Question about Seth Thomas Bachman Thomas Annie Clarabel Electric Train Set
ENGINE DOES NOT MOVE VERY WELL AND IS LOUD
I have three Bachman diesel engines one works very well, one moves o.k. but stops at times and need a slight push to get moving again (this one is very noisey also), and the third only lights up but does not move.
all three trains are n-scale. I'm new at model trains so any help would be nice. Thank You
Jeremy Rodecap
  • 59 Answers
Depends what a filter or pump the engines hawe cood bee the fuel pump or filter
Posted on Nov 10, 2010
    Problem Solver:
  • 8 Answers
Sounds like the wheels may be dirty on the one . Have you tried cleaning them? The noisey one may need a little grease on the gears. The one that does not move but lights up, not sure. Have you tried to take the body off and see if a wire is disconnected?
Try going on line and look for a group on Yahoo Groups for N-scale. They will probably be more helpful and you will get more information about N scale trains. Good luck!
Bob D.
Posted on Aug 22, 2009
Mk3 mondeo engine loud ticking like grinding all the time.just had problem with injectors.had all 4 replaced.the garage says piston slap
Is this a new noise your hearing? If your mechanic has correctly diagnosed the noise find more info here:
http://www.autos.ca/auto-tech/auto-tech-noisy-engine-it-might-be-piston-slap/
The distinctive noise of a diesel engine is variably called diesel clatter, diesel nailing, or diesel knock. Diesel clatter is caused largely by the diesel combustion process; the sudden ignition of the diesel fuel when injected into the combustion chamber causes a pressure wave. Engine designers can reduce diesel clatter through: indirect injection; pilot or pre-injection; injection timing; injection rate; compression ratio; turbo boost; and exhaust gas recirculation (EGR).
Find more information more here: Diesel engine Wikipedia the free encyclopedia http://www.autos.ca/auto-tech/auto-tech-noisy-engine-it-might-be-piston-slap
Aug 30, 2017 | Cars & Trucks
My 2000 toyota camry 4cyl. seized up on me. out of oil. i can't afford to lose my car. how can i unseize engine? diesel fuel?
All that I can suggest is to remove the spark plugs and put a small amount(1 oz) of Marvel Mystery Oil into the cylinders. Let this soak in for a about 30 minutes. Take a socket to the crankshaft main bolt with a 1/2 break over bar and slowly jelly move the boat forward and back in small amounts and try to get the crank to turn if it does insert more Marvel Mystery Oil and continue until you get the crank to turn fully after turning the crank at least three times then change the oil reinstall the spark plugs and give it a try
Jul 14, 2017 | Toyota Cars & Trucks
How do I bleed a perkins ad3.152
locate the three diesel fuel lines that ate connected to the fuel injection pump, loosen them one at a time, only enough to have movement of the fuel line from the connecting nut, crank the engine, until you see and get fuel coming out from around the fuel line, tighten that fuel line and move on to the next fuel line
when all three lines have been bled, the unit should start
Mar 04, 2015 | Electrical Supplies
My car is range rover diesel automatic 1998. when the engine is runing and the car is stationary you can see some time the speedometer moving up and down at that time the engine rev changes .is the engine...
the engine is fine- what you are seeing is the transmission fluid flowing fast enough in transmission to cause the speedometer to move- does the transmission slip at all? might be time to have transmission serviced- fluid and filter change.
Jul 30, 2011 | Land Rover Range Rover Cars & Trucks
I have a 2003 kia sportage 2000cc can anyone tell me if the engine on this is a interference or none interference It is registered september 2003 the timing belt has broken and I need to know if the...
The term interference refers to the valves being in the way of the pistons when they move to the top of the cylinder. When the timing belt breaks, the valves will stay in the position they were in when the belt broke, they will not move or "Drop". either way you still need to move the crank and the cam to the alignment positions before installing a new belt. To manually check, you can remove the spark plugs and turn the engine over by hand. it is not too too hard and if you don't hear or feel anything stopping you from turning it by hand then you are in luck, it is a non interference engine. Assuming the engine was running when it broke you should have hear some loud banking if it was an interference engine. The best information i can find says, YES, this is an interference engine.
Jan 20, 2011 | Kia Sportage Cars & Trucks
Seth Thomas Bachman Thomas Annie Clarabel Electric Train Set Logo
188 people viewed this question
Top Seth Thomas Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Seth Thomas Toy Expert? Answer questions, earn points and help others
