Question about LG 42PX5D 42 in. Plasma HDTV
Tv clicks on and off
My 42 inch plasma lg clicks when u turn it on on and off then i unplug it it stays on sometimes. but it will cut off by it self
    Novelist:
  • 152 Answers
Hello, you have a protection circut shutdown. it is usually the power board failing but not allways. its common becuase these internal circuts operate at high heat and handle high voltages these components may become fualty after time with normal use, not holding the right voltage or resistence will the cuase fualts in the circut. becuase these tv,s have built in protection that happens your tv is powering off when it detects any abnormality within the circut .
the best bet is to have it service by a qualified center it isnt easy to detect without the proper equipment. a service center can diagnose it and give you a estimate you will be better off doing it now before it developes more fualts or even a complete shut down..
hope this helps happy holidays
Posted on Dec 22, 2008
    Guru:
  • 449 Answers
This type of problem usually indicates that the power supply unit for your Lg Projection Tv has become faulty.Either replace it or get it repaired.
This is a common problem 'if it's under warranty the will replace it. good luck happy holiday
    Master:
  • 479 Answers
Remove the connections of the tv from the main plug and checkout the wire is it proper or looks like burned internally or getting cut somewhere in between.if the wire is proper.then its definately the problem in the main board of the tv .any of the components which supports the tv to function properly is either got loose on the board or become faulty.the board has to be checked out with the multimeter.if the component is loose on the board it can be resoldered but if it is faulty it has to be replaced to make the tv work properly.
Posted on Dec 12, 2008
  • 734 Answers
Check power cord.
thanks
How do you do a master reset on a 42 inch LG plasma TV?
unplug the tv and let stay unplugged for at least 24 hrs then try it if that dont work then it sounds like a power board issue
Aug 24, 2012 | LG 42LC2D 42 in. LCD HDTV
My 42 inch LG plasma turns on and off repeatedly when I try to turn it on. happened a few times before when tv was working fine, now it wont turn on at all. I have to unplug tv to get it to stop turning on...
Theres a short between the start-up processor signal on the interface board and power supply. It keeps sending the same start-byte over and over again to the power board. This could also be a DC high voltage shutdown on the power board its self. Now the tv is in protection mode to prevent further damage. Get it serviced at your local repair center. If its under warranty take it back.
Nov 04, 2009 | LG 42PC3D 42 in. Plasma Television
42 inch LG Plasma TV - Lost picture
This is almost certainly the device that sends electricity to the the plasma in the panel after failing. Bring to your local repair shop and expect to pay 300-400 parts and 100-200 labour.
Cheers,
Stephen
Apr 28, 2009 | LG 50PC1DRA 50 in. Plasma Television
If you paid by cheque or credit card, that is your proof of purchase.
Mar 09, 2017 | LG 50PG6000 50 in. HD-Ready Plasma TV
Most likely what happened is one of the capacitors went bad. When a capacitors goes bad it produces a popping sound. This could be an easy and cheap fix if you find the bad capacitor or capacitors. The bad capacitor will have a bulging top most likely on the power board but could be anywhere.
Feb 24, 2009 | LG 42LC3R 42 in. LCD TV
Loud pop Blank screen 42 inch Viore Plasma
Unfortunately, that board is the inverter board. And for this model the inverter board is only supplied with the the PDP panel. The panel is quite expensive, here's a link if needed:
LG 42PX5D Replacement Part PDP Plasma Display Panel
Dec 26, 2008 | LG 42PX5D 42 in. Plasma HDTV
ysus pcb that supplies voltage to the panel is faulty
Dec 14, 2007 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
sounds like it may be a software upgrade
Oct 16, 2007 | LG 50PX4DR 50 in. Plasma TV
LG plasma tv 42 and 50 inch
probably you switch was sticking causing it to behave that way.just monitor you tv if it happen once more then it will be time to call the tech.standby my brother.
Apr 03, 2007 | LG 50PX4DR 50 in. Plasma TV
LG 42PX5D 42 in. Plasma HDTV Logo
24 people viewed this question
Computer Repairing
Computer Repairing
