP until the selected mode key blinks twice, then release SETUP.
3. Use the code lookup to locate the type of device, brand and model and then enter the first four-digit code for your device. If performed correctly, the selected mode key will blink twice.
NOTE: If the selected mode key emits one long blink, the entry is invalid. Repeat steps 2 through 3and try entering the code again.
4. Aim the remote control at the device and press PWR once. The device should turn off. If it does not, repeat steps 2 through 3, trying each code for your brand until you find one that works. Repeat steps 1 through 4 for each device you want the remote control to operate.
  • 916 Answers
  2. On the remote control, press a device key once (i.e., VCR, DVD, AUD, TV, or CBL); it will blink once. Then press and hold SETUP until the selected mode key blinks twice.
  3. Use the "Manufacturer's Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly, the selected mode key will blink twice.
    NOTE: If the selected mode key emits a long blink, the entry is invalid. Repeat steps 2 through 3 and try entering the same code again.
  4. Aim the remote control at the device and press PWR once. The device should turn off. If it does not, repeat steps 2 through 3, trying each code for your brand until you find one that works. If it still does not respond, try searching for the code (see “Searching for Your Code”).
  5. NOTE: If the device does not have a PWR key, press the PLAY key.
  6. Repeat steps 1 through 4 for each device you want the remote control to operate. For future reference, write down each working device code in the boxes on the following page.
  • machadojr_fe Jan 08, 2009
    I opologize this is the correct way to program your device
    1. Turn on your device (i.e. TV).
    2. On the remote control, press TV (or appropriate device key) once; it will blink once. Then press and hold SETUP until the TV key (or appropriate device key) blinks twice, then release SETUP.
    3. Enter 9 - 9 - 1. The TV key (or appropriate device key) will blink twice.
    4. Aim the remote control at the TV (or appropriate device) and press POWER once.
    5. Press CH+ one or more times and stop when the TV (or appropriate device) turns off.
      NOTE:
      first.
    6. Press SETUP once to lock in the code. The TV key (or appropriate device key) will blink twice.
    7. To search for codes of your other devices, repeat steps 1 through 5, but substitute the appropriate key (e.g. AUX, DVD, AUD, or CBL) for the device you are searching for.
  • 679 Answers
Check 7355.
Thanks for using FixYa.
Posted on Jan 05, 2009
  • rockfixya
    rockfixya Jan 07, 2009
    did the solution works for u.
  • 565 Answers
What kind of universal remote control u have. if u tell i can help
  • 15,935 Answers
What is the make/model of the remote?
  • blueextc3221
    blueextc3221 Jan 05, 2009
    It works with some. here they are.
    0005, 0017, 0047, 0050, 0062, 0103, 0146, 0156, 0486, 0237
What is tv code for daenyx
You will need to provide the make and model of the remote control device that you are using to control the Daenyx DN-26D.
Sep 19, 2014 | Daenyx DN-26D 26-in. LCD HDTV/DVD Combo
Will an rca remote work for a daenyx tv
I don't know if an RCA remote will work with a Daenyx tv, but I do know that a Harmony 600 will. It costs about $80.00 and codes are provided by the Harmony website during programming. The site just needs the product name and model number.
Feb 18, 2011 | RCA 3-Device Universal Remote with...
I just want to get a universal remote for my daenyx tv. I can not find one.Is there such a thing. Please help. Thanks
The Harmony 600 will work with a Daenyx tv. It costs about $80.00 and codes are provided by the Harmony website during programming. The site just needs the product name and model number.
Dec 05, 2010 | RCA Universal Remote Control
I purchased my TV at Future Shop and am in need of a new remote control for my Daenyx TV model DN-193. Future Shop advised me to use a Universal remote and so far I have tried two universal remotes and...
Teresa;
The Harmony 600 will work with the Daenyx DN-193. It costs about $80.00 and codes are provided by the Harmony website during programming. The site just needs the product name and model number.
Sep 22, 2010 | Televison & Video
Can't program a new universal remote for daenyx tv
The Harmony 600 will work with a Daenyx tv. It costs about $80.00 and codes are provided by the Harmony website during programming. The site just needs the product name and model number. I don't think WalMart would carry it but a good electronic products shop will.
Jun 02, 2010 | RCA Universal Remote Control
I broke my daenyx remote and i cant turn my t.v on and i cant find a universal remote that will work or any codes
Mar 30, 2010 | RCA Universal Remote Control
Need to buy a new remote for Daenyx tv can't find one
The Harmony 600 will work with a Daenyx tv. It costs about $80.00 Cdn and codes are provided by the Harmony website during programming. The site just needs the product name and model number.
Nov 18, 2009 | Universal Remote Control URC-6131N Remote...
Bought universal phillips remote to replace broken one and can't find code for Daenyx
couldnt find the type of tv you have but i found something that might help you can try these
or you can try doing a code search with the remote below is how to do it
Manually turn on the device (TV, VCR, etc.) to be
controlled.
2. Press and hold the CODE SEARCH button until the
red indicator stays on, then release the CODE
SEARCH button.
3. Press and quickly release the desired mode button
(TV, VCR, etc.). The red indicator blinks off once.
4. Press the CHANNEL UP button repeatedly (up to
300 times) until the device to be controlled changes
channel. The red indicator blinks off with each
button press. If you accidentally overshoot the
code required, press the CHANNEL DOWN button
to backtrack through the library until the device
changes channel. Pressing CHANNEL UP changes
direction to forward again.
5. Press and release MUTE to install the code.
May 29, 2009 | Universal Remote Control URC-6131N Remote...
Remote control code for a daenyx tv
My Daenyx DN-191 D TV remote stopped worked after a while. I didnt get one universal remote that works with this piece of junk. I called their customer service at 1-877-329-8351. They said the remote will be $30 + $7 (shipping) + tax. Your best bet will be to buy a replacement remote or better toss this junk off the window.
Jun 28, 2008 | Televison & Video
Universal Remote code for the Daenyx 42" LCD TV
Here try this link
REMOTE
pls dont forget to rate as fixya if helpful. Thanks!!
Apr 27, 2008 | Televison & Video
Televison & Video Logo
247 people viewed this question
Top Televison & Video Experts
