Question about Whirlpool LER5636P Electric Dryer
Dryer lint all over the house
Maytag atlantis
Generally this would be caused by an open or tear in the flexable exhaust vent pipe to the outside. Look behind the dryer and determine if the flexible exhaust pipe is connected at both ends. With the dryer running you might feel a lot of warm/hot air in the area around the vent pipe if there is a tear in the foil. The fix is either to reconnect the pipe or replace it if the pipe has a tear in it. You should be aware that if the lint is exhausting into your home, it is likely the exhaust gas (carbon monoxide or other exhaust gases) are being injected into your home. If you are unable to repair this, you should call an appliance repair company and have a professional technician check out your unit.
Posted on Dec 29, 2008
Lumpy816
  • 246 Answers
SOURCE: maytag atlantis dryer exsess builup lint
What product have you purchased from this site? We are a collection of knowledgeable people who are not afilliated with any manufacture. While you have the OPTION of paying to work with someone live, if you leave your information posted for a day or two, one of us will generally get back to you with some FREE help.
Now on to your problem. While I don't know what model of maytag atlantis you have, these are the general guidelines for cleaning out under the lint screen area. The easiest approach is to buy a vaccume extension availible from appliance parts stores and some hardware stores. I have even seen a clean out kit for sale at bed, bath and beyond. Basically you fit the vaccume extension on to the end of you vaccume and feed it down to the area under the lint screen. To do a more efficent cleaning you would need to dis-assmble your dryer. If you can supply the model number located just inside the door, I could get you a step by step tear down to get to it from the inside.
Posted on Jul 05, 2008
  • 659 Answers
SOURCE: My lint trap has very little lint.
Older clothes do not produce as much lint as new ones. Also, if your dryer isn't getting as hot as it used to, then you won't get as much lint either. Does it seem to take a bit longer to dry your clothes? Also, check your dryer vent, if the airflow is reduced, the amount of lint that is expelled through the filter will deminish as well. You may have a build up of lint in the vent ducting to the outside that is restricting airflow.
Posted on Apr 08, 2009
SolutionGuy
  • 331 Answers
SOURCE: How do I remove the lint housing of Maytag Neptune dryer
Hi Kate,
Gaining access to the lint housing sounds more difficult than it is. As a matter of fact, I could get to it and have it back together in the time it takes me to type out the instructions!
Tools needed;
1.) Phillips screwdriver
2.) 5/16" nut driver or socket
UNPLUG THE DRYER FIRST!!! Or risk a funky new hair-do...
Open the door and remove the four screws at the hinges then remove the door. Opposite the hinges, you'll see 4 more screws, remove these too. Now grasp the front panel on both sides near the top and pull it toward you. Lean it out to about a 45 degree angle and lift it off the clips that are holding it (at the bottom).
Now you'll see the lint trap housing. Look around the housing, you'll probably see a yellow wire near the 5 o'clock position, remove it. Now, on either side, you'll see four 5/16" screws... Don't remove the top ones, just remove the three below the top ones. You can now pull the entire panel off of the frame for cleaning.
Rebuild in the reverse order (and don't forget to re-connect that yellow wire!)
There ya go! Please don't forget to rate this as "FixYa", OK
SG
Posted on Apr 11, 2009
Healeyman
  • 1198 Answers
SOURCE: Maytag Atlantis Dryer squeals
Try Repairclinic.com for help and parts. You are going to need heat resistant grease, and probably snap ring pliers.
Posted on Apr 28, 2009
TheMobilian
  • 8220 Answers
SOURCE: Coins stuck in Maytag Atlantis dryer. Could
First unplug the machine. Then remove the door.
You will then be able to remove the "goalpost" front panel. Then you will be able to get the hold down off so you can lift the top. Are the coils inside the drum vanes? Just remove them and dump the coins out and reattach the vanes. A lot of trouble for a few coin. That's the story of my life.
Posted on Apr 18, 2010
Can I remove washing machine agitator to clean it. I have a Maytag Atlantis washer
Hello, Bonnie -
The instructions for cleaning the Maytag Atlantis washing machine can be found in the User's Guide for the machine.
I can only think that you do not have the User's Guide. If that is the case, you can download one (free) here:
https://www.manualslib.com/manual/294972/Maytag-Atlantis-Mav6451aww.html#manual
You will need Adobe Acrobat Reader software (free). After you download the guide, save it to your Documents folder and use a file name you can find again easily - example: Maytag Atlantis Washer Manual.
Cleaning instructions are on Page 8 of the guide.
Note: Unless you are mechanically inclined, do not remove the agitator. You may not install it again properly and then will have to pay for a service call.
Best wishes.
Mar 03, 2018 | Maytag Washing Machines
How do I take the top off of the Maytag Atlantis dryer?
they are called baffles. and can only be accessed by getting to the outside of the drum. have to remove the body but u may have a bad baffle if the screw hole is busted up?
Sep 14, 2014 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis dryer drum catching clothes and making holes
drum seals are faulty
Replace them
Go to the following webpage for parts
Please rate me
Bud
http://www.appliancepartspros.com/
Oct 29, 2012 | Maytag Atlantis MDG7400AW Gas Dryer
I have a maytag Atlantis washer - 7 years old, it
I have a Maytag Atlantis top load washer which leaks in the rear right hand corner under the discharge hose, how do I take the machine apart to get to the problem.
Feb 04, 2010 | Maytag Atlantis MAV6000 Top Load Washer
We have a Maytag Atlantis dryer. Inside the tub
Did you try opening up the back of dryer or the top?
Sep 05, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag gas atlantis dryer. It starts but after a
I love the Maytag Atlantis!!! This sounds like your motor may be bad. It's NOT the element or it would not heat at all. Hope this helps!
Aug 13, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Feb 28, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Why is Maytag Atlantis is not drying like it use to?
Nov 12, 2007 | Maytag Atlantis MDE7400AY Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
195 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
