Question about GE GSS25SGMBS Side by Side Refrigerator
GE Side by Side Ice Cubes Clumping
I have a GE GSS 201EPD Side by Side. The freezer normally runs about 0-10 degrees. It occaisionally gets up to near 40 degrees (I suspect during defrost). The ice maker works good except that the cubes melt a little and then freeze together in a clump. I had a tech out several times who replaced a burned out defrost heater (unit was icing up). Then he replaced the main board and also some white capsule looking sensors (thermistors?). Anyway over $300 dollars later and I'm still having problems and he gave up on me.
  • Pamela Bates
    Pamela Bates May 17, 2009
    I have the same problem. The board controls the defrost cycle and the condenser coils are clean
  • jeff1013946 May 11, 2010
    Sounds like the unit is staying in defrost too long. does the board control the defrost cycle or is there a defrost timer in the unit? I suspect that the board controls all functions. First thing to do is to make sure that the condenser is clean and air flows freely. Dirty condensers prevent units from freezing to their proper temps and can cause unit failure. Next, check the time of defrost. If you have a digital thermometer, check the temp of the freezer when it comes out of defrost cycle. Also time it. Get back to me when you have that info.
5 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Clumps of ice cubes in back of ice bucket
sounds like your just might not be using enough ice and they are defrosting and clumping together.figure your pulling ice from front of bucket the the backs hardly get used espescially in winter your not using as much ice. or ice maker is slightly over flilling water and dripping over rear of unit
Posted on Feb 24, 2008
SOURCE: Ice cubes melting then refreezing in clumps
check the flap door to see if it is slightly open letting warm air in
Posted on Aug 10, 2008
ginko
  • 19396 Answers
SOURCE: Clump of ice in bucket
That means that the evaporator fan system that releases the the ice cubes is not working as it should.
The evaporator fan and heating system must be checked, and fan, or solenoid, or element must be replaced.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
Posted on Nov 29, 2008
  • 1891 Answers
SOURCE: ice from icemaker melts together
look for water over flling the ice tray . may need leveling / also the water valve may be leaking through. if so replace it .. mm
Posted on Aug 14, 2010
I have a GE Profile side by side refrigerator. It has not been cooling very well, it stays between 38-41 degrees. also the ice maker doesn't make a lot of ice and the cubes are smaller in size.
Ice maker want work if freezer bus not around 0F. Are fans running? Is condenser coils clean? Is there any frost build up on inside back freezer wall?
Nov 06, 2017 | GE Refrigerators
Sometimes ice melts in ice maker. Water drips down and refreezes.
There is a heater built into the ice maker bottom to help release ice cubes from the machine. Under normal conditions the heater only come on when the ice maker starts to run and then jambs against the frozen cubes. When it stalls and jambs against the frozen ice cubes, the heater comes on to melt the cubes enough. I think you have a defective ice maker and the heater is coming on to much or at the wrong time, Since your temps go back to normal with the ice maker turned off, I am almost sure thats your problem.
Mar 16, 2015 | GE Profile PSC25MSWSS Stainless Steel...
Ge profile fridge side by side makes only 8 ice cubes per day
Good day,
Assuming the temperature in the freezer is normal. 10 degrees or less. then it should be one of the 3 items here.
1. Partially plugged filter.
2. Water valve in the back bottom of the machine failing to open properly.
3. Partially blocked supply line from the house or it's connection fittings which ar more common than the line itself.
As well, if the water fill valve has a small leak on the off cycle, the fill tube running from the outside back of the machine that supplies water to the ice maker cavity may have ice starting to cause a blockage.
Nov 06, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
GE side by side refrigerator with automatic ice - ice clumping
Most likely happening during defrost. Replace defrost thermostat
Nov 17, 2017 | GE Refrigerators
GE TBX21ji Refridgerator/Freezer Factory Icemaker quit making ice
Normally, when the temp of the icemaker gets to about 14 degrees F, the icemaker goes into the harvest mode, turning on the mold heater and attempting to eject the cubes. When the heater has warmed the mold sufficiently to release the cubes, the ejector can continue and push out the cubes, then the icemaker fills with fresh water to beging to make a batch of ice again. Manually starting the cycle as you have done only allows the cycle to start without the temp sensor seeing the 14 degrees. The mold heating generally takes a couple minutes. If your mold heater or the temp sensor are not working, you will have to replace the icemaker, as they are not available as a repair parts.
Jul 04, 2009 | Freezers
GE Profile refrig side by side Model GSS 20iEMCC, not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
df
Dec 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Problem with my GE side By Side refrigerator--Ice Machine
This is the normal operation!!!!!! Check the manual and it will instruct you to periodically loosen the ice in the tray to prevent clumping. Pretty low tech design.
Oct 09, 2007 | Refrigerators
GE 25 side by side refrigerator ice maker problem
Assuming the temp inside the freezer is at around 0 or -2 degrees, it should dump ice every ~50 minutes or so. Again, depending on temp's, an Ice Bin should fill within 24 to 48 hours. If your freezer temp is running at around 10 degrees, everything will obviously still be frozen (below 32), but the ice maker will take longer to freeze the water than it would if it were at 0 degrees. Open both doors and place the palm of your hand on the partition between the freezer and Fresh Food compartments... (where the door gaskets seat when they're closed). The temp of the partition should be about 5 or 10 degrees warmer than body temp., If it's hotter than that, you found the problem. Either the condenser coils are dirty and need a good cleaning OR your condenser fan motor (the fan in back, near the floor in the compressor area) is failed or about to fail.
Jul 29, 2007 | Maytag MSD2756G Side by Side Refrigerator
GE GSS25SGMBS Side by Side Refrigerator Logo
303 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
