Question about Kenmore Elite HE4 Electric Dryer
Kenmore HE2 door bellow
Are your directions for replacing the Kenmore Elites door bellow the same for the Kenmore HE2?
  • mktzach Feb 19, 2009
    torn rubber seal
    Problem Solver:
  • 5 Answers
  • 91 Answers
He 2 are a little similar to all H E washer ,, it has spring clamps (2) remove and install them same way
Posted on Jan 04, 2009
2 Suggested Answers
  • 91 Answers
SOURCE: how do I replace the kenmore he2 bellow?
door boot not eady to install,, if you can but machine on a 45 tipp back and place 4x4 wood to hold in front it has a clamp remove ,, now there is another clamp once u can remove boot ,,
Posted on Jan 03, 2009
Kenmore HE2 Plus Model# 11047512600 When pushing the start button it will just beep 3 times and not do anything, door won't lock or start cycle. No error codes are displayed. Whats wrong?
Hello Jason,
Regarding
  • There is a communication error in the control board.
  • Also the door Latch assembly may be defective. Check & replace as necessary.
Here is a link to Sears parts direct.
KENMORE RESIDENTIAL WASHER Parts Model 11047512600 Sears PartsDirect
Jun 25, 2015 | Kenmore Washing Machines
Took apart my He2 washer to see why it was leaking. Looks like a small tear in the rubber bellows close to where the dispenser tube enters (in front). I guess the bellows will have to be replaced. I was...
the bellows do tear and you will want to consult the Warrentee on that point several are recalled on the point of the wiring harness there should be no significant issue but the door switch is probably the issue . this is where the sensor and door lock is try reseating this and trying the power again
Mar 05, 2011 | Kenmore Elite HE4 Electric Dryer
How do I go about replacing the door seal (bellows) on my kenmore elite washer?
The following link explains how to access and replace the bellow one:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
A replacement bellow (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites so shop and compare. The first three sites on the list, have helpful exploded view diagrams to assist you with locating and identifying any parts you may need.
NOTE: The manufacturer recommends that you leave the door OPEN between washes to, not only allow the bellow to keep from becoming permanently stretched, but also to allow the wash tub to breath to prevent mold and mildew from forming. This will extend the life of the bellow and minimize any odors in your washer.
If you have any questions, please post back with your complete MODEL NUMBER and let me know. I hope this helps you.
Jun 27, 2010 | Kenmore HE2 Plus Front Load Washer
How do I stop my Kenmore front loader from leaking around the door. I have a Kenmore HE 2plus front loader
If this is a Kenmore FRONT LOADER you need to remove the lower toe panel directly below the door to inspect the cabinet interior for the source of your leak. The following link explains:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
The most common source of leaks on a front loader is the rubber door bellow. The bellow can develop cracks, rips or tears with age and needs to replaced. The following link explains how:
If you have any questions about this repair, please let me know so that I may be able to provide you with better assistance. I hope this helps you.
Jan 31, 2010 | Kenmore HE2 Plus Front Load Washer
I pulled bellow boot out from door with the bellow clamp
you can try to do it from inside but difficult if you never have done it
Jan 09, 2010 | Kenmore HE2 Plus Front Load Washer
I opened the door on my he2 plus 1104751 and a large retain type wire with a spring was there. I assume this goes around the tub seal to hold it on tight?
Yes, it is used to secure the bellows (door side) of the gasket to the cabinet. If the loop is still intact, you can use a pair of needle nose pliers to reinstall the retaining wire onto the gasket.
If the wire loop is broken, you'll want to get a replacement ASAP to prevent leaking and to prevent damaging the gasket too. They're available from searspartsdirect.com or you can check for a local parts supplier if you wish.
Hope you find this Very Helpful and best regards!
Oct 09, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 plus 11047532601
If it's stackable, you'll want to start by removing the dryer.
Open the door and remove the outer bellow spring around the bellow to release it from the cabinet lip. At this point lean the machine back to give more space between the drum and the cabinet.
Remove the kickplate for easier access and to visually check for leaks later.
At the top/right of the bellows (close to the tub) loosen the bellow to tub clamp and pull out the bellow.
Install the new bellow starting at the top by aligning the marks. Work your way around until bellows is properly seated snug against the tub.
Replace the tub to bellow clamp and tighten it (make sure the bellow stays snug against the tub while tightening the clamp). Once in place, lay the machine back to level and reinstall the front of the bellows to the cabinet with the outer bellow spring clamp.
With towels handy (just in case), let the machine fill and agitate for a few minutes and check for water leaks. If all is well, re-install the kickplate and wash some laundry.
Feb 22, 2009 | Kenmore Elite 45986 Front Load Washer
How do I replace the kenmore he2 bellow?
Dec 30, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Bellow Replacement
Make sure the drain holes are clear in the bottom of the bellow. Also, make sure the bellow is aligned properly. There should have been an alignment arrow at the 12 o'clock position. Hope this helps.
Aug 05, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4 Electric Dryer Logo
654 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
