Question about Microsoft Windows XP Home Edition
Your OSD problem
Did you manage to solve your problem? I have the exact same problem!!!!
    Guru:
  • 829 Answers
Hold the MENU button for ten seconds to unlock or lock the OSD.
Posted on Dec 17, 2008
Monitor display says OSD Lockout /no signal input how to fix this?
This document pertains to LCD monitors .
One of the following messages appears on the screen (over the items being displayed).
OSD Lockout
OSD Lock-out
... or similar message.
This message occurs when the Menu button on the front panel is pressed for more than 10 seconds. OSD lockout prevents the OSD menu from opening on the screen when a button is accidentally pressed.
NOTE: The button may be different and the procedure might vary on some monitors. Please check your monitor User Guide to find the exact procedure if this procedure does not work.
To remove the OSD Lockout message, release the Menu button (if something was pressing against it), and press and hold the Menu button again for about 10 seconds - until the message goes away. If the OSD Lockout message does not go away, the button may be stuck or the hardware behind the button might have become defective.
Aug 31, 2013 | Dell Computers & Internet
There is a blue lock that appears in the center of the screen
Change the OSD Lock option from ON to OFF by following these steps:
Press the Menu button on the remote or the control panel for 15 seconds to unlock the OSD menu.
When the OSD menu appears, select the Management option at the Main Menu, then select OFF at the OSD Lock option.
Select Exit to save the setting and exit the menu.
hope this helps
Aug 07, 2012 | Dell OptiPlex SX280 PC Desktop
Osd volume control won't go away
bad switch i monitor.
fix switch
or new monitor.
its just a switch, it closes and OSD pops. on demand by said switch, OSD is a timing processor in the display that has the OSD code in it , "program"
Mar 25, 2017 | HP Computers & Internet
When i try to adjust the monitor controls message comes up OSD locked, how do I unlock it
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Oct 24, 2010 | Computers & Internet
OSD Lockout
Hello, Just hold the menu button for about 30 seconds, this solves the issue
Sep 09, 2009 | HP L1940T 19" LCD Monitor
Compaq FP5315 monitor with OSD Lock out
Here is the tip to solve your problem. Hope this might be helpful to you.
OSD Lock—The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message “OSD Lock” displays for five seconds.
❏If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
❏If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Aug 07, 2009 | Philips 170S7FS 17" LCD Monitor
Osdlock on my computer desktop for 17'' monitor
You are having a problem with the OSD lock on your ViewSonic E70f Monitor. Is that correct?
If so, please follow these instructions to unlock or lock your monitor.
On some display devices, there is an OSD Lock that locks all current control settings and prevents access to the control menus until this mode is unlocked.
The method for unlocking the OSD is different for different monitors, but will be one of the 2 below. If the first method doesn't work, try the second.
Method 1: Press and hold both the [1] button on the front of the monitor and the down arrow button for 10 seconds.
Method 2: Press and hold both the [1] button on the front of the monitor and the up arrow button for 10 seconds.
Note: These same buttons, when pressed for another 10 seconds, will lock the OSD
Please let us know if you require any further help with this matter.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Mar 31, 2009 | ViewSonic E70f 17" CRT Monitor
OSd lock keeps on poping up on my screen, i ihave viewsonic monitor. how can i solve this problem?
You are having a problem with the OSD lock on your ViewSonic Monitor. Is that correct?
Mar 28, 2009 | ViewSonic E70f 17" CRT Monitor
OSD Lockout
Have you opened the monitor's onboard menu and checked the OSD settings? Do that and see if you can change those settings there. I would also open the Device Manager and check for problems. If you see any yellow question marks, that hardware has a problem.
Sep 12, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
Problem in TFT
  • If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
  • If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Jun 09, 2008 | LG L1915S 19" LCD Monitor
Microsoft Windows XP Home Edition Logo
35 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
