Question about Whirlpool LER5636P Electric Dryer
I have dryer lint all over house - Whirlpool LER5636P Electric Dryer
  • greg_rinehar Feb 15, 2009
    Same problem, and the exhaust tube is not clogged.
  • 640 Answers
Your exhaust vent leading from house is clogged..
Posted on Dec 26, 2008
How do I replace the clip-spring on the duet sport dryer?
Here is how to install the 8066208 clip-spring in the lint housing of the duet dryer. Hold the clip with the curved end facing down towards the ground. Now insert the opposite flat end of the clip through the slit in the lint housing. Continue to push the clip inside the lint housing until it stops. The flat end of the clip will slide to the bottom of the housing. There should be about an inch and a half of the clip showing when all finished.
Feb 23, 2013 | Maytag Parts Maytag 8066208 Dryer...
DRYER GENERAL ELECTRIC SUPER CAPACITY. APPARENTLY IT IS WORKING BECAUSE IT HEAT BUT THE CLOTHES ARE WET
A leading cause of poor drying results in that type of dryer is lint build up in the blower/lint filter housing. That build up will restrict air flow through the dryer causing very long dry times. To repair that the front panel would need to be removed and clean all the lint build up from that housing and blower wheel area.
To remove the front panel DISCONNECT POWER TO THE DRYER, on the bottom of the dryer inside of the door rim will be 2 phillips headed screws,remove those and lift off the top. At the top corners where the front panel connects to the cabinet will be 2 more phillips headed screws remove those and the front panel will pull off and out of the way. With the front panel off the blower housing will be in the lower left side clean lint from it and also the sure to clean all the lint from the lint filter housing which will be attached to the back side of the front panel. In addation to cleaning that area be sure to check and clean the exhaust duct tube as well.
GENE
Oct 13, 2011 | General Electric Dryers
Thermal fuse location on a 110.9597590110 gas dryer
The model number of your machine doesn't seem to exist but the thermal fuse, whether dryer is electric or gas, is always located on the blower housing together with the thermistor or cycling thermostat depending on the model of the dryer. The blower housing is located at the rear of the dryer if the lint filter of you dryer is located on top of the cabinet and can be accessed by removing the rear panel.
The blower housing is located on the front right bottom of the dryer if the lint filter is located on the door. It can be accessed by removing the kick panel.
Kick Panel Removal
Once the kick panel is removed, remove the lint chute to expose the blower housing and the thermal fuse.
Sep 30, 2010 | Kenmore Dryers
How many lint filters does an estae dryer have? I know one on top is there another one?
There is only one lint filter on this model dryer. there is however the lint filer housing hat the lint filter goes into that is accessible by removing the back cover and then removing the screws at the lint screen opening as well as the screws at the lower section of the round part of the housing. if something fell into it you may have a chance of removing it from the lower housing area before the blower assembly by removing the back and the lint filter housing.
Good luck with this and let me know if you have any further questions!
Jul 25, 2010 | Estate TEDX640JQ Electric Dryer
Dropped pen into lint trap. Now Dryer makes a screeching noise.
The pen has fallen into the blower housing and is hitting the fan blades.
Unplug the dryer!! Remove the two screws at the top of the lint trap. Remove the rear panel. Remove the four screws at the bottom that attach the lint filter housing to the blower housing. Then, remove the pen from the blower housing.
Apr 06, 2010 | Kenmore Dryers
Keeps blowing thermal cutt-off fuse
You need to remove the front dryer panel clean dryer completely of lint . Even where the lint filter is . Also make sure the vent hose is not kinked or filled with water and lint . I changed a thermal cutt-off 3 times in a dryer within about 2 weeks time . On the last time , removed the front panel and filter housing , and a big ball of lint fell out . Cleaned vent housing and inside of dryer and no more problems since .
Sep 05, 2009 | Whirlpool Dryers
Dryer lint throughout thr house
lint throughtout hte home is a sign tha there is a tear / or a disconnect of the dryer vent. check your venting
Feb 15, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer not drying cloths
HI thanks for your question. the lint filter housing is full of lint. remove the lint screen. 2 screws. remove. pry top up with a flat screw driver, from the almost the corner. lift the top up. pull dryer away from the wall remove the air duct that the lint filter goes in clean out the lint. thanks the appliance doc
Oct 16, 2008 | Kenmore 73952 Gas Dryer
Back panel removal
it is..remove bottom panel ..after unplugging from wall..remove lint screen next remove 3 screws holding the lint screen/blower housing in place ..clean out housing clean blower wheel with long brush or a long arm clean lint from base and on element housing on right side especially on top of the housing..that is the most important location if lint gets too thick on element housing ..fire hazard....ckd vent behind dryer and to outside if you find a large amount of lint .that is good indication of a restricted vent
Aug 22, 2008 | Kenmore Elite HE4 Electric Dryer
I own a whirlpool gold dryer about 4 years old. I empty the lint catcher frequently. I noticed however, that sand has accumulated inside the dryer, I hear the sound when the dryer starts tumbling. How...
not as hard as it will sound here we go
remove the lint filter
remove the 2 phillips screws at the filter housing top you will see these screws after you have pulled out the lint filter
unplug the dryer
remove the back panel
on the left side is the lint filter housing it is held in place with 4 1/4 inch screws remove them
lift up on the filter housing and pull forward you will find the sand inside the filter housing use a vac to **** it out and reassemble the dryer, no more sand
Apr 26, 2008 | Dryers
Whirlpool LER5636P Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
